NEED HELP!!!!!
06-01-2012, 07:59 AM | #1 |
Catch Me If You Can
Rep 80
NEED HELP!!!!!
I need to find a dealer that is actually competent. My car keeps going into limp mode every single week. I have literally been to the dealer 25 times because of the same reason. I have had my fuel pump replaced, valves have been carbon blasted, have gotten tons of spark plugs replaced. Yesterday as im coming home roll up on a s2k throw it into third and accelerate and the car wont boost and the check engine soon light comes on. So now I need to find a dealer that can for once and all fix whats going on with my car, I'm sick of bringing it in to the dealer and by the next week it throws the code. Any recommendations on a dealer to go to or what else could be wrong with the car?
06-01-2012, 08:08 AM | #2 |
FREE DREAMK
162
Rep 9,321
Drives: the shiiit!
What codes is the car triggering?
06-01-2012, 08:47 AM | #4 |
FREE DREAMK
162
Rep 9,321
Drives: the shiiit!
If you have a tune and canclear is not on, it should be stored.
06-01-2012, 08:49 AM | #5 |
Rep 2,396
Drives: '08 E90 335i
If you can't read codes and have already tried disagnosing for a misfire (plugs, ignition coils, fuel injectors), it's possible (and sounds like) you have a boost leak. You could try getting a smoke test to see where the leak specifically is. Impressive Autowerk (Queens, NY) is running a June promotion for smoke test (http://www.e90post.com/forums/showthread.php?t=699220), $50. You could start there & find out if it's just a simple leak.
If there are no leaks, here's another thing to consider: Are you running a tune or anything? Reason why I ask is....
Good luck & hope that helps. |
