F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Would a chip for the 335i work on the ActiveHybrid 3?
proTUNING Freaks
      06-28-2012, 11:00 PM   #1
BMWCali
Expect the Unusual
BMWCali's Avatar
Drives: 2018 X6M
Wondering if I could buy a chip to further increase the output on the ActiveHybrid 3 I'm getting. I know it's the same engine as the 335i, but it's apparently tuned to work in sequence with the supplementary 50HP electric motor so I'm wondering if a chip would still work as I'd love to be able to increase the output by 50HP or so. Since the combined HP on the ActiveHybrid 3 is 335HP from the factory, if I could buy a chip that gave me an extra 65HP out of the engine, I would be pushing 400HP!
A 400HP Hybrid... we'd be talkin' then!
      07-21-2012, 09:51 PM   #2
Walt
Drives: 2013 335i m-sport
I've seen this post unanswered for a while. I think were all rooting for you. I think it's anbodys guess though. Maybe you will get lucky since it is set to work with the auto start-stop. Wy doesn't anyone do a regular boost controller. You can easily and safely get 30hp without needing to change fuel maps and timing. I'm sure on these cars the boost is regulated electronically but I'm sure it can't be that hard. Definitely void the warranty though.
      07-05-2014, 12:28 PM   #3
franzzz
franzzz's Avatar
Italy
142
Drives: BMW M4
http://www.ziptuning.eu/shop/en/Exte...1EX1-4292.html
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
      07-09-2014, 07:48 AM   #4
RoundelM3
RoundelM3's Avatar
Drives: 15 F80 M3, 22 G01 X3 30i
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
FYI - there have been no "chips" available for engine tuning since the 1990s...it's all done by engine software updates or "piggyback" tuners that alter the engine parameters. There is no way to remove/replace a "chip" on current vehicles - they're all permanently mounted to the circuit boards. Last car that I put an actual chip in was a 1993 Porsche 968; the advent of OBDII regulations pretty much killed off the whole replaceable E-PROM thing.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey
      12-30-2014, 11:12 AM   #5
franzzz
franzzz's Avatar
Italy
142
Drives: BMW M4
Installed JB Stage 1
380Hp final
The car is great in the midrange !
      12-30-2014, 09:46 PM   #6
dougt.ah3
dougt.ah3's Avatar
Drives: AH3 Msport; F150 XLT
380Hp final
+1
2013 Active Hybrid 3 | M Sport | Alpine White | Coral Red | BM3 Stage 2 | ER FMIC | FabSpeed Catted DP | ER CP |
2016 F150
2021 RnineT
2022 K1600B
      06-09-2015, 05:42 PM   #7
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
I guess any piggyback tune for a 335/ N55 will work then ?
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      06-10-2015, 07:50 AM   #8
Mike@N54Tuning.com
BimmerPost Supporting Vendor
Drives: 2007 335i, 2015 M3
It should. The Stage1 and JB4 does work but can't speak in certain for other chips.
Mike
      06-10-2015, 12:47 PM   #9
mike@x-ph.com
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
I had customers who got the Jb on the Active Hybrid and it works without a problem .
https://x-ph.com/sale/
Phone number 702-494-9435
      09-12-2016, 01:58 PM   #10
franzzz
franzzz's Avatar
Italy
142
Drives: BMW M4
Update
After a software upgrade of the car by the dealer
(August 2016 psdzdata 3.59.3) the piggy does not work
      09-12-2016, 02:40 PM   #11
frackje
frackje's Avatar
Belgium
52
Drives: AH3
Update
Is that piggy like a JB4?
      09-12-2016, 02:49 PM   #12
mike@x-ph.com
Update
Software update should not impact piggys
Log boost and let us know how it looks like.
      09-13-2016, 12:11 AM   #13
Lancelot
France
568
Drives: 2017 m550i
Ordered JB4 for mine... Will let you know how it goes.
      09-13-2016, 01:40 AM   #14
franzzz
franzzz's Avatar
Italy
142
Drives: BMW M4
No
The new software detect te map-tmap manipulation by the JB stage 1
In the ActiveHybrid 3 my JB and my tmcmotorsport piggy put the DME ecu in the same error after a lot of pull (freeway or trackday) :
"Druck zu Nieder" (error appears only in navi screen, no mil lamps)
After this the car run in "stock" power.
Only with stop-start sequence the car run now with the contribute of the piggy
Before this software update ( 3.57) no problem.
A new logic in order to find tmap manuipulation ?
A conflict with the electric engine in "eboost mode" ?
the fact is that after upgrading my two piggy are detected when strong run
in stock mode no problem
      09-13-2016, 01:41 AM   #15
franzzz
franzzz's Avatar
Italy
142
Drives: BMW M4
I have stage 1 sorry
      09-13-2016, 01:57 AM   #16
Lancelot
France
568
Drives: 2017 m550i
Hope the JB4 doesn't have this issue... It'll stay in stage 1 but wanted a boost controller by rpm.
      09-13-2016, 02:01 AM   #17
franzzz
franzzz's Avatar
Italy
142
Drives: BMW M4
try.
your car have a new software called psdzdata 3.59.3 ?
(f20-16-7-503)
      09-13-2016, 02:02 AM   #18
Lancelot
France
568
Drives: 2017 m550i
Where can you see that? In Esys?
      09-13-2016, 02:05 AM   #19
franzzz
franzzz's Avatar
Italy
142
Drives: BMW M4
yes
with e-sys you check the software
But this new software is available from august 2016.
Have you visited BMW last month ?
      09-13-2016, 03:02 AM   #20
Lancelot
France
568
Drives: 2017 m550i
No, I will visit them by end of year for the yearly visit; I guess we will know for sure then. I should find a way to get them to update earlier, so I can check and return the JB4 quickly in case of problem.
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i
      09-13-2016, 03:43 PM   #21
Duperstar
Duperstar's Avatar
Drives: G30 540
I have a jb4 with an active hybrid 3 and just got a cel today after about a week. Jb4 can't read or clear the code. Going to check with carly and see if it shows anything. I definitely have the software update.
      09-13-2016, 11:50 PM   #22
Lancelot
France
568
Drives: 2017 m550i
And if you remove the JB4 does the CEL disappear?
f30post
