      03-25-2012, 12:19 AM   #1
PHANTOM
Drives: 1M, X5d
Springs for the 1M
Are just switching out springs the best bang for the buck option to lower the 1M?
What are the best springs for the car?
I have been looking at the H&R and they are advertised as the same ones for the 135i is this correct?
Thanks guys
      03-30-2012, 09:12 AM   #2
Maximus_Prime
Maximus_Prime's Avatar
24
Drives: '11 1M, '12 Q5 2.0T, '06 Miata
Where are the H&R springs advertised as the same ones for the 135i? I remember H&R issued a press release featuring a AW 1M with BBS wheels that said that the 1M springs were specifically designed for the 1M?
2011 1M | Valencia Orange | #655 of 740
BMW Performance CF Spoiler | BMW Performance Shadowline Grills | Gloss black iND side markers
      03-30-2012, 09:26 AM   #3
TunedM2C
TunedM2C's Avatar
Drives: 2016 LBB M2
They are not the same. I verified this with the H&R reps at SEMA. The N.A. owner of H&R bought a 1M and said they did the R&D on his own personal car.
      03-30-2012, 11:32 AM   #4
mPlasticDesign
mPlasticDesign's Avatar
684
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
Originally Posted by PHANTOM View Post
....I have been looking at the H&R and they are advertised as the same ones for the 135i is this correct?
Like everyone has already said they are not the same. If you go to their website you will see that the part numbers are in fact different. I'm pretty happy with them.
H&R: http://www.hrsprings.com/scripts/app...Find3&MakeID=4
128/135: #29187
1M: #28910-1
Here is what the car looks like with the sport springs:
      04-03-2012, 10:13 AM   #5
M3Power79
Belgium
31
Drives: 1M sold - M4 MW DKG ordered
I have them also. Good on good roads, even more bumpy on bad roads then the stock springs.
"... on the smiles-per-mile charts, the 1-series M coupe can't be beat. It is a challenging piece, a triple-X-rated driver's machine for semi-professionals. Its handling balance provides an open invitation to indulge in latent oversteer, and provides an opportunity to separate the men from the boys. It is an absolute hoot on the track and an addictive plaything on your favorite twisty back road. "
      04-03-2012, 01:41 PM   #6
Aqua
Taiwan
23
Drives: 1M
What about the KW Adjustable Lowering Spring Sleeve-Over Kit?
It seems like a good alternative to the H&Rs while retaining the stock shocks
Anyone with experience using them?
http://www.europeanautosource.com/pr...ver-kit-e82-1m
      04-24-2012, 12:22 PM   #7
IMG's Avatar
Drives: E36 M3 Track car,Ess E90 M3 DD
What about RD springs ?
      04-24-2012, 05:54 PM   #8
Das Ein
Das Ein's Avatar
Drives: '16 Audi TTS, '17 500 Abarth
$885.00!!
      04-24-2012, 05:55 PM   #9
Das Ein
Das Ein's Avatar
Any word on the Eibach's yet?
      04-24-2012, 11:13 PM   #10
///M1
///M1's Avatar
Drives: Many
128/135: #29187
1M: #28910-1
Looking good, M-, a couple of questions:
1.What is the drop you experienced after full settling front and rear?
2. Did you do an alignment?
3. How has everyday comfort been affected (negligible/noticeable)?
Einser has these on, he should chime in.
2011 BMW E82 1///M: AW, all options; Renntech, Akrapovic, Forge, P3, RevoZ CF bits, many mods
1988 BMW E30 M3: Hennarot, S14, stock
2018 Porsche 991.2 GT3: PtS, CXX, LWBS, PCCB
1998 Porsche 993 C4S: Zenith Blue, last aircooled widebody, Bilstein PSS10, Fister II + Fabspeed exhaust
2008 Audi B7 RS 4: Sprint Blue, Audi Exclusive Euro Bucket Interior, Premium+Titanium, many mods
      04-25-2012, 03:15 AM   #11
EINSER M
EINSER M's Avatar
Drives: BMW i3 rex
my calendar says mid May for the final version of the Eibach springs to be out.
I have the prototypes on for about 1000 miles now, they feel great, and the 500 miles road trip out to las vegas for MFEST this weekend was super comfortable. the full lock grind and rubbing that I had while on the H&Rs went away with the Eibachs.
      04-25-2012, 11:58 AM   #12
Das Ein
Das Ein's Avatar
Awesome! Do you have the lowering specs? Any more details you can share?
      04-25-2012, 12:40 PM   #13
EINSER M
EINSER M's Avatar
Drives: BMW i3 rex
i only have the prototypes on and final specs have not been released yet and wont be until my car goes back in for fitting of the final production versions. from what i have seen eibach springs should be close to h&r springs lowering specs which were 1.2 inch front and 0.6 inch rear...
      04-25-2012, 01:39 PM   #14
Romo
Romo's Avatar
Netherlands
1748
Drives: GR Yaris GT4RS
I`ve the JRZ RS1 damperset with Eibach Pro Kit springs.
      04-25-2012, 01:41 PM   #15
CDR_UK
Drives: AW 1M
How is the ride? What settings do you typically run?
      04-25-2012, 01:55 PM   #16
Romo
Romo's Avatar
Netherlands
1748
The dampersettings are from 1 to 22 clicks, 1 most soft, 22 most firm.
1 klick is typical for street driving, which is firm enough (you can immediatly notice while braking hard, the nose won`t dive !!), has a great and sharpend steering input, great stability with high speed driving ,is less nervous than factory damperset.
The 22 klicks are typicaly for track driving.
1st klick is so far good enough for my driving style.
      04-25-2012, 02:15 PM   #17
CDR_UK
Drives: AW 1M
Thanks for your reply! There must be quite a lot of middle ground between 1 and 22 . Please could you also tell me if the rear dampers are adjusted from the top or the bottom? Any pics of the adjuster?
Sorry for the OT.
      04-25-2012, 02:24 PM   #18
Romo
Romo's Avatar
Netherlands
1748
Sorry for the OT.
Adjustable from the top, there was a special hole made for it, which can be closed with some special material, so you won`t notice there is a hole inside.
The adjuster is the red dot on the upper side
      04-25-2012, 02:26 PM   #19
Grey Dove
Grey Dove's Avatar
Drives: Sold for a reptile
above
      04-25-2012, 02:28 PM   #20
Grey Dove
Grey Dove's Avatar
Hey Romo how did things work out? everything oke now?
OOPS nevermind just saw your post in the other tread
      04-25-2012, 03:12 PM   #21
CDR_UK
Drives: AW 1M
Thanks Romo and gs/e60/1m!
      05-21-2012, 02:12 AM   #22
mpiligrim
M-addict
mpiligrim's Avatar
Russian Federation
Drives: M3 e92 Laguna seca, M5 f90 Com
Just bought Eibachs will post pictures soon.
In wroom I trust.
BMW M3 e92 Laguna Seca Blue '13
BMW M3 e91 Tourmaline Violet '10
BMW M5 F90 Comp Peridot Green '19
BMW 1M Valencia Orange '11 (sold)
1addicts
