E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Bmw 335d Exhaust
      03-01-2012, 01:03 AM   #1
evinsaini
Drives: Bmw 335d
Bmw 335d Exhaust
Hello people,
I have bought a 2010 BMW 335d couple months ago. I was wondering if anyone has any suggestions for what kind of exhaust i can get for a my diesel bimmer? I'm looking for a low tone rumble exhaust. I would appreciate if you guys helped me.
Thanks.
      03-01-2012, 07:52 AM   #2
minus13
Drives: 2009 335D
This is the only one I am aware of:
http://store.vacmotorsports.com/akra...ems-p2418.aspx
I hope you're sitting down when you see the price.
      03-01-2012, 11:27 AM   #3
EYE4SPEED
Ex-Diesel Driver
EYE4SPEED's Avatar
Drives: Audi SQ5
^ Is that compatible with the (edit: USA) D models?
      03-01-2012, 12:02 PM   #4
cssnms
cssnms's Avatar
Drives: 2011 BMW 335d
It looks like you are located in the UK. You are lucky owner since you do not have the urea injection system to contend with! Look into the Eisenmann exhaust system for the 335d. I think it sounds the best on the diesel.
http://www.eisenmann-sportauspuff.de...ust-system.php
      03-01-2012, 01:02 PM   #5
mottati
Drives: 91 M5 / 09 335d
12hp at 5980 rpm?? my rev limiter is below that.
Is there that much difference between the 335i and 335d rear muffler section? i was looking at a 335i on a rack at my local independent bmw shop, that is also a dinan dealer, looked very similar as far as the rear muffler went. The shop is a dinan dealer, said they'd never done it but yeah, it looked very similar and possible.
      03-01-2012, 01:48 PM   #6
cssnms
cssnms's Avatar
When I removed my exhaust there was a stock e92 exhaust on the floor that I compared it against and the mufflers look identical as far as I could tell. As for the exhaust run from the downpipes back, they are different. The 335i is a 2 pipe system the entire run vs the d's single pipe system up until the secondary cat at which point it then branches to 2 pipes.
      03-01-2012, 02:03 PM   #7
GreekboyD
Drives: 2009 BMW 335d
2009 BMW 335d  [8.00]
I'm sure that 12 HP at 5980 RPM pertains to the 335i and not the 335d.
      03-01-2012, 03:53 PM   #8
cssnms
cssnms's Avatar
Here in an illustration of the stock d exhaust for US cars.
      03-02-2012, 12:43 PM   #9
acerboo
England
179
Drives: e92 335d lci
ive tried a ver expensive schnitzer, a bmw performance 335i, and a special straight through supersprint and none made any difference at all to the sound,
      03-02-2012, 01:31 PM   #10
cssnms
cssnms's Avatar
True dat! Replacing mufflers will do little for the sound.
I had my pipe and mufflers off after the secondary cat (seen in pic above), started the car and it was amazing how quiet the exhaust sound was still. Short of removing all cats on a US car and the dpf there isn't a whole lot that can be done about it. Despite that, I still think there is some benefit to installing a less restrictive system which is what I did.
e90post
