Had a smoke test done today...
05-30-2012, 07:34 PM | #1 |
Rep 2,854
Had 4-5 different locations with leaks.
Meth bung, cold side fmic, both intake tubes (injen), and the pipe going from fmic hot side to chargepipe. My logs didn't show peculiar wgdc prior to smoke testing, but it's such a simple process (just plug one intake and smoke the other, then reverse) that I figured I may as well do it. I'm glad i did. I also suggest checking out the vac lines going from your brake booster line to the canisters, as well as the brake booster line itself (at all 3 junctions). |
05-30-2012, 07:50 PM | #2 |
Rep 2,396
Drives: '08 E90 335i
Where'd you get this done?
05-30-2012, 08:34 PM | #3 |
Rep 821
Drives: 23 G80 M3 6SPD
Did you have any codes that pertained to the leaks?
Acura RSX-S K24a2 JRSC Swap - SOLD CPO BMW 335i 6MT - SOLD |
05-31-2012, 05:26 PM | #7 |
Rep 2,854
05-31-2012, 05:42 PM | #8 |
Rep 553
Speaking of vacuum lines, check out my thread. One of my vac lines from the vac tanks failed....
http://www.e90post.com/forums/showthread.php?t=698780
Montego Blue E90 335i
7" VRSF IC | OFT Tune | DCI | RB PCV | Secondary CAT Delete & CYBA 3.75" Tips | M3 Front | Mtech Rear | CSL Trunk | 219M | KW V1 | AA CP |
05-31-2012, 05:47 PM | #9 | |
Rep 2,854
what's up with the rust on that bracket? |
05-31-2012, 06:05 PM | #10 |
Rep 553
eh not sure, I sanded it off once but just came back. I may sand it again and just spray it with some clear.
