F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Stock F30 335i Axle Back Exhaust Muffler Modification and Dissection
ARMA SPEED
      03-23-2013, 10:30 AM   #1
Jadar
Dejan
Jadar's Avatar
Serbia
1751
Drives: 2018 Audi S3
Post Stock F30 335i Axle Back Exhaust Muffler Modification and Dissection
BIMMERPOST
     Featured on BIMMERPOST.com
As always, my curiosity gets the best of me. I planned on doing this for some time now, pretty much since I installed my M perfromance axle back.
It goes back to when I saw a few people modifying the e90/92 M3 exhaust by replacing the perforated tubes, and the result was an amazing sound for very few $$$.
The plan was to replace them on the f30 muffler and reinstall it on my 335i and see what the result would be. But due to chamber 1 and the shape of the pipe this seems pretty much out of the question, as there would be way to much custom work and too much labor involved. Im trying to keep this as simple as possible.
So plan B is to open up the muffler all the way, so that I have access to both top and bottom, and spot weld every single hole individually in chamber 1 and 3.
Ill update as I go.
Some videos:
Video by eyim1988
Video by TurboM
FBO-PS1 and stuff
cdwalls700.00
kern4174442.00
N26Ghost496.50
      03-23-2013, 10:51 AM   #2
buildbright
buildbright's Avatar
155
Drives: F80 M3 MG
I have been waiting for this! But this makes me relize the F30 stock muffler is a well designed unit so well I can't believe it. It's so quiet with this design I am a little shocked. But it does have a giant Hemholtz Chamber.
      03-23-2013, 11:17 AM   #3
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
So how are you going to spot weld on the underside?
Wouldn't having a Meineke guy with tubing make a straight through tube design be cheaper? that's essentially what's being done...no?
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray
M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com
      03-23-2013, 11:44 AM   #4
Jadar
Dejan
Jadar's Avatar
Serbia
1751
In chamber 3 yes that would be the way to go, just cut and replace with a tube and weld it back.
The difficult part would be re fabricating the section in chamber 1. It's not round, it's very much oval. Not saying its not possible, but I doubt it be cheaper then just welding each hole.
The underside plan is to open the muffler even further with my angle grinder so I have access to the underside.
I'm not saying this is going to successful but if I close off the perforated tube there will be a change in the exhaust note. I'm not even sure if it will be a good sound, it may be the most annoying thing we ever hear....but we'll all find out soon
FBO-PS1 and stuff
      03-23-2013, 11:50 AM   #5
buildbright
155
Drives: F80 M3 MG
The second chamber you want to keep that is the hemholtz chamber it's what kills drone. Taking out the the 1st and 3rd chamber like you said by welding the holes should work. Nice clean lines that is good angle grinder work.
      03-23-2013, 12:22 PM   #6
Jadar
Dejan
Jadar's Avatar
Serbia
1751
Yes, the 2nd chamber Im not touching. Thanks, it helps when you outline and just cut by following the lines.
If I try to replace the tube in chamber 1 I forsee issues and it wont be cost effective. Its not like in the m3 muffler where they are just 2 straight perforated tubes, you cut replace and weld.
It would pretty much looks like this. Also sorry Im not the greatest with photo shop but its a rough draft of what its suppose to look like.
FBO-PS1 and stuff
      03-23-2013, 03:21 PM   #7
Koer
Drives: F15 X5 2014 Sec. 50i
Wow.. Please do keep us updated on the result!! Im looking to do this same thing with mine!
My main concern is drone, but since chamber 2 is untouched i think the result will be quite satisfactory!
Are the materials you removed only for sound supression?
      03-23-2013, 04:03 PM   #8
buildbright
155
Drives: F80 M3 MG
I think you got the right idea I have done this before. I did it trial and error and actually before I welded the muffler up I used exhaust tape so I could hear how each change sounded. I want to do this with my stock exhaust so I can sell my M Performance.
      03-23-2013, 07:20 PM   #9
Jadar
Dejan
Jadar's Avatar
Serbia
1751
Yes it was just for sound deadening. It felt like a wig lol. Not sure what the material was. I think as for drone there will be some because even my m perf muffler gets a tad bit but only when driving in comfort or Eco when low rpm and all gears are in play. Ill post up as I go, I figure about another a week or so ill have it wrapped up.
You and are thinking alike . I want to see if this works and ill sell my m perf muffler as well. That's a nice move with the muffler tape and testing it. Reading your post and your past experience in doing this really makes me think I'm doing the right thing and it will be a success. Ill defoentely post up pics and sound clips.
FBO-PS1 and stuff
      03-23-2013, 09:05 PM   #10
Turboedv6
Drives: '13 Apline White Sportline 328
Does any one make a muffler delete?
2019 Ibis White/Red S4
1997 Nissan Skyline GTR V-SPEC
      03-23-2013, 09:16 PM   #11
Jadar
Dejan
Jadar's Avatar
Serbia
1751
Not a specific manufacturer that I know of, but I have seen a couple of people custom fabricate their own exhaust with a muffler delete. Sounded pretty good actually. There are some threads I'm here about it you'll have to search it.
FBO-PS1 and stuff
      03-23-2013, 09:17 PM   #12
Turboedv6
I fabricated my own muffler delete, I am surprised a company has not started to make one yet.
