2010 2011 BMW 5 Series Forum F10 ___DIY - Heat Shield For BMS Intake - 535i |
08-24-2013, 05:12 PM | #1 |
Rep 260
Just to update that there was no test done before or after installing the barrier to see if there was any air restriction which may increase/decrease performance. Also, note that there is no guarantee that this DIY will keep heat and dirt away from the air filter. Please use this as a form of research and use it to your own discretion.
-sheet metal 26 gauge 12"x24" -10" metal cutting snips -3M tape -high temp spray paint -rubber tube seal along the top (not shown) The shield was cut from a single 12x24 sheet metal into two separate pieces, parts A is outline in RED and B in GREEN (see pic). The overall size of the shield is 10.25"x11" with the height of 3.75" in the back tapering down to 2.5" in front. Part A is taped to part B with 3M tape (test fit first). I made the shield to fit the inside of the stock intake box, there is a little edge that runs along the inside. Next was to spray it with high temp paint and place the rubber seal along the top and in the back around the BMS intake housing. Thanks and Good Luck! Last edited by tvd75; 05-22-2014 at 02:20 PM.. |
08-26-2013, 11:07 PM | #3 |
Rep 2,197
Any pics of the finished product? You should spray paint it or plastidip in black so that it doesn't look so out of place.
Bake
08-26-2013, 11:16 PM | #5 | |
Rep 260
09-18-2013, 10:50 AM | #9 | |
Rep 422
2023 I4 40 Msport White/red interior 19"Rims
2023 Ix 50 MSport Hraphite Gray.Oyster interios 22" Rims Retired 2020 X7 MSport 40i 2020 I3s Bev |
09-29-2013, 07:48 AM | #12 |
Rep 375
Drives: 2011 535i Sport - P1, P2
06-25-2014, 12:18 PM | #15 |
V.I.P.
40
Rep 248
Drives: F10 535i 2011, F10 550i 2015
Has anybody else tried this, thinking of giving it a try... if it actually makes a difference?
F10 550i Imperial Blue/Ivory
BM3 Stage 1 - xHP Stage 1 F10 535i Alpine White/Oyster BMC - Vorsteiner Exhaust - ER Chargepipe - AR Catless DP - MHD Stage 2 - FMIC |
