F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > PPK Install Problems: Early November Build Issue?
Extreme Powerhouse
      06-10-2013, 02:53 PM   #1
RJK993
Eurowerkz Co-Founder
Drives: '95 993 cabrio/13 335xi Msport
Looking for a little bit of help on this one…
My car is a: 2013 335xi Msport, Sport Transmission option. Build was completed 11/6/13.
-I preordered my PPK from the parts department at my dealer based upon my VIN.
-Sent the car in for service/installation Thursday.
-I was informed Friday that the car "wouldn't take the kit because the DME in my car was the old DME."
-Then my SA says BMW engineering got back to them, and the car should take the kit.
-Today my SA explains it to me as "one of the amplifiers won't take the upload". He's contacted BMW engineering again, and is "waiting for an answer".
Does any of this make sense to anyone who has had a PPK installed? This was supposed to be a 2 hour process that's taken since Thursday.
Past:2010 MB C300 Sport
2001 BMW 330ci AA Supercharged
1999 Shelby SP360 #150
      06-10-2013, 06:56 PM   #2
hksusa
Drives: 2013 BMW 335i M Package
From what i understand, Anything post 11/12 is suppose to get a DME Replacement with PPK?
      06-10-2013, 08:07 PM   #3
tdizzle
Drives: 2017 F80 ZCP
I thought it was the opposite, but I haven't looked at the details in awhile.
      06-10-2013, 09:14 PM   #4
KevRyd
Drives: F30 335i Xdrive MSport EBII
Early builds need the DME July 2012 to Sept/Oct 2012
      06-10-2013, 09:34 PM   #5
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
11/6/13 hasn't happened yet.
And 6/11/13 is tomorrow...
So I think your build date might be the issue...Pre-11/12, you need a new DME.
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray
M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com
      06-11-2013, 10:25 PM   #6
parisholley
Drives: 2013 335i
I am going through the same thing, I bought the kit without DME and my vin is Nov production and was told that it wouldn't work and they ended up backing out the changes. Right now I'm trying to work with the folks who sold me the kit to see if I can get the DME.
      06-12-2013, 08:46 AM   #7
tdizzle
Ha, nice catch. Skimmed it and it didn't say '12 so I was like um, DME should be fine. But working in the future, who knows!
      06-12-2013, 12:54 PM   #8
jrsx86
Drives: AW '13 335i M Sport
I had the same issue with an 11/12 build. They said I needed a new DME after they tried a remote session to program and it failed. DME still hasn't arrived and its been over a month now. Must be really back ordered.
      06-12-2013, 01:39 PM   #9
shivaswrath
Drives: 2012 335i
it's taking that long?
It really shouldn't, I received mine within 3 weeks of ordering back when it was released...
      06-12-2013, 06:43 PM   #10
jrsx86
They said it was back ordered but they expected it to arrive in 2 weeks. Its been 5 weeks now and the service writer gave me a call a week ago telling me that it should almost be here, LOL. I'm not in a rush, but this wait is taking a lot longer than expected.
      06-13-2013, 11:11 AM   #11
RJK993
thanks for the replies guys!
ok so they wound up having to change my radio/head unit?
the description in my paperwork is as follows:
cic failed during programming performed battery reset, performed 2nd attempt to program and code vehicle. vehicle failed second attempt, performed battery reset again and tried third attempt, third attempt failed. instructed to perform IRAP session, set up irap session, unable to perform due to faulty CIC, need to replace CIC first and perform another ista-p session as per bmw engineering. also the VO was not changed for m-performance package during initial programming of CIC, kombi and amp successful, but DME failed to activate. found bad file in original m-powerkit download. necessary to set up another irap session. irap session successful. necessary to let vehicle sleep for 20 minutes and road test, necessary to obtain release code for navigation.
hope this helps you guys out!
