V1 Hardwire Question
08-12-2007, 06:10 PM | #1 |
Rep 5,623
i am in the process of doing a v1 hardwire but i don't know which to do. either go through the fuse box or the headlight unit above on the roof. which is easier as i can't tell from the pictures here, http://www.e90post.com/forums/showpo...2&postcount=29.
also looking at this diy, http://www.e90post.com/forums/showth...hardwire+block, what is the v1 hardwire block? i don't seem to have this. |
08-12-2007, 06:56 PM | #2 |
Free Your Heel
10
Rep 309
I'd go through the fuse box, but then I've never tried it through the roof.
As far as the "hardwire block," maybe you're referring to the "Direct wire power adapter" (part #20305) at https://store.valentine1.com/store/d...gory=partsdept This should have come with your V1. This is the part you use to tie into the "Add a circuit." I'd suggest reading the entire thread in your second link...including my post which is at the end It's not that hard and you're unlikely to screw up anything expensive.
2007 E90 335xi || Sparkling Graphite || Terra || Burl || 6MT || Premium || Sport || Cold Weather || Sirius || Comfort Access
ED May 2007 Report |
08-12-2007, 11:38 PM | #5 |
Rep 548
I went in through the light unit, and it took less than 5 minutes to install. I had absolutely no issues, and it works and looks awesome.
08-13-2007, 02:44 PM | #6 |
Rep 5,623
08-13-2007, 06:26 PM | #7 |
Rep 201
Yes, they do exchange all models. The older the model, the less they will give you towards a new one though. It's still a great deal.
Bob ///Margolis
2013 335i xDrive – 6-speed, AW, M Sport Line, Cold Weather, Dymanic Handling, Premium, Technology, 403M, Black Grills, Carbon Caps, Performance Exhaust |
08-28-2007, 11:25 PM | #10 |
Rep 5,623
i am in the process of hardwiring my v1 but stumbled into a problem. been using this post for refrence. http://www.e90post.com/forums/showth...ight=valentine
i bought a "add a circuit" from autozone and plugged a fuse from the v1 box (gray) and inserted the fuse that was taking up the slot into the 2nd slot on the "add a circuit block" so now i got two fuses on this block which i inserted into 1 fuse slot on the fuse circuit board. now the blue clamp adapter thing from the v1 box, i take that cut the skin off the fuse tap wire and insert the rare metal into the clamp? lastly has anyone found other ground method besides drilling a hole in the metal pillar? |
08-29-2007, 08:22 AM | #11 | |
Rep 892
Yes, you have to cut that portion off and put it into the adaptor on the V1 cord. I didn't drill a hole in the pillar, I used that hex screw and just loosened it up and grounded it there, worked like a charm. I think there are some pictures in that other thread of what I'm talking about. I used that as a guide installing mine, it never mentioned anything about cutting the wire, I just kind of figured that was the only way to do it. |
08-29-2007, 09:13 AM | #12 | |
Rep 6,664
As for the blue clamp, you do not need to strip any insulation from the wires. Put the two wires into the blue housing, put the metal piece in/close the thing. Squeeze with pliers. The metal will slice through the wire insulation enough to make solid contact to the wires.. Hope this helps some, Josh
E90 325XI, MYSTIC BLUE ON BLACK/ALUM, STEP, NAV, PDC, CWP, XENON, SIRIUS, ALARM, MUD GUARDS, CLEARBRA, CHROME GRILLS AND TIPS, VALENTINE 1 (HARDWIRED), HO CERAMIC 40%, 161'S, REAR FOG MOD, LUX 4.0, BLACKLINES, OEM PEDALS, MTEC FOGS, GRUPPE-M REP INTAKE. 156'S AND RUBBER MATS FOR THE WINTER. |
09-04-2007, 10:08 PM | #14 |
Rep 48
If any one is concerned about tapping into a fuse in the fuse box, i have found another way that is a little more work, but much safer since it uses the wiring for the factory cigarette lighter. If you pop up the trim piece in the center console around the shifter, you can unplug the cigarette lighter and place the trim in a safe place, so as to not scratch it. The cigarette lighter has three wires running to it in the plug you just disconneted that is still in the center console. the Green w/Red stripe is the ignition power, the Brown is Ground, and the Grey w/Red stripe is the illumination wire for the lighter trim. wires can easily be run from this location in the center console to the back of the glove box where it can be continued up to the A-pillar like the other threads.
Only word of caution I would give anyone running a wire from a rearview mirror location down to the glove box is to make sure that as you cross the A-Pillar to go down to the glove box, make sure you that the wire goes behind the airbag that is running down the a-pillar. it is not easily possible to do this, without lots of practice, if you don't remove the a-pillar trim piece. this trim is a T-20 Torx scres behind the little cover piece that says Airbag, and then two pop clips. removing this piece is fairly straight forward and easy, but getting it back in can be frustrating at times trying to line up the bottum a;ignment tabs and the two pop clips on the side, but with patience it makes for a much safer install. hope this helps, InstallMD |
09-05-2007, 01:27 PM | #15 | |
Rep 548
Here's the details from the DIY I used; this literally took 5 minutes. Use the Green/white wire in the wire bundle as the hot. Link |
