ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Engine, Exhaust, Drivetrain Modifications
  TireRack
      10-15-2007, 03:40 PM   #1
Pontio
Drives: Z4 Coupe
Tuning advice for my 3.0si
Hi every1, this is the first topis im starting rather then just replying to others, hope you can help me out. I am the proud new owner of a 2006 Z4 coupe 3.0si and would like to get it upto or at least closer to the 300bhp mark. it is the N52 engine so already has 260-265bhp depending on what sire you look at. I dont want to touch the exhaust as i dont want it too noisy or obvious its been "played" with. Spoken to a few different companies and there all fairly confident in getting between 15 to 20bhp out of it. However that still leaves me a bit short of 300ish. I was looking at the simota carbon cai's which can give upto 10bhp apparently however they are only for the M54 3.0. Any ideas where i can get a decent cai or anything suttle for a bit of help to get closer to 300BHP? I'm in the uk btw so delivery charges might be silly from abroad.
Thanks for any help
      10-15-2007, 06:20 PM   #2
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
169
Drives: 2007 M Coupe
Search for the ESS S/C kit.
07 ///M Coupe (Premium Package) Black Saphire Ext. Imola Red Int.
Best Website EVER!
      10-15-2007, 06:34 PM   #3
BimmerZealot
Drives: 2019 BMW X3 xDrive30i
No one makes a supercharger kit for the N52 engine yet. The M54 yes but not the N52. As of right now there are very few modifications for the N52 engine. There are a few exhaust options, I haven't seen any intake options. You might have to wait for anything substantial. To get to the 300 HP mark you're going to need a lot more then you think. N/A tuning is very expensive for sadly very minimal gains. You're looking at headers, full catback exhaust, intake, and software that should put you close to it but also probably drain a good 3500$ with install.
      10-16-2007, 11:32 AM   #4
Pontio
Drives: Z4 Coupe
even if supercharger kits were available i want to keep it n/a. the remap company seem confident of 15-20bhp and with a simota i should gain 4-6bhp apparently so i guess im not really gonne get much better then maybe 290 if i'm lucky..
      10-17-2007, 03:42 AM   #5
Nightrider07
Drives: 2007 bmw z4 3.0si
i have a z4 3.0si myself and exhaust is one option. but expensive supersprint i called sells the muffler and y-pipe for 1300 dollars.to get closer to 300 hp you then would have to get full header system for the car, which costs $5600 . they say it will give about 30 hp and the exhaust does about 10 to 15.
for intake , i found one but it costs $900 dollars and is carbon fiber,.
Iam in the process myself of doing some cheap upgrades to my car. i just want the sound for it. so iam making a custom intake and deleting the resisnator
or you could just pop in a v8 motor in there from haman 400hp then
      10-17-2007, 11:10 AM   #6
Pontio
Drives: Z4 Coupe
a bit expensive doing that.. i'll look into the supersprint system tho, thanks
      10-17-2007, 12:00 PM   #7
BimmerZealot
You can also look at the Eisenmann exhausts they sound great, as well as Remus. Supersprint isn't the only company that makes one.
Nightrider07: Which intake are you talking about? Links? Thanks
      10-17-2007, 02:28 PM   #8
Pontio
Drives: Z4 Coupe
I found no intakes apart from the gruppe m for the n52 engine and the only exhausts i found are cat back only, all manifolds are only LHD.
      10-17-2007, 03:19 PM   #9
Nightrider07
gruppe yeah thats the intake which costs 900 dollars i found. the carbon fiber one. that is expensive for an intake. i thought intakes were supposed to run from 200 to 400. i wish aem or some other brand comes out with an intake
      10-17-2007, 04:20 PM   #10
Pontio
Drives: Z4 Coupe
i looked everywhere and know1 does 1. the reason they dont make one is because the air flow sensor is screwed onto the airbox, i could probably reposition it but cant be bothered. just ordered a bmc panel filter and gonna remove the resonator foams.
      10-18-2007, 01:47 AM   #11
Nightrider07
all you would have to do unscrew that intake sensor and get a 2 or 3 inch rubber tube and pop make it fit into the tube. then have the air filter at the end of it
zpost
