07-27-2012, 11:42 PM | #1 |
Supreme Allied Commander
3808
Rep 54,285
Drives: F80 M3
Clutchmasters BMW E82 1M Clutches Our Best Selling 1M Clutch
The FX100 System uses the Power Plus I Pressure Plate with a custom heavy-duty Steel Back Organic friction disc. This clutch is engineered for heavy-duty street use. It is specifically designed for extended wear and additional clamping force for the enthusiast who has added an exhaust system, an intake system, up to 50hp NO2 upgrade, or other non-forced induction external bolt-ons. It features only slightly increased pedal pressure, longer life than stock, and normal clutch feel during engagement and disengagement for a very smooth operation.
The FX300 (Our most popular clutch for the 1M)System uses the Power Plus I Pressure Plate with a Steel Back Segmented Kevlar disc. This clutch is designed for the ultimate street enthusiast or weekend racer running a normally aspirated car equipped with cylinder head work and/or hotter cam(s), or with medium-boost turbo or super-charger, or up to 100hp NO2. The FX300 features only slightly increased pedal pressure, long life disc and positive engagement. The FX400 System uses the Power Plus I Pressure Plate with a custom, extremely durable, Sprung Ceramic disc. This is the ultimate extreme duty street and/or road/drag racing system. It is available in a 4 or 6 wing (paddle) configuration, with the 4-wing being the more aggressive setup (please specify which type you prefer). The sprung hub design allows for moderate dampening in high-torque applications, rendering it much more streetable than solid or rigid designs. This disc is designed for long life, outstanding holding capacity, and rapid heat dissipation. Warning: Due to the solid (no Marcel) friction rivet design, the FX400 disc engages very quickly and may chatter slightly in first and reverse. To help alleviate this problem, we only use premium ceramic friction material. All stages come as a complete kit including disc, pressure plate, throwout bearing, pilot bearing (when applicable), and alignment tool. (Individual components available upon request) Price starts at $729 Order here: http://www.hpashop.com/Clutchmasters...mw-e82-e9x.htm Last edited by HP Autosport; 10-17-2016 at 10:11 PM.. |
08-11-2013, 02:34 PM | #2 |
Sheriff
109
Rep 1,481
I have the FX300. That's on the edge for street driving. It sucks at traffic and going up on ramps. But the clutch never slips, I mean NEVER. you can punch the gas on first and that thing is brutal. It holds a lot of power. And I'm at around 585 pounds of tq.
2023 Porsche Spyder, 2024 Porsche Macan GTS, 4Xe Rubicon & 2021 BMW X5 M Package
08-11-2013, 11:34 PM | #4 |
3808
Rep 54,285
Drives: F80 M3
06-09-2014, 01:48 AM | #5 | |
Rep 359
Hi would like to ask, which FX300 did you buy, with the dampened disc or with the Rigid disc? there seems to be 2 versions.. not sure which one's better |
