      06-06-2012, 04:50 PM   #1
GTM_Challenge
GTM_Challenge's Avatar
Drives: E46 M3, E90 M3
Willans Racing Harnesses - Authorized Distributor 4 Point, 6 Point, and accessories
** Items may take up to 2 weeks if not in stock at our warehouse. Please email or PM for stock before ordering **
Willans - Club 4 x 4 Saloon - 3" Shoulder & 3" Lap
Four strap body harness with four vehicle attachment points using snap hook and eye bolt mounting.
- All shoulder straps are 3" (75mm) wide. Lap straps are 3" (75mm wide). All straps fully adjustable.
- 3" (75mm) lap straps and all shoulder straps use Willans own steel anti-creep adjuster for control of wearer straps.
- A Willans aircraft type rotary multi-point quick release mechanism is used for central fastening. All straps connect individually to the release mechanism.
- Note: one lap strap is permanently fixed to either left-hand or right-hand lap strap so that when in unlocked position release mechanism falls to centre of the vehicle.
- Can be supplied with shoulder upper looped (PM for custom features).
- Harness approved, in both 3" (75mm) shoulder and lap or 3" (75mm) shoulder and 2" (50mm) lap, to FIA standard 8854/98.
- Can be upgraded using either a ‘V’ or a ‘T’ type plug-in crutch strap to comply with FIA standard 8853/98.
- Can be supplied in 3" (75mm) shoulder and 3" (75mm) lap to SFI 16.1 Approval if specified at time of ordering. Supplied with fitting instructions and eye bolts.
Black
Blue
Red
Please PM for custom colors!
Willans - Club V6 - 3" Shoulder & 3" Lap
Six strap body harness with six vehicle attachment points using snap hook and eye bolt mounting.
- All shoulder straps are 3" (75mm) wide. Lap straps are 3" (75mm) wide. ‘V’ crutch straps are 2" (50mm) wide.
- All straps fully adjustable. 3" (75mm) lap straps and all shoulder straps use Willans own steel anti-creep adjuster for control of wearer straps.
- Crutch straps are adjustable for individual drivers using 3 bar locker.
- Crutch straps are designed to stop driver submarining through the harness in high ‘g’ decelerations. These connect to the release mechanism by inserting crutch tongue into the 5th (lower) slot of the release mechanism.
-A Willans aircraft type rotary multi-point quick release mechanism is used for central fastening. Shoulder, lap and crutch straps connect individually to the release mechanism.
- Can be supplied with shoulder upper looped (see custom features).
- Harness approved, in both 3" (75mm) shoulder and lap or 3" (75mm) shoulder and 2" (50mm) lap, to FIA standard 8853/98
- Supplied with fitting instructions and eye bolts.
Black
Blue
Red
Willans - LDT6 Saloon - 3" Shoulder & 3" Lap
- All shoulder straps and lap straps are 3" (75mm) wide webbing. ‘T’ crutch straps are 2" (50mm) wide.
- All straps fully adjustable using Willans own anti-creep adjuster for control of wearer straps. Crutch straps are adjustable for individual drivers using 3 bar locker.
- A Willans aircraft type rotary multi-point quick release mechanism is used for central fastening. Shoulder and lap straps connect individually into the release mechanism.
- The ‘T’ crutch strap is permanently fixed to the 5th (lower) slot of the release mechanism (See 5th thumbnail)
- Harness approved to FIA standard 8853/98
- Can be supplied to SFI 16.1 Approval if specified at time of ordering
Black
Blue
Red
Accessories:
Willans - Fixed Tow Loop - Red
100mm Fixed Tow Loop to aid in vehicle recovery. Mounting bolt hole size is 11mm (7/16")
** Items may take up to 2 weeks if not in stock at our warehouse. Please email or PM for stock before**
      09-05-2012, 11:50 AM   #2
GTM_Challenge
Please PM or Email with any questions or for pricing
1addicts
