07-01-2012, 05:10 PM | #1 |
Rep 25
F30 euro switch
Installed the euro switch from ECS tunning in my 2012 328. Install was a snap but the rear fogs don't go on. Anyone know what coding might be involved to get it to work?
Thanks, G |
07-01-2012, 05:38 PM | #2 | |
Rep 1,879
Drives: 2012 F30 328i
If the bulb is there, and the cabling is there too, then all you might need to do is to turn the feature on in the coding which should be (out of the top of my head) located somewhere in the REM module, probably under 3062 LceMapping1 or 2 and the feature should be called something saying 'mapping_nebelsomething_output' , just change the value from off to on and they should work.
F30 328i Luxury w/ Mojave metallic, beige interior (timeline)
Note: Many PM me for links to the software needed to code. Please note that I do not have download links to this software. Your best bet is using the search function in the coding thread |
07-02-2012, 02:48 PM | #3 |
Rep 584
Interesting thread,.. I want to follow, since I want rear fog too.
CurrentNone! RETIRED [15' GLA250][14' M235i F22 AW-ED 06/16/14][12' 335i F30 AW-ED 05/01/11 PCD 07/01/11] [11' M3 E93 MW-ED 08/13/09 PCD 10/14/09] [09' 135i E82 AW] [07' 335i E90 SB]
[ED Photo 12'] [ED Photo 11'] [ED Photo 09'] [PCD Photo 09'] |
07-02-2012, 03:01 PM | #4 |
Rep 2,148
Drives: F87 M2 BSM MT
I am happy that you tried it b4 me as in I created this thread 2 months ago.
http://www.f30post.com/forums/showthread.php?t=686589 please keep us updated on your findings.
07-02-2012, 03:09 PM | #5 | |
///Multiple
2992
Rep 4,243
Drives: M4 Coupe | M3 | Z4M Roadster
Garage List 2006 BMW Z4 M Roadster [8.81]
2016 BMW M4 Coupe ( ... [10.00] 2018 BMW M3 (Euro D ... [0.00] 2011 BMW 335is Coup ... [10.00] |
OP: If you ordered this switch from ECS Tuning and it doesn't enable rear fog lights, I'd contact ECS Tuning and let them know about your experience. I've had nothing but good experience ordering from ECS Tuning and the Euro headlight switch that I ordered for my E92 works perfectly. I'd be surprised if they said that your switch enabled rear fog lights and it didn't actually work.
The Coupe: 2016 M4 | Sakhir Orange | Black Full Merino Leather | CF Trim | M-DCT | More | ED 5/13/16
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18 The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12 |
07-02-2012, 03:17 PM | #6 |
Rep 25
Thanks for the information. I'll check on the bulbs/cabling this afternoon. FWIW ECS does make a point of stating the switch might need coding to work. I'll send them an email to see if they have gotten any feedback from customers.
G |
07-02-2012, 03:32 PM | #7 |
///Multiple
2992
Rep 4,243
FYI, the rear fog lights on the E92/E93 use the same lights that are used for the Brake Force Display.
Brake Force Display is a feature whereby additional tail lamps comes on during rapid or sudden braking. During normal braking, the two brake lights that are located on either side in the rear fender portion of the tail lamp assembly light light up when the brake is applied. During rapid or sudden braking there is an additional brake light located in the trunk lid portion of the tail lamp assembly on each side that turns on. Turning the rear fog lights on utilizes these two extra lights which are brighter that the regular tail lamps. As a result, the Brake Force Display is not available when the rear fog lights are on because those tail lamps are already illuminated. See the second picture that I posted in the above referenced thread to see what the rear fog lights look like. If the F30 doesn't have Brake Force Display on US models it may also not have the capability of rear fog lights.
07-02-2012, 04:30 PM | #8 |
Rep 1,879
Just a heads-up, I just checked in the code for my car and it says that the 'nebenschlusslicht' (fog light circuit) is turned off. You probably need to activate this indeed before it would work
(btw, in relation to the brakeforced lights, they're supposed to be there on the US F30 (they're advertised, after all.. although I have no clue how they start working), and these are enabled in the code (if they were not working, they most likely wouldn't be enabled) ).
07-08-2012, 11:17 AM | #9 |
Rep 25
Update:
The bulbs were there. ECS at this point has no information since they just started selling them. The code location svache mentioned didn't change anything although I was a little unsure since the code location he mentioned lists a right and left entry. I picked the left entry but my options were "off" and "nsl_1" I picked "nsl_1" |
07-08-2012, 07:30 PM | #11 |
///M Specialist South Shore BMW
772
Rep 7,108
damn, why cant this be as easy as the e90. I really want this switch but I have no idea how to do coding. seems too complicated for me and even if I did its still not working. thanks for the update OP
2021 M5 COMPETITION LCI Brands Hatch Gray on SIlverstone, carbon roof, comp wheels, Mperf splitter, carbon pro spoiler, carbon diffuser , carbon paddles, executive pkg. Dinan HAS, RaceChip, dinan spacers, FC stud kit, etc
10-23-2012, 09:15 PM | #12 | |
Rep 94
I have my Euro non xenon version installed. All of the functions work fine except the rear fog and the headlight range adjustment. I coded the same as you did and no luck. |
05-01-2013, 09:35 AM | #14 |
Rep 5,373
Rear fogs
Any new info on rear fogs?
///| g87 | f87 Comp | g29 M40i | f97 Comp | f80 Comp | f80 | f30 | e92 | tt | S5 | e92 | 350z | e90 |
08-10-2013, 07:33 PM | #16 |
Rep 25
Ok, so it took me a year of once and a while searching code but it turns out the rear fogs will work with the euro switch. Turns out one has to buy and install the switch. Then go to the coding discussion form on this website get the coding software and turn on not just the rear fog itself but also enable the rear fog button in software as well. As one can do all kinds of other cool things with the software as well (see forum) it was worth the search. Still frustrating on some level it wasn't a drop in and work feature like it apparently was in the past but it's working now so, so be it.
08-10-2013, 09:05 PM | #17 | |
Rep 94
08-11-2013, 12:28 AM | #19 |
Rep 5,373
Please post more info.
a) does one need to buy euro switch or could US switch be modded b) which code line needs to be changed c) pics or it never happened
08-11-2013, 02:31 PM | #20 |
Rep 25
It obviously looks like the U.S. switch could be modded. I initially tried to gently pry it apart but it wasn't coming easily. Nor are the little tabs that are on all four sides of the switch the only thing that is keeping it together. There is something else that I couldn't see. As the car is leased I didn't want to "F" with it too much as I have to turn it in at some point. These are the lines that need to be changed:
FEM 3060 LCEMaster 1C NSL_Verbaut = Verbaut REM 3062 LCELampMapping 1 Mapping_Nebelschlussl_L_output = nsl_l Mapping_Nebelschlussl_L_Function = nebelschlusslicht I still have the original software that came with the car. It hasn't been updated yet. While I assume the latest versions have everything in the same place I don't know that for sure. I'm sure someone in the coding forum would be able to look. G |
08-11-2013, 02:34 PM | #21 |
Rep 25
I couldn't take a pic of the rear fog on as it's in bright sun now. Trust me though it's on. If one wanted to for some unknown reason on could turn the right rear fog on as well. Or the right instead of the left. Just change the code entry in REM to the next section down which lists the _R_ entries
