F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > need more power from my 335i sport line , ECU/downpipe/intake - what my best option?
GetBMWParts
      05-14-2013, 01:37 AM   #1
pelo911
Drives: 991 GT3
i have the car 4 month
3K miles now
BMS , i checked their website
they don't offer N55 Stage 2 for F30 yet.
i found also those 2:
aFe Scorcher
http://www.turnermotorsport.com/p-16...-f30-335i.aspx
      05-14-2013, 03:03 AM   #2
TreDirtyFive
Drives: X3 M40i
BMS does have a stage 2 available for the car if it has a pneumatic boost solenoid rather than the newer electronic one. Dyno numbers are on the "other" site.
X3 M40i G01, M235i F22, 335 F30 MSport, 135 DCT, 335 E92, Audi A3
      05-14-2013, 08:02 AM   #3
RoundelM3
RoundelM3's Avatar
Drives: 15 F80 M3, 22 G01 X3 30i
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
What about the M-Performance Power Kit? Everyone here who's installed it (including myself) are giving it very good reviews. Plus, it's a BMW accessory, so there's no warranty hassles.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey
      05-14-2013, 09:22 AM   #4
Koer
Drives: F15 X5 2014 Sec. 50i
3K miles now
aFe Scorcher
Try the jb4 stage 2 and slap in a downpipe, you wont look back again.
You might need a new set of tires though.
      05-14-2013, 10:49 AM   #5
pelo911
Drives: 991 GT3
http://www.burgertuning.com/N55_Stage2_Jb4.html
"JB4 is not currently available for 2012+ F30 335 models. Manual transmission F10 models and F30 models should use the N55 Stage1 tuner"
      05-14-2013, 08:32 PM   #6
GET A GUN
Drives: 2013 335i F30
Even the stage one will out perform any other option out there. I can be installed in less then 5 minutes. Best thing is you can buy it for under $400 dollars. No race gas required. Plug in and play.
2013 335i F30 N55
      05-14-2013, 09:29 PM   #7
tdizzle
Drives: 2017 F80 ZCP
You have to request it, technically it's in beta testing and has been for quite awhile but lots of people are using it and getting great results.
It really is only beneficial if you want to toss in more aggressive mods with it (at least a DP or I'd say stick with stage 1 as the gains are about the same until you're able to use other maps). If you plan on using DP and have access to E85, etc, Stage 2 will turn your car into a monster.
Like the above poster said, stage 1 will give you more gains than anything else out there and is an easy install.
      05-14-2013, 10:47 PM   #8
pelo911
Drives: 991 GT3
it's heavy car , i think over 350 HP will be great to have
stage 2 sound great , what DP brand/model i should get?
also intake , which one?
about M-Performance Power Kit:
can i get more info about this kit?
for first look it's look overpriced for 20 hp only
is it come also with intake?
thanks
      05-14-2013, 11:01 PM   #9
ybbiz34
ybbiz34's Avatar
670
Drives: 2023 330i M Sport
thanks
The "Search" button is your friend.
Regarding the M Performance Power Kit:
Dyno at Post #11
http://www.f30post.com/forums/showthread.php?t=820502
More information, user reviews, etc. -
http://www.f30post.com/forums/showthread.php?t=821701
Current: '23 G20 M Sport 330i
Current: '20 X253 GLC300 SUV
Gone: '20 W205 C43 Sedan
Gone: '18 W205 C43 Sedan
Gone: '13 W204 C63 Sedan
      05-14-2013, 11:49 PM   #10
Koer
Dont quote stuff you dont even know is true. Makes my post seem stupid without any justification whatsoever.
What if i told you i have a JB4 stage 2 hooked up to my engine right now, what if i told you there is such a thing as an upgrade kit from stage 1 to stage 2. All you need is the old boost solenoid.
To top it all what if i told you even a stock car will pull like a monster with the stage 2.. The difference is very noticeable from stage 1, especially torque wise.
I hate it when people act all smartass, as if they're doing shit to help the OP out. Just stop, all you do is confuse people.
      05-15-2013, 12:16 AM   #11
Steve33
Steve33's Avatar
Drives: 2018 SQ5
You do realize, he is the OP right? He's quoting the website, don't get all pissy at him.
