M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > F10 M5 DIY Guides
      09-20-2013, 06:57 PM   #1
cncmastr
cncmastr's Avatar
Drives: E30 M3 Cecotto, F85, G05, G07,
2018 X5 M  [0.00]
2020 M2 CS  [0.00]
2005 BMW X5 4.8is  [0.00]
2006 BMW M3  [0.00]
Video: V1 Hardwire DIY Install F10 M5
Hi guys,
I just posted a video here that shows how to hardwire (using the V1 hardwire kit) the radar detector in an F10 M5. I used green wire with the brown stripe on it to tap into. It was hard to access the ground bolt, but with a swivel accessory it is possible. I referenced this guide for help as well. - http://www.bimmerfest.com/forums/sho...d.php?t=515517
Thanks to William for letting me use his car.
      09-21-2013, 11:31 AM   #2
Bokke
Bokke's Avatar
574
Drives: E90M3/991.2GT3/G82M4CSL/9YOTGT
Garage:
09 E90 ///M3 | SS | Black | Modded
22 992.1 GT3 | Black | PCCB | LWB | PDK
23 G82 ///M4CSL | AW | Race Buckets |
24 9YO Cayenne TGT | QGM| Burgundy | Neodyne / PCCB
      09-30-2013, 12:30 AM   #3
Niko1414
Drives: 720S, s550, S7, 997GT3RS
Nice job
      10-06-2013, 02:30 PM   #4
MickeyLe
Drives: 2008 Black M5
nice job
      10-26-2013, 02:19 PM   #5
cncmastr
cncmastr's Avatar
2018 X5 M  [0.00]
2020 M2 CS  [0.00]
2006 BMW M3  [0.00]
Glad to help!
      01-04-2014, 05:46 PM   #6
shellbmb
shellbmb's Avatar
Drives: 2022 F90 M5C
Thanks for the DIY especially adding that extra washer for the ground. Worked like a charm!!
      01-06-2014, 10:43 PM   #7
Pburns
Drives: M4
Looks good. I'd like to get that installed in the M4.
      06-04-2015, 10:13 PM   #8
midnightrider
Drives: m5
I also used the green wire with brown stripe. When the car shuts down at a traffic light (fuel saver) the radar detector reboots when the car starts back up. Annoying. Any answers other than the obvious - shut off the fuel saver switch?
      06-05-2015, 10:39 AM   #9
v3n0m
Drives: 2013 MCB M5
I hardwired as well but in a much simpler way. I just tapped the powered mirror lines and only had to remove the piece of the housing right near the mirror. Does not turn off with the fuel saver switch. See here for instructions:
http://www.bimmerfest.com/forums/sho...d.php?t=546557
      12-07-2015, 02:08 PM   #10
barchetta316
Drives: E46 ///M3 & F10 ///M5 CP
What were the exact swivel ratchet tools you guys used for this DIY? Cant find the right tool to access the bolt for the ground wire.
      12-13-2015, 05:02 PM   #11
StevanM5
StevanM5's Avatar
19
Drives: M5 F10
I'll connect my dashcam like this!
Nice diy
      07-19-2016, 03:59 PM   #12
djseto
Drives: 2013 M5
I did this as well but I found that the Ground connector on the invisicord was too short and barely made contact inside the plastic connector so improvised a little to connect ground...see photo
Tags
diy, hardwire, valentine one v1 radar detector
m5post