      06-19-2013, 12:46 PM   #12
gigibombom
Drives: 335xi
Just called my SA and went to BMWUSA.com then realized that the MPPK option for pre-11/2012 is no longer available on the website and the SA cannot put the order for me. However, I contacted GetBMWparts and they said I can still order it through them but will take 3-4 weeks from now. I am wondering if BMW pulled back this option for pre 11/2012 as the issues they have experienced? Anyone has the similar experience?
      06-19-2013, 04:10 PM   #13
jrsx86
That is interesting... and it could explain why my new DME hasn't arrived yet after 1.5 months of waiting for delivery. My SA hasn't updated me on any changes yet either. I guess the wait continues.
      06-19-2013, 04:56 PM   #14
shivaswrath
Drives: 2012 335i
Holy crap...so German. If the part's causing issues, drop it.
Glad I got mine done...I bet you they pulled off their site because of the excessive costs associated with the IRAP sessions.
FOR ONCE, being a first adopter paid off....Tischer is standup though, they'll get you the stuff.
      06-19-2013, 07:42 PM   #15
gigibombom
Drives: 335xi
I still took the risk and put down an order through getbmwparts. what concerns me more is that i am afraid of no dealership will be willing to install for me with 3-4 hours labor charge. it seems like the issues have spread out internally and they are aware of this is not gonna be straight forward. I guess the BMW NA 's solution is to take this off from their official site which they already did. My car built is 2012/10/30. such a bad luck....
      06-19-2013, 08:51 PM   #16
edward.b.mendez
Germany
Drives: 2012 BMW 335i Sport line
I got the PPK kit installed at Taylor BMW in Augusta, GA. They had never done this on an F30 so I took my chances. My 335i needed a new DME since it was an 02/12 build. From placing the order to installation took exactly a week. There were issues with programming which the dealer had to do a remote from Germany and got it done with no problem.
      06-24-2013, 09:50 AM   #17
wrmem73
Drives: 2013 335ix white sport line
My 335 has a build date of 4/13 and the ECU version is still MEVD1726 (which requires the the new DME). I was confused by all of this (why the < 11/12 and > 11/12 in the order description for the PPK if my car is a 4/13 build and still requires the new DME?). My dealer contacted BMW NA and they said that BMW was still building vehicles with the older ECU/DME up until recently and that the PPK parts description will (eventually?) be updated to reflect that. Regardless of whether that's true or not, the important part is if they plug into your car and the ECU version is MEVD1726, the new DME is needed; if it's MEVD172S then you don't. Looks like I'm in for a long wait.
      06-24-2013, 10:24 AM   #18
dinonz
Drives: 2016 M3 MWM ZCP
Do you know how to determine which we have? I'm guessing as mine was a 4/13 build I have the same as you but can we check or can only the dealer find out?
      06-25-2013, 12:25 AM   #19
jddssc121
Drives: vroom
I have a pre 11/12 build and needed a new DME. Install at first failed, and it took an IRAP session to straighten it out. All in all they had my car for 5 days but it all worked out in the end and I am happy
      07-02-2013, 08:53 AM   #20
boomn29
boomn29's Avatar
Bought my car in Oct/2012 so obviously the older DME. Parts on order...
2012 F30 BMW 335i
8sp; Red; Sport, 20x9f; 20x10r (wearing 245/275's) Bronze Forgeline DE3C's, M-PPK, Challenge HFC-DP.
Winter Setup: 18x8 Black Enkei's with Blizzaks!
      07-02-2013, 12:46 PM   #21
gigibombom
Drives: 335xi
does anyone who requires the new DME get the parts and have it installed recently? I placed my order for the whole kit through getbmwparts on 6/19 but the order status still shows "processing". Will appreciate it if anyone on the same boat can keep us update your status on this "pain in the a**" early MPPK situation.
Thanks,
      07-02-2013, 04:10 PM   #22
jrsx86
Thanks,
I haven't heard from my SA since the last time he called in to tell me "it should be here any day now". I'm guessing the DME won't be coming in anytime soon as its been almost 2 months for me. Maybe BMW had put a halt on the MPPK for now since they've taken it off their website. Probably at least until they can get the install straightened out for those needing new DME's (install without needing IRAP session).
f30post
