Need help, finding remote / ignition cable on radio Proffessional
09-10-2007, 03:15 AM | #1 |
Rep 77
Hi,
I´ve search this and other forums over and over again but without result. I wanna know what cable, colourcode or pinout from the stereo that gives +12v on ignition or remote. This shall start up my handsfree unit. Please please give me a advise. Sincerely Marcus Ps my voltmeter is broken and I haven´t found another one around here...:-(
- 335 Coupé - Saphire Black - M Sport Package - 19" M 225 Wheel -
09-10-2007, 09:48 AM | #2 |
Cunning Linguist
147
Rep 2,219
just a suggestion, not really knowing what you are trying to do, but why not run the remote from one of switched fuses. That way it will come on the car comes on.
Bottles are for babies, Real men get blown.
09-10-2007, 11:27 AM | #3 |
Rep 77
I will put in my handsfree unit, and want it to come on and off together with the rest of the car....
Can I use any of the cables for this in the picture above?? //Marcus
09-11-2007, 04:17 AM | #4 |
Rep 77
updated my picture, Anyone wants to comment it? Is it right/wrong?? This can be used for everyone wanting to switch HU in the future...
//Marcus
09-11-2007, 11:22 AM | #5 | |
Rep 48
a little help
to help fill in the chart you made, the red/green is a quasi constant power. it comes on when the car senses the key, but shuts off when the computers shut off, so don't use it for a memory power. The four wires that are Brown/orange are the negitive leads for the audio signal going out of radio. The larger solid brown is Ground to the radio. In the open space you show over the optical outs should be a twisted pair of wires, usually one green and the other yellow, that are the Can-Bus control wires for the steering wheel controls, etc. as far as connecting a hands free kit, use the power and ground located under the center console ashtray/cigarette lighter. if you lift the center trim, the cig lighter unplugs and there are three wires in the plug, green/red is ignition (not accessory ignition) and the brown is ground. the grey red is illumination for the cig lighter trim ring. hope this helped. |
09-11-2007, 11:35 AM | #6 | |
Rep 77
I will use red/green for ignition and then find constant 12v somewhere else... //Marcus
09-11-2007, 03:11 PM | #7 |
Rep 48
still there
the three wires are still there under hte sunglass holder, cause i put it into my friends car while i had the console apart. the cars are all pre-wired with that harness under there.
I wouldn't suggest using the red/green for ignition as it takes 20-30 minutes after you get out of the car for it to shut off, shich means you will have to manually turn off your radio everytime you shut off your car. look under sunglassholder and you should find that three wire harness |
