XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > X1 DIY (Do-It-Yourself) Discussions
Register FAQ Calendar Today's Posts
      01-11-2014, 03:45 PM   #1
TrueRedi3
Drives: 2015 BMW i3
Rear Fog Mod
Hey guys... a bit of a twist on the rear fog mod that others have performed. I wanted to have the rear fog icon on the button but did not want to pay $150+ for a brand new switch. I found a used switch for a E82 120i (PN 61316932798) from Europe that had the button with logo and swapped it for the blank spacer on my switch.
Good news is that it works and it only cost me $35.
Bad news is that the LED that illuminates the button at night is missing from my switch.
I thought I would share my experience in case anyone else had a similar idea...
      01-11-2014, 10:40 PM   #2
BeEmVe
Drives: '14 X1 x28i M-Sport
You are not totally out of luck. I did the same at first but also used the electronics from the used switch as well. I posted that mod here:
http://e84.xbimmers.com/forums/showp...1&postcount=57
In my case the switch I got was for non-zenon lights but everything else was a match (fog lights and rain sensor). So I just used the electronics board. The leveling control is ignored and now you have the backlighting.
If you swap boards check the soft button height on the boards as they may be different between switches. If so you will need to swap the "block" between the button and board. One can also very easily disassemble the leveling control and put the blank plate from the original over it.
I.e. do not be afraid to totally disassemble the switch and mix and match.
That all worked great but I also happened to find a second switch that was the correct match sans the chrome knob. I just swapped it.
Oh, I paid less than $15 for each switch including shipping .
      01-12-2014, 09:05 AM   #3
Black Flagged
Black Flagged's Avatar
Drives: M2C
you can use your OEM switch.... just remove it and then take the tabs of the inactive switch to allow it to activate. no you wont have a lighted icon on the switch when done, but it works for free
      01-12-2014, 10:04 AM   #4
BeEmVe
Originally Posted by Gangsta D View Post
you can use your OEM switch.... just remove it and then take the tabs off the inactive switch to allow it to activate. no you wont have a lighted icon on the switch when done, but it works for free
I think you missed the point. We know about the free trim the tabs mod. However, some want the button with the spiffy graphics rather than a blank button. Rather than buying an all new switch one can buy a used switch for cheap that has the button with graphics. However, the if one uses the original switch electronics there is no back lighting. As such, one also needs to use the electronics from the used switch. So this more about spending $150 vs $30 or so to get the full function.
      01-12-2014, 10:58 AM   #5
TrueRedi3
Drives: 2015 BMW i3
Hmmm... I didn't consider that the PCB in the used switch would be compatible. Thank you for the suggestion. I will look in to swapping those if my OCD sets in...
      01-12-2014, 12:08 PM   #6
Black Flagged
Drives: M2C
i did miss the point, my bad thanks for the FYI on the back light and the graphics install! going to do this to my E84 & E88
      01-30-2014, 09:17 PM   #7
Twix
Twix's Avatar
Drives: 2011 e91
Just did this today. I bought an OEM switch from Germany and used the board and rear button. I used my original switch for the dial because it has the silver finish to it.
Super easy to get at, I used a spoon handle to gently pry the side panel away, then I just pressed the upper tabs and pulled the assembly into the dash and outward through the side panel.
The switch itself is easy to dissamble, but the button removal can be annoying. Just takes a bit of patience and a steady hand with a small screw driver to move the tabs.
2011 E91
2016 M2 - Sold
2014 X1 - Sold
2002 Land Rover Discovery II - 3" lift & 33s
      01-30-2014, 11:41 PM   #8
BeEmVe
Twix it is much easier to remove the dial and swap it than remove the damn button. Just remove the graphics for the dial then pop the dial off. Swap - done.
      02-25-2014, 03:05 PM   #9
STE92VE
STEVIL Empire
STE92VE's Avatar
Drives: Fast
Great pic of the side panel removed showing the attachment locations. Will be a big help when I swap out the E84's USA light switch with the Euro one I picked up from a Munich BMW dealer when we did ED for the E90.
2007 E92 328i 6MT-Space Gray/Black Dakota/Gray Poplar w/heated seats-PCD 4/27/07 (SOLD)
2009 E90 328i xDrive 6AT-Space Gray/Oyster Dakota/Dark Burl Walnut w/ZPP,ZCW,Xenons-ED 4/17/09 - Redelivery 5/30/09 (SOLD)
2014 E84 xDrive28i 8AT-Alpine White/Black Nevada/Silver Matte w/ZMV,ZLP,494 - DD 3/14/14 (SOLD)
      02-25-2014, 03:49 PM   #10
BeEmVe
FWIW I was going to remove the side panel but the vent popped right out really easily. From there one can access the switch from the top.
      02-25-2014, 03:56 PM   #11
STE92VE
STEVIL Empire
STE92VE's Avatar
Drives: Fast
Thanks, I'll keep that in mind.
      02-25-2014, 07:17 PM   #12
Black Flagged
Drives: M2C
Yes, that way is a lot easier to do then remove the side panel! That's how I did mine also..
      03-15-2014, 10:01 AM   #13
STE92VE
STEVIL Empire
STE92VE's Avatar
Drives: Fast
Thanks guys! Just accomplished this today and it had to be the easiest thing in the world to do, way easier than replacing the switch on the E92 & E90.
      03-16-2014, 11:11 AM   #14
Black Flagged
Drives: M2C
sharing knowledge and helping out other members is what this forum is all about...
      04-13-2014, 02:55 PM   #15
Ivan Vasilevich
Ivan Vasilevich's Avatar
Drives: BMW X1
Hi guys!
I read a lot of your forum, thanks for the info!
Also decided to share the experience
OSRAM LEDriving® LEDFOG101 on my install BMW Х1
this is my video installation fog lamps
      04-22-2014, 02:55 AM   #16
Ivan Vasilevich
Drives: BMW X1
How to disable the fog lights
NFRM.
FRM3_E89.C32
KALTUE_NSW_M2_37_M1_3_C32
nicht_aktiv
WARMUE_NSW_M2_37_M1_3_C32
nicht_aktiv
      04-22-2014, 09:02 AM   #17
Twix
Twix's Avatar
Drives: 2011 e91
Should have made a new post, this one was for rear fogs, not fronts.
2011 E91
2016 M2 - Sold
2014 X1 - Sold
      04-22-2014, 10:57 PM   #18
Ivan Vasilevich
Drives: BMW X1
Twix, Sorry, no rights to create a new topic.
Moderators can move where they want.
      08-11-2022, 07:34 PM   #19
GuamX1
GuamX1's Avatar
Guam
28
Drives: 08 BMW 135i, 08 128 Cab
I tried to remove the headlamp switch and I thought you removed the vent so I broke the vent
2013 BMW X1 * 1973 Clubman GT * 2016 Mazda MX5 * 2000 Honda S2000
2004 BMW 325i Touring * 2009 BMW X5 3.0xdrive
xbimmers