You are the one attempting to look like a smartass. He's just an owner asking questions, you're the dude being the ass here.
      05-15-2013, 10:13 AM   #12
tdizzle
thanks
You're getting into dangerous mod bug territory!
People will have different opinions on all of this so I'd do some research. For bang for your buck, I'd go with BMS stuff (although when it comes to DPs, there are others that perform just as well, the main difference, it seems, is price and perhaps fitment, but I haven't heard many complaints of any of the major tuners versions).
Stage 1 + a DP (let's go with BMS since it's widely used and honestly they all give about the same gain): You'll put down around 335hp at the wheels, which exceeds your 350hp goals at the crank by a fair margin. Not a bad way to spend under $1k and the Stage 1 is easily put on/off in 5 mins or less.
Stage 2+ a DP will give you a bit more power for only $150ish more and more flexibility. Map 2 will put you at 355hp at the wheels with a DP. Toss in E85 and you'll be nearing 370hp at the wheels. Stage 2 isn't quite as easy to install/remove as it's not just plug and play (it is but you have to tap into wires instead of just plugging in connectors).
As far as the intakes, AFE makes one right now that's pretty pricy, but looks good, not huge gains obviously (it's just an intake so you're probably looking at 10hp'ish) but they are there and probably even more with increased boost. BMS is working on one currently, not sure when it'll be released, but it will probably be a bit cheaper.
      05-15-2013, 02:23 PM   #13
Koer
Lol thats hilarious, my bad! Sorry op, didn't mean to be an ass!
Back on topic then, you should get the stage 2.. Its not THAT hard to install and the gains are pretty amazing.
Would you guys do intake or downpipe first?
      05-15-2013, 02:53 PM   #14
tdizzle
Performance wise, DP is a no brainer. You're looking at a good 30hp with no other mod. But obviously it's a bit harder to install and cost a bit more. Intakes don't offer that much of a performance bump for it to be a first mod, unless you're really into the whoossshh sound.
      05-15-2013, 03:37 PM   #15
J-boogey
J-boogey's Avatar
Drives: F30 335xi Msport
first 2 mods should be JB4 stage 2, and a Catless downpipe I went with ER couldn't be happier with both mods.. next is a catback for me!
2013 F30 335i xdrive | Estoril Blue | Black Dakota Leather | Aluminum Hexagon trim | M-Sport | Cold weather | DHP | Premium package | Tech package | Harmon Kardon | PDC | Rearview Cam | IND Painted reflectors | BMW performance grills | JB4 stage 2 | ER downpipe | BMS Intake | H&R sport springs
      05-15-2013, 06:08 PM   #16
s1k0ne
Drives: ..
JB4 stage 1 with DP throws a code correct?
JB4 stage 2 isn't offered for the 335i manuals still correct?
Just want to confirm some stuff cuz it seems like you guys know your stuff with the JB.
Thanks
F85 (17) - DG/AB
F87 6MT (20) - Comp - BSM
F80 DCT (18) - Comp - AW
F30 6MT 335i - EBII
      05-15-2013, 07:37 PM   #17
pelo911
Drives: 991 GT3
forgot to ask
when i'm taking the car to a service (once a year)
it will end my warranty?
      05-15-2013, 08:35 PM   #18
TreDirtyFive
Drives: X3 M40i
Thanks
JB4 Stage 2 does work on manuals but you tap into the CAN connectors in a different spot. As of now, the Stage 2 only works with cars with the pneumatic solenoid.
      05-15-2013, 08:42 PM   #19
tdizzle
forgot to ask
Technically no, unless they can prove the mod caused the issue, but many people just remove it to make sure.
      05-15-2013, 08:58 PM   #20
TreDirtyFive
Drives: X3 M40i
it literally takes less than 10 minutes to put on or remove.
      05-16-2013, 01:18 AM   #21
pelo911
Drives: 991 GT3
how can i find out if my car with pneumatic solenoid or not?
      05-16-2013, 12:20 PM   #22
Koer
http://mmg.photobucket.com/albumview/albums/NICKTENN/A55ADC7D-CE04-4E9D-9BE1-7AE27764E0C6-3309-000001E9B3C7C1B6_zps220667f1.jpg.html
Sorry for the link, the iphone app is not good for posting stuff,
The image shows how it looks like, it should be identical.
f30post
