F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > F30 Owners: Want an Front Mount Intercooler that flows better? Help us out!
Extreme Powerhouse
      02-25-2013, 06:12 PM   #1
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
I used ETS intercoolers in my previous ride, I wanted to see if there was anyone in the Washington state area that could be a donor car to see if this E-body style intercooler will need some modifications:
I live in CT, so it'll be difficult for me, otherwise I would do it in a heartbeat.
I gained about 15-20whp when running higher boost with an upgraded intercooler, and obviously won't void your warranty.
Previous E-series had the following pluses:
Here's their info, please help the community out!
12613 NE 95th St
Vancouver, WA 98682
Phone: 360-896-3000
Fax: 360-896-3100
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray
M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com
      02-25-2013, 06:14 PM   #2
tdizzle
Drives: 2017 F80 ZCP
12613 NE 95th St
Vancouver, WA 98682
Phone: 360-896-3000
Fax: 360-896-3100
Wish I could help you out, but alas I'm in the TN/MS area so no dice.
I'm not expert on intercoolers, but how exactly does it provide a gain in hp? I thought it was more of a mod that helped the engine perform at peak longer more than a straight power gain. /noob
      02-25-2013, 06:17 PM   #3
shivaswrath
Drives: 2012 335i
With increased boost, which all of us with a tune will run, there will be increased heat.
So comparing stock versus a nice bar and plate design will flow better and cool more effectively=more hp!
Here's a dyno they did on an N54 engine before and after a 5" IC:
Of course, there was a tune and other goodies involved...
-Shiv
      02-25-2013, 07:39 PM   #4
buildbright
buildbright's Avatar
155
Drives: F80 M3 MG
Terry from BMS only saw 8hp increase At low boost and only 1 hp with high boost. This is with Meth. If you plan on using meth it cancels itself out with a stock N55 turbo.
      02-26-2013, 07:53 AM   #5
shivaswrath
Drives: 2012 335i
Well, regardless of gains, the more aggressive a tune you get (unsure if we can use a Procede for our system?), the better the flow one will need.
Anyone in Washington able to loan a car?
      02-26-2013, 09:44 AM   #6
MiladsFrozenM5
M5, 335i, Maserati gts, Audi A8L, CLS 63
MiladsFrozenM5's Avatar
49
Drives: m5
Why wouldn't it ruin your warranty ???! It's an aftermarket part?
      02-26-2013, 12:02 PM   #7
buildbright
155
Drives: F80 M3 MG
That was with the BMS Flash. You have to change your turbo to really see a difference. It's on N54 tech. Now this is if you use meth. In a non meth car it will be more helpful.
      02-26-2013, 12:24 PM   #8
Jamesons Viggen
Drives: '98 M Roadster stg 2+ S/C
N20 and n55 might both use the same after market intercoolers. That can be confirmed by the board vendor who was fitting to both f30s.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      02-26-2013, 04:58 PM   #9
shivaswrath
Drives: 2012 335i
I think they're the same IC's, the UICP and LICP are different between the two, obviously, but it does seem as though the end tank inlets and outlets are the same.
Jameson, could you see if anyone on the N20 might be interested to? If we drum up enough interest, might help the cause...
      02-26-2013, 05:00 PM   #10
shivaswrath
Drives: 2012 335i
I'm not running with meth, just want cooler intake temp's.
It's physics really, Sean Ivey didn't believe I'd be able to squeeze extra hp when I added an IC either, but was pleasantly surprised.
I know the tunes are less aggressive in the BMW world, and the lack of a MBC doesn't help the cause, but I'm positive the current design and flow isn't that great...
      02-26-2013, 05:50 PM   #11
slmdgee
Usofstance
Drives: 328I 6SPD
I would be down but not this moment.
2013 328i 6MT Bagged
IG Stu_UnitedStatesOfStance
United States Of Stance
      02-26-2013, 07:58 PM   #12
justinnum1
Drives: 2018 330i Msport 6mt
what does it mean to run with meth?
F30 330i Alpine white/Coral red Msport 6MT
      02-26-2013, 09:10 PM   #13
shivaswrath
Drives: 2012 335i
methanol injected into your intake manifold to lower your intake temp and allow you to alter timing and adjust your AF's for more power...highly fun.
      02-26-2013, 10:25 PM   #14
buildbright
155
Drives: F80 M3 MG
I could not have said it better myself
      02-26-2013, 11:21 PM   #15
justinnum1
so it gives you more power? how much is it and can you just add it to a totally stock car?
