      05-30-2012, 02:59 PM   #1
GTM_Challenge
GTM_Challenge's Avatar
Drives: E46 M3, E90 M3
GTMotoring - ESS E-Flash N54 "is/1M" spec ECU Performance Software
ESS E-FlashFlash N54 "is/1M" ECU software is a result of extensive testing and exact calibration of ECU parameters to allow conservative performance gains on an otherwise stock car. The ESS 335i software is developed and tested in extreme heat in the Arizona desert as well as extreme cold temperatures in Scandinavia. The end user can select between 2 different power levels and cat/no cat in the DirectFlash unit. ESS E-Flash also includes full engine diagnostic functionality and code clearing capabilities.
DirectFlash Stage 1 :
Top Speed Governor: Removed
RPM Limit: 7200RPM
Fuel requirement: 91US
Horsepower: 400 DIN (Stock 335) - 390 DIN if used with stock intercooler
Torque: 550NM
Normal whp range on DynoJet: 345-365whp
Custom tuning available on an hourly basis, files can be loaded with DirectFlash unit through email.
When ordering this product you will receive 1 ESS E-Flash OBD2 reprogramming system which will VIN lock to your car.
This system can be used to program between stock and tuned, and it can also be used to load custom files/race fuel files/updates received from ESS over email.
ESS Tune is available for 1M and 135 models
Please PM or email for pricing and availability
Please PM / Email me any questions or give us a call at: 847-466-7463 M-F 10-6 central
austin@gtmotoring.com
Payments by Paypal, Visa or Mastercard
      09-05-2012, 11:58 AM   #2
GTM_Challenge
Please PM or Email with any questions or for pricing
1addicts
