F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > HK Sound System: Suggestion for Improvement
proTUNING Freaks
      09-06-2012, 08:55 AM   #1
shoptb
shoptb's Avatar
Drives: '19 G01 X3 m40i
Cool HK Sound System: Suggestion for Improvement
Maybe I'm the only one that has noticed this, but wouldn't it be nice if the HK Sound System allowed for "easy switching" to preset sound profiles on the equalizer (like Jazz, Deep, Vocal, etc)? Some songs sound a lot better with different settings than others, and it's a pain in the a$$ to go into the equalizer and manually adjust each band for every song. Even the 2008 Chevy Cobalt had this feature...c'mon BMW!
Delivered --> '21 G01 X3 M40i, 8SA, Sunstone Metallic with Cognac Vernasca, 22Z, ZDA, ZDB, ZPK, ZPP w/ 4HA, ZPX, 2VF, 3AC, 4K1, 688, 6NW, 5DF
Past --> ?19 G01 X3 m40i, 15 F33 328xi, 8SA, '13 F30 328i, '08 E92 335xi, '95 E34 530i, '88 E30 M3
      09-06-2012, 09:05 AM   #2
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
Yes, I would like something like that to. Now it feels like I have to adjust it for each song I listen to. Maybe this is because I just got the car, but if feels like I have to make small adjustments all the time.
Is there a thread where people list their equalizer settings somewhere around here?
I know that E90Post had this, and it was a big help when someone with the right equipent did a calibration. I know it's not one setting fits all, but it was a great starting point.
      09-06-2012, 09:25 AM   #3
shoptb
shoptb's Avatar
I agree; I've looked for the same thing on F30Post, and come up with nothing. Anybody know?
      09-06-2012, 09:38 AM   #4
justinnum1
Drives: 2018 330i Msport 6mt
not possible, maybe you can use one of the presets, but i doubt it.
i always listen to edm so i never really thought of this, older bmw's had it
F30 330i Alpine white/Coral red Msport 6MT
      09-06-2012, 10:09 AM   #5
Robin_NL
S0THPAW
Robin_NL's Avatar
8717
Drives: HS M2 Competition
I even UNclicked L7. Many songs sound better then.
The reception/sound of the radiostations is 9/10 times just poor for such an expensive system.
The songs on my iPhone via the HK system sound 100% better it seems(Thank God). Strange.
Cheers
Robin
      09-06-2012, 10:14 AM   #6
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
Higher bitrate I guess. I don't own a single MP3 or song in iTunes. Every song I play is from Spotify. So it makes it not so ideal to use the media section in the F30. Everything is prepared to be used with iTunes or MP3 on the harddrive.
I can stream the audio with bluetooth, but that kills the battery in 2h. And if i plug it in with the USB-cable is have to kill bluetooth audio. The sound still plays fine, but the controls doesn't work (to change songs) and no info about artist, album, song title anymore.
I need a Spotify app!
      09-06-2012, 10:15 AM   #7
justinnum1
it's all about the source
^there is an iphone app for spotify
      09-06-2012, 10:29 AM   #8
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
I know, I use it all the time. It was the one I used in my post above. What I meant was an BMW App (made with the SDK), like Pandora. So that I can get full control with the iDrive instead of just BT-streaming.
      09-06-2012, 10:36 AM   #9
shoptb
shoptb's Avatar
Maybe I need to mess with the EQ on the iPhone under the Music section of settings. However, I was always under the impression that you should leave this to 'Off' when playing music through the iDrive.
      09-06-2012, 10:49 AM   #10
justinnum1
ahhh, i see
      09-06-2012, 10:52 AM   #11
dave-the-rave
dave-the-rave's Avatar
Drives: M135i
I always leave my EQs flat - I can't stand artificially increased EQ's. A good audio source always helps aswell - if you're using mp3 or m4a's, they are lossy and one of the first things they do is cut the very top and very bottom ends off the waveforms as most people can't hear the difference. That's why CD's or lossless always seems be to more "punchy".
