02-07-2013, 09:59 PM | #2 |
Rep 3,288
Drives: anything given a chance
what other petrol fuelled, turbo charged cars have you driven?
the N20 and N54/55 are a delight compared to at least three other engines I can recall driving. I have a suspicion you're mistaking turbo lag for your transmission adjusting to deal with your foot stomping on the loud pedal. try going to 1st in manual gear selection mode and tell me if you still experience lag. I believe you'll experience the traction control light flashing instead. |
02-07-2013, 10:48 PM | #6 |
Rep 960
02-07-2013, 10:56 PM | #7 |
Rep 3,566
Drives: F30 M-Sport 328i Estoril Blue
8AT?
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
02-07-2013, 11:14 PM | #8 |
Feeling horny
36
Rep 152
yeap. i drive a 8AT. after driving my mates f30 335 (also 8AT) for 2 days i hate going back to my 328 now.
not because of power,it's the initial reaction when i put my foot down. It's all got down to smaller engine, smaller torque and higher psi and lower compression then 335 i guess.
BMW F30 328i Sport Line
02-07-2013, 11:23 PM | #9 | |
Rep 3,566
I will replicate it on my car and report back with my experiences. Of course, no matter how the 328i fanboys spin it, the 335i is a more powerful & more responsive car. Is your mate's car an 8AT as well?
02-07-2013, 11:47 PM | #11 |
Rep 603
its the 4cyl 2.0L engine. Try feeding the fuel into the engine then push the hard. By just thumping the pedal, you are flooding the engine (happens to small engines). Adapt is my only advice
02-08-2013, 01:17 AM | #12 | ||
Feeling horny
36
Rep 152
im not talking about acceleration feeling. taking off from the lights with say 70% and above throttle there is this delay before there's any turbo response. I did exactly same thing in the 335. no delay at all, if not very minimal.
02-08-2013, 04:21 AM | #14 |
Feeling horny
36
Rep 152
And I don't think this is because of the torque converter shutting down after 2 sec. Didn't feel that on 335.
I think it applies on all driving mode except sport and sport plus is way better due to sharper throttle body response but turbo response remains the same or little bit better due to The better air flow from Tb.
02-08-2013, 04:28 AM | #15 |
Rep 1,549
Thats what I thought, But would a bigger engines like the M's cater for the larger fuel intake
02-08-2013, 05:23 AM | #16 | |
Rep 3,566
Don't forget, these are subdued throttle response settings. Of course it won't be the same as the 335i. On my way home tonight, I tried some brief in gear tests in comfort and I got an immediate response. I also got a quicker one in DS and a much quicker one in sport mode. I will try from standing start, but I expect different response from different settings. Going back to your original post, if you have a clear and definitive 2 second delay, then your car may have a software or turbo issue. Your thread takes me back to late last year, when I drove a 320d over a few hours. I posted that it had a clear and definitive turbo lag, especially from standing start, but more recently I drove a 118d, which had instant power & torque, without ANY turbo lag. So, if you have an issue, which is replicated each and every time you take off in a moderate to spirited manner from standstill, take your car back to the dealer for analysis. At the same time test drive at least one other 328i, but don't compare it with the 335i for any performance comparisons. As you know, it will end in 'tears'.
02-08-2013, 05:28 AM | #17 | |
Rep 43
I have the same feeling in my car as well. Sport and sport+ are fine but there is definitely lag or a pause in comfort. I got them to check it when it was in for other work and they said it was normal. Sometimes it is fine and takes off normally and then other times it feels like it's dead and nothing happens. It can happen on low throttle starts or when putting the foot down. A 328i loaner had lag as well, although a 320d was fine. |
02-08-2013, 05:42 AM | #18 |
Rep 238
Coming from an X1 s20d I thought the turbo lag was minimal and linearity much superior. Comfort has a soft response to throttle but I don't think it is nearly as bad as what was described in the opening post.
To be honest I think there is too much of a gap between Comfort and Sport. People talk about turbo lag. The NA engine in the E90 323i or 325i had no lag but not nearly as much shove either in low to mid range. Comparing to the 335i is just pointless given the capacity, power and torque difference. |
02-08-2013, 06:52 AM | #19 |
Feeling horny
36
Rep 152
My car has no mechanism issues, it's normal. 2 sec is a bit exaggerating, more like 1 sec.
I don't think I'm unfairly comparing 328 to 335 as the response feel I am hoping for shouldn't require an extra 1000cc and 50nm more of torque. Car doesn't need 100% full use of it power and torque to take of with 70% throttle. Anyone still don't know what I'm saying get urself a 335 and drive it 2-3 days straight and u'll know what I'm talking about.
02-08-2013, 07:12 AM | #20 |
Rep 238
The F30 328i comes with a 2 litre turbocharged engine. Without the turbo it wouldn't have been much better than the anemic E90 320i. Let's say the E90 320i gets to 100km/h in 9s. So for the sake of this comparison let's say the turbo knocks 3 seconds off.
What would the F30 335i be without the turbo? Like a E90 330i? Which is what? 6.3s to 100? So the turbo knocks 0.8 seconds off. My point is that the 328i depends a lot more on the turbo for its performance than the 335i. That should be quite clear. The extra 1000cc is like 50% more in capacity. You know what capacity a NA engine with the response you are hoping for would need to produce 350 Nm of torque? Roughly 3.5 litre. Or a much more lightly turbocharged 3 litre engine. |
02-08-2013, 07:20 AM | #21 | |
Feeling horny
36
Rep 152
02-08-2013, 03:25 PM | #22 |
Rep 238
So you were complaining about what exactly? That BMW should rewrite the law of physics?
Just enjoy your car mate. It is a great car. The N20 is always going to come up short against the N55 but the 335i another 30k more which quite frankly is ridiculous pricing for a 3 that is not an M. Last edited by jctg; 02-08-2013 at 03:30 PM.. |
