Sirius Radio Intermitant
08-11-2007, 01:40 PM | #1 |
Rep 361
I have a 2007 335i E90 with the factory option Sat. radio. This is my first experience w/ Sat. radio. Every so often when I either turn the car on and the Sat. radio is on or turn from the tuner to Sat. none of the pre-programmed channels will come in. All the channels will go to Hits 1/ Channel 001. The reception quality is good. At times I can turn off the radio and then try again a while later and will will be fine and the programmed channels will come back. Sometimes it does not work. Is this normal? If not, is there a fix?
08-11-2007, 10:10 PM | #2 |
Free Your Heel
10
Rep 309
Odd. Do you have comfort access? If so, are both fobs in the car when this happens? I'm wondering if it's flipping over to the preset stations of the other fob, which if they haven't been set, seem to default to Hits 1 (god forbid).
2007 E90 335xi || Sparkling Graphite || Terra || Burl || 6MT || Premium || Sport || Cold Weather || Sirius || Comfort Access
ED May 2007 Report |
08-12-2007, 06:57 PM | #4 |
Free Your Heel
10
Rep 309
I'd take it to the dealer.
08-13-2007, 06:25 AM | #5 |
Rep 12,276
Unless you are alternating key fobs, take it in for a look by the dealer.
I think it is bad luck to be superstitious |
10-03-2007, 07:19 PM | #6 | |
Rep 64
Current: 2009 BMW 328i (e92) M-Sport - PCD on July 22, 2009
Former: 2006 BMW 330i (e90)- PCD on August 25, 2006: http://www.bimmerfest.com/forums/sho...d.php?t=162751 |
10-03-2007, 08:58 PM | #7 |
Rep 374
Drives: '05 645Ci Coupe
Just saw this thread. Did it get fixed and was it this issue:
SI B 65 07 07 Sound System, Cruise, Alarms, Monitors April 2007 Technical Service SUBJECT SDARS SIRIUS Radio is Intermittently Inoperative MODEL E90, E91 *(3 Series) E92, E93 *(3 Series Coupe/Convertible) E60, E61 *(5 Series) E63, E64 *(6 Series) *Only with option 655 (SDARS Satellite Radio) SITUATION When the SIRIUS Satellite radio is intermittently inoperative, the following can occur: The SIRIUS radio preset list is empty "Call SIRIUS" is displayed to subscribe CAUSE Incorrect hardware and software in the SDARS Satellite module, GEN2.5 (Generation 2.5) CORRECTION Try to reproduce the complaint, when possible with the customer. If it can be reproduced, immediately call SIRIUS to verify that the subscription is not deleted or outdated. When the subscription is verified and the module can be recognized by SIRIUS, remove the SDARS module and check the part number on the module. When P/N 65 12 6 987 545 is installed, create a PuMA Case for parts replacement authorization and include the following information: Part number of the SDARS module Hardware number Software number ESN number Install an improved SDARS module and program the vehicle with Progman V25.01 or higher per SI B09 05 01 (Coding, Individualization, Programming), Procedure A. Important: Complete vehicle encoding has to be done as outlined in the procedure! PARTS INFORMATION Part Number...........................Description...... .............. Quantity 65 20 9 142 850.......... SDARS Satellite module GEN2.5....... 1 WARRANTY INFORMATION Covered under the terms of the BMW New Vehicle Limited Warranty. |
10-04-2007, 02:15 AM | #9 |
Rep 959
I had the above problems, and the software update (mostly) fixed it for me.
Used to be sometimes I'd get no satellite radio until I'd parked the car for a while and restarted it, now if sirius doesn't work immediately, it will come on within about 30 seconds of starting the car, or immediately if i switch to the tuner and back. A big improvement from when it occasionally would just not work for a specific car trip.
330xi SG/Terra/Burl -- ZPP, ZSP, ZCW, CA, Sirius, PDC |
10-04-2007, 07:27 PM | #10 | |
Rep 64
10-10-2007, 10:34 PM | #11 | |
Rep 45
