Requesting: AG M359 On Stock Suspension
09-06-2012, 11:25 PM | #1 |
Rep 460
Hi,
I am wondering does anyone have a picture of the Avant Garde M359 F:19X9ET35 R:19X9ET38 on stock suspension? I would like to keep my stock suspension while rocking those wheels. Will you know what tire size i should get so that it will not rub. I would like to go the widest tires that I can get. Thank you. |
09-07-2012, 12:10 AM | #3 |
Major Pain
164
Rep 1,260
not on stock suspension, but here take a look through the pages, youll find some pictues.
http://www.e90post.com/forums/showthread.php?t=728102 I run F: 19x8.5 235/35/19 et25 R: 19x9.5 265/30/19 et21 no fender work, no rubbing. If youre not lowered you can go easily go wider if you want
09-07-2012, 01:52 AM | #4 |
Where'd my VTEC go?
481
Rep 6,067
why would you run a weaker offset rear than front?
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
09-07-2012, 09:20 AM | #5 | |
Rep 460
Also, I would like to know why the rear offset is less than the front as well. Thanks everyone. |
09-07-2012, 09:39 AM | #6 |
Rep 10,603
I'm a vert on stock sport suspension. I think perches up front and a 10mm rear spacer will be perfect. I'm not looking to lower with springs. Sport is good enough with me.
09-07-2012, 11:02 AM | #8 | |
Rep 10,603
Fronts are 19x9.0 ET35 with a 235/35/19 Continental DW Rears are 19x10 ET38 with a 265/30/19 Continental DW Debating to get 275 in the rear or some spacers, I have a little bit of room to work with. Front sits pretty flush, any spacer would have it outside the fender. |
09-07-2012, 11:36 AM | #10 |
Rep 10,603
I really don't know anything about the offsets and clearances on the sport suspension. You could definitely have a more aggressive offset in the rear compared to mine though. The front is perfect IMO.
09-07-2012, 12:46 PM | #11 | |
Rep 1,016
Crimson Red e92 335i - H&R Premium Performance Coilovers, 19" AG m359's, Cobb AP, BMS DCI, AA CP/BOV, OEM Gloss Black Grills, M3 sideskirts
09-07-2012, 01:56 PM | #12 |
Rep 1,731
I'll take some pics today, but it pretty much looks the same as the vert
Yeah there's a bit tucking, but i can barely get two fingers (gap) and I got non-sausage fingers. EDIT- F 19x9 ET 35, 245/35/19 DWS, R 19x10 ET 38, 275/30/19 DWS. No rub. Unless I got passengers (4) in the car and I go over a bridge bump there's a slight rubbing in the rear. The sticker "No Fat Chicks" is going up ASAP. Note: I do have the Pre-LCI E90 so I have the most leeway in terms of 'space' hence the 245 tire fits perfect. Next set I may opt to down down to 235....maybe. I want to fit a 285 or 295 tire in the rear though because of my turbo upgrade >:] |
09-08-2012, 11:05 AM | #14 | ||
Rep 460
Thanks everyone for replying! |
09-08-2012, 05:11 PM | #15 |
Where'd my VTEC go?
481
Rep 6,067
you have it backwards. lower positive offset = more flush. higher positive offset = more tucked
09-09-2012, 09:16 AM | #16 |
Major Pain
164
Rep 1,260
whatever, my wheels are flush. And if your saying a lower positive = more flush, than my rear would be more flush
09-09-2012, 08:23 PM | #17 |
Where'd my VTEC go?
481
Rep 6,067
did you mean 19x10 +38 in your original post? that would make more sense. AG doesnt even make 19x9 +38.
03-20-2013, 03:19 PM | #18 |
Rep 496
I understand this is an old thread, but I have a 2007 BMW 335i. I really want the m359 wheels in matte black for my car but don't want to rub.
As for the whole spacer thing I'm not sure I have never ran them on any car I have ever owned. This is my first BMW so my apologies. My car is at stock height and most likely will never be dropped. I never have 4 people in my car and want to run DWS in the 235/35 and the 265/30 set up. Will I be ok without rolling fenders |
03-20-2013, 05:19 PM | #19 | |
7456
Rep 10,259
03-20-2013, 07:28 PM | #20 |
Rep 496
I'm not going to drop it and I won't adjust my suspension at all so I am just worried ill hit a bump in MI I don't wanna bottom out.
I also want to run 275 30 so Idk
07 BMW 335i (East Lansing, MI)
Winter / Sport / Premium Packages Installed |
03-21-2013, 10:20 AM | #21 |
Rep 333
Drives: 2012 E92 328i
What's the link? I'm curious to see how those wheels look on stock suspensions.
2012 E92 328xi | KW V1 | AG M359 | BMW Performance Exhaust | M-Sport |
03-21-2013, 02:21 PM | #22 | |
Rep 2,711
This is all I really have of my car with those wheels. I've been under the weather for the past week but once I get better ill take my camera out and take some pics and update this thread |