Lossless for me all the way
      09-06-2012, 11:13 AM   #12
shoptb
shoptb's Avatar
Originally Posted by dave-the-rave View Post
I always leave my EQs flat - I can't stand artificially increased EQ's. A good audio source always helps aswell - if you're using mp3 or m4a's, they are lossless and one of the first things they do is cut the very top and very bottom ends off the waveforms as most people can't hear the difference. That's why CD's or lossless always seems be to more "punchy".
That's good information. However, my main concern with this is that my sound was a lot better with my E92 HK than I've had so far in my F30 HK using the same iPhone (MP3/M4A). The bass is crazy overkill, while the middles are lacking a bit. Guess I need to play around with it more.
      09-06-2012, 11:43 AM   #13
dave-the-rave
Drives: M135i
I've just got the alpine kit in my E90 at the mo - how much better is the F30 H/K from that ? Thinking of getting it when i order my f30 in a few months
      09-06-2012, 12:49 PM   #14
Micleg
iX1 2022
35
Drives: iX1 msport, 520d F11 X08
I always leave my EQs flat...
The problem with the HK is that it must be lowered, not increased. One should use the EQ to lower the bass frequencies. There are threads about this for the E90 and it makes hell of a difference. Flat is useless in this car.
Here is one thread:
http://www.e90post.com/forums/showthread.php?t=42672
      09-06-2012, 02:22 PM   #15
BimmerMad
Drives: 3 wheeler
Let the speakers run in. It should sound a lot less harsh after around 100-200 hours of playback. The cones are still very stiff up until then so they need time to loosen up and improve the dynamics. Also, use CD or Apple Lossless on an iPhone/iPod.
      09-06-2012, 06:27 PM   #16
cardnation
Güten Täg
cardnation's Avatar
Drives: 91 E30 & 13 F30
Fwiw, mp3, m4a/mp4 are lossy not lossless formats.
ALE, ALAC and for the real enthusiast FLAC are the "lossless'' formats, FLAC will eat storage space very quickly.
2013 F30 328i Sport 6MT MG
1991 E30 318iC 5MT M20B25 swapped Vert Black - gone
      09-06-2012, 07:14 PM   #17
BimmerMad
Drives: 3 wheeler
ALAC is just as good as FLAC and it has better compression (still lossless though) so the file sizes are slightly smaller. Yes, the extra compression requires more power to decompress but there's nothing these days that can't handle it. Also, ALAC is supported on iPods/iPhones, it's much better for tags and album art, and finally it's now open source!
      09-07-2012, 02:12 AM   #18
dave-the-rave
Drives: M135i
Ooops, typo! i did mean lossy :P.
      09-07-2012, 10:27 AM   #19
zibawal
Drives: 2012 X5D
I tried playing flac off of flash drive my m3 won't play;( so I have to burn on cd and transfer ? Is it possible to transfer to apple format in iTunes and play from flash drive or transfer from flash drive
      09-07-2012, 11:50 PM   #20
RPM90
Drives: 340i M-sport AT
The HK is nice, it's a step above the stock system.
But for the price, it's not up to it's cost.
Satellite stations have poor sonic quality. It's nice that it's a "clean" signal, but it's quality is ultra compressed.
The problem I'm having with mine is FM reception. It's bad.
I can't believe I spent all the extra money and BMW and HK can't even make a good antenna. We have HD channels of FM stations, and if you can "catch" it it sounds better, good even. But, even with the strongest stations the FM receiver can catch and hold it. It cuts back to non HD. On some of those same strong FM stations I get hiss, quick signal loss and then back again. It's freaking annoying.
Cheapo FM radio's can get and hold these stations. My 135i's standard system always held these stations.
I'll put it in the list for the tech's to check out. I'm really hoping there is a loose antenna connection. If not, I want a new receiver, and if that means a new head unit, then so be it.
Anyone else have poor FM reception?
f30post
