04-27-2013, 03:48 AM | #1 |
Rep 68
Drives: F15 X5 30D MSport
Tyre Monitor Question
So during my last service 3 weeks ago, BMW told me I had a slow leak from a puncture in my rear driver's side tyre. They told me that as the inside edge was down to 3mm and due for replacement soon, I may as well leave it in, top it off at the servo from time to time, and then replace both rear tyres when they wear out fully in the next few months (the fact they had no replacement tyres in stock may have influenced this advice).
Tonight while driving I got a low tyre warning. I pulled over to a servo and checked the tyre. It was at 35psi (BMW told me the rears should be 42psi). The rest of the tyres were all still full. I topped the tyre off and re initialized the tyre monitor to clear the alarm. Less than 20km later the alarm came back on. Any thoughts as to what might be going on? I haven't been able to get in to another servo yet as I'm at a trivia night but in a few hours I need to drive about 80kms home.
Current Car: 2016 F15 X5 XDrive30d M Sport
Sold: 2012 F30 320d Luxury |
04-27-2013, 04:51 AM | #2 | |
Rep 960
04-27-2013, 08:33 AM | #3 | ||
Rep 1,549
04-27-2013, 09:40 AM | #4 |
spectator
81
Rep 507
Your slow leak is getting faster (the puncture is getting bigger). If you think the tyre tread will last a few months, then get the leak repaired at your local tyre shop (RFTs may be repairable so long as the puncture isn't in the sidewall).
04-27-2013, 06:35 PM | #5 |
Rep 68
The puncture is in the sidewall unfortunately. After I left the trivia night last night I stopped at the first servo I saw and checked the tyre and it was down to 12psi (so obviously a much faster leak).
Strangely, after I filled the tyre up to 40psi again and then drove 50+kms on the freeway, I checked it again at a servo after getting in to Sydney and it had only dropped down to 36psi. I can only guess that the leak is more time based than usage based. I've been phoning around this morning trying to find a tyre place open on a Sunday that also sells run-flats. I've found one close-ish to home, and they have quoted me $225 for run-flats. From what I've heard that seems very cheap (conspicuously so). They are offering Kumos. At that price, I may as well just swap it now and next service I do I can look at getting better tyres from BMW.
04-28-2013, 02:01 AM | #6 |
First Time Bimmer
30
Rep 617
i had a big nail puncture on my Accord Euro about 8 months ago, but the tyre was holding the pressure, and the during the service, the Honda dealer just sent for the tyre puncture service for $25. you know it's expensive to replace a run-flat tyre.
The Accord Euro Tyre was expensive on Michelin Premacy HP 235/45/18... |
04-28-2013, 07:19 PM | #8 |
Rep 68
The tyre(s) are now sorted. I went to the servo after leaving home to go and pick up the new tyres and when I checked the pressure in the punctured tyre it was down to 3psi (and for the first time I could see a barely visible deformation of the outer sidewall). I pumped it back up again but as soon as I took the hose off I could actually hear the air escaping from the tyre again.
I ended up paying $450 for two tyres fitted (I decided to replace the opposite tyre as well to keep things consistent), which is a lot less than I expected. I told the dealer this (after I had paid for the tyres) and he just shrugged and said some people rip customers off when it comes to run-flats. Interestingly, the owners manual for the F30 says to look out for "RSC" printed on the sidewall of the tyre (which apparently stands for "Runflat System Component") and the tyres I got don't have this. They do say Runflat Tyre on the sidewall, they just don't use the RSC logo. Not sure if it's anything to be concerned about but everything driving-wise with the car seems to be fine now.
Sold: 2012 F30 320d Luxury Last edited by ozorion; 04-28-2013 at 10:15 PM.. |
04-28-2013, 10:06 PM | #9 | |
Rep 72
04-28-2013, 10:16 PM | #10 |
Rep 68
I rechecked the piece of paper they gave me and it was actually 40psi rear, 34psi front.
04-28-2013, 10:17 PM | #11 |
Rep 68
Kumos, I couldn't tell you the exact "model" of the tyre at the moment.
04-29-2013, 04:54 AM | #12 |
On the hunt for PSI
41
Rep 778
out of interest how many k's have you done? I'm surprised that people are already through their first set of rubbers!
2016 Alfa Romeo Guilia Quadrifoglio - Metallic White |
05-07-2013, 09:44 PM | #13 | |
Rep 603
For tyre pressure, I normally aim for 40psi on hot. Depending on your driving the pressures will vary with cold pressures. On the conti runflats I have been doing 38 cold for day to day and 36 for heacy spirited. For light spirited I just leave it on the 38 |