      03-23-2013, 10:24 PM   #13
buildbright
155
Drives: F80 M3 MG
Yes I agree I was trying to buy an extra stock exhaust because I was worried the stock muffler would be a mess but now I am going to my exhaust guy next week. Thanks for being fearless and inspiring me. Now you got me to wonder what the M Performance muffler looks like. I guess great minds think alike lol
      03-24-2013, 11:10 AM   #14
Jadar
Dejan
Jadar's Avatar
Serbia
1751
Indeed great minds think alike . I'm curious about the m muffler as well but I'm not sure if want to cut into it, it may turn away a potential buyer if I go to sell it.
FBO-PS1 and stuff
      03-27-2013, 02:11 PM   #15
MMOTION
MMOTION's Avatar
109
Drives: like you'll never drive again
Sorry to bring this off topic, but what is that black module attached to the drivers side exhaust pipe?
      03-27-2013, 02:59 PM   #16
Jadar
Dejan
Jadar's Avatar
Serbia
1751
That is the actuator that opens and closes the butterfly valve.
FBO-PS1 and stuff
      04-13-2013, 04:14 PM   #17
utenigma
Drives: 2013 F30 335i 8SA M-Adaptive
Really interesting, were you able to complete and test?
      04-13-2013, 06:32 PM   #18
Jadar
Dejan
Jadar's Avatar
Serbia
1751
It's out in a shop getting welded. My friends dad is doing it he said the inside pipe will be very easy to weld since its steel. The canister is aluminum and is a PITA to weld aluminum so he quoted $200 for the gas used and his labor.
If its successful (I believe it will be) it will be a well worth $200 mod, as opposed to spending a grand on the m performance axle back.
If unsuccessful in what I'm trying to achieve, we'll I threw away $200 on an experiment and you guys got to see the interior of the muffler
Stay tuned
FBO-PS1 and stuff
      04-13-2013, 09:06 PM   #19
PaulBailey@ltbmw
PaulBailey@ltbmw's Avatar
Italy
662
Drives: 2-325 330 2-335 2-Z4 2-135 X5d
Very interested!
Can't wait to see the results.
      04-14-2013, 08:52 PM   #20
RPM90
Drives: 340i M-sport AT
Stay tuned
Just removing the damping material will change the sound, making it louder and perhaps even a bit deeper.
If you consider that low frequencies are also longer waves, then allowing that wave to travel through to the outlet without being broken up will result in a deeper sound. Long waves can also bend around corners like through the tubing. That's why in a house we can still hear the bass coming from the stereo even if we're in another room down the hall.
Your idea to close off those holes is a "sound" idea, as those holes are where the longer sound wave is being broken up.
That additional damping material further absorbs the broken wave energy to keep things quieter.
I think you're going to get a much louder and deeper tone, but will it sound pleasant? THAT is THE question.
If it does sound good I'll be surprised considering that manufacturers spend time tuning mufflers and exhausts systems not just for flow but sound quality. It'll be a very happy surprise if the louder sound is also a pleasant one. You may find that only closing half or one side of the holes will yield a better tone.
Maybe you should have done only one side at a time.
That way you would know if you're on the right track.
But, too late now. If the sound is ugly you could then try drilling some holes back in.
I had a Yamaha V-twin a few years back with a very anemic and very quiet exhaust due to the same type of design as our stock mufflers. People experimented and came up with some ideas. I used the recommendations and did the drilling. Yes, the sound was louder and deeper, but the quality of the sound sucked.
So, I opted for a set of low cost slip on mufflers made by Jardine. The result was louder, deeper, but a much better and mellower sound quality.
The best experimental experience I had was with my former Honda VFR750.
It's a V-4 engine. I had a nice though quiet Yoshimura slip on muffler.
One day I took off the slip on and fired up the V-4. WOW, man that engine had a cool sound and with just the headers the sound was glorious. But now way I could ride it around, it was just too freaking loud.
I've loved the sound of V4 engines ever since. Too bad they're not common. I'd love an auto maker to make a V4 for a car. That configuration yields great torque, and what a sound, think 2 V-Twins beating against each other.
I digress, sorry.
I want to hear your frankenmuff experiment. Let me know when it's done and I can come out and take a listen.
PM or email me.
      04-14-2013, 09:18 PM   #21
Jadar
Dejan
Jadar's Avatar
Serbia
1751
I digress, sorry.
PM or email me.
Yeah it may indeed sound like crap. We shall find out soon. Im leaving the packing material in there, i think it will help with droning. Not sure if just want to do one side welding, and if there is little or no change because the sound is still escaping Ill be pissed lol. To reopen and reweld the muffler again will just be to costly to make the project worth wile and to proceed would just be throwing another $100-$200 to reweld the canister.
Im gonna pray that is sounds good, as I got my idea form an E92 M3 project I saw on youtube. The cut and replaced the perforated pipes instead of just welding the holes up, but those pipes were perfectly straight and easy to cut and weld. The F30 interor piping is curved and oval so to speak. Finding another pipe like that is a long shot and a waste of time and cash.
As soon as Im done Ill throw up a video. And youre more then welcome to check it out in person if it sounds good. Even if it sounds like crap Ill still post up the vids just to show you guys.
FBO-PS1 and stuff
      04-14-2013, 11:07 PM   #22
buildbright
155
Drives: F80 M3 MG
It should like a muffler delete which sounds pretty good on our cars.
f30post