      02-27-2013, 01:07 AM   #16
nsquared
[Versatile]
nsquared's Avatar
378
Drives: (S)LOW.
Would be down for a more efficient intercooler. Hopefully adds more top end hp.
'02 TS E46 330xi - SOLD
'06 SGM E90 325i - SOLD
'13 AW F30 335i ///M-Sport 6MT. OEM(+) - SOLD
'20 AW F87 X3MC - Sold
Current: `23 Chalk G80 M3CX | Ordered: '24 M3CS - Week37 build.
      02-27-2013, 09:55 AM   #17
shivaswrath
Drives: 2012 335i
you would need:
1. methanol tank
2. lines to the tank
3. a tune
4. nozzles connected to #2 that are bored into the intake manifold that will spray based on the tune.
it's complex, will void the living hell out of your warranty, but highly effective in reducing intake charge temp's and thus allowing you to reap full benefits of your N55 turbo...
      02-27-2013, 02:03 PM   #18
TreDirtyFive
Drives: X3 M40i
So far, it doesn't seem the N55 small turbo flows enough to really take advantage of an aftermarket IC setup the way it does on other cars such as the Evo...Yes, it will help keep heat soak down over general driving periods but you won't see the numbers the N54 is making with an IC it seems.
Here is a link to a test on an N55...although this is with meth it helps keep things into perspective.
http://www.n54tech.com/forums/showth...55+intercooler
X3 M40i G01, M235i F22, 335 F30 MSport, 135 DCT, 335 E92, Audi A3
      02-27-2013, 03:16 PM   #19
shivaswrath
Drives: 2012 335i
I think it's probably a function of the tune and stock boost rather than turbo size.
I have to get the vane sizes, but the Mitsu turbo specs are:
Turbo = TD05HR-16G6-9.8T (GSR / USDM)
TD05HRA-16G6-9.8T (RS/RS2 & NZDM) or 6MT:TD05HRA-16G6-10.5T (model unknown)
Nozzle Area (cm2) = 9.8
Turbine = USDM EVO 8 & JDM GSR =Inconel (steel alloy),
Compressor = Aluminium, 68mm wide
Flow rates//Max Output:
TDO5H-16G-7CM2 505 CFM
TDO5H-16G-10CM2 505 CFM
TD05-16G (small) 345-365hp @ 22 psi
TD06-16G (large) 365-385hp @ 22 psi
N55 turbo information (I could find, since I'm new to the platform):
53mm Inducer and 46.1mm Exducer
A borgwarner b03 is all I could find...they are so tightlipped...
Judging from the sizing, the Mitsu turbo is jesus larger... 98/68 verus 53/46.
That's why we are such low end torque monsters, and honestly you probably don't want too large of a turbo on an inline-6...HOWEVER, with that said (and little information I have on the N55 b03), I would imagine if we increase the flow, the heat would increase, and an efficient IC would be good.
      02-27-2013, 04:32 PM   #20
buildbright
155
Drives: F80 M3 MG
The power increase on a stock car will be minimal, but will keep the intake air temperatures down. Meth kits are around $200 to $450 but you need a failsafe and will have to tune it. I recommend a piggyback like BMS which has a failsafe built in and they have a kit for $370 that bolts on and comes off in 10 minutes with no warranty issues. Not to mention the power is awesome and safe for the engine.
An intercooler will run you around a $1000. But it can be run a stock car but will be hard to remove before service and BMW will most likely void your warranty if they see it.
We use to build turbo cars without intercoolers and just use meth. That way you reduce the flow restriction and would get great power on low boost. Its actually old technology but since turbos were not popular in the 90’s and early 2000’s people didn’t use them a lot. It started becoming popular with the turbo craze.
      02-28-2013, 09:08 AM   #21
TurboBullett@Ambient Thermal Management
TurboBullett@Ambient Thermal Management's Avatar
80
Drives: 2012 Abarth 500
FYI Our design and prototype phase is complete and we are going to production of our final design for testing. Keep your eyes peeled on this site for the data!
      02-28-2013, 11:20 AM   #22
RoundelM3
RoundelM3's Avatar
Drives: 15 F80 M3, 22 G01 X3 30i
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
Definitely want to get a better intercooler for the F30 (currently on its way from the port); I had ETS 5" on my E92 and really liked it. Anxiously awaiting the F30-specific product!
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey
f30post
