E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > TREO Owners & Bluetooth
      06-04-2007, 09:50 AM   #1
PI Guy
Like Mannix...with a Bimmer!
PI Guy's Avatar
Drives: 2007 335i Cabrio-ordered 3/29
Hey. I know there are threads that mention the pairing of TREO's with the Bluetooth system in BMW's but I think it is important for all TREO users to get "the scoop" on how they actually work on 2007's.
Please state your TREO brand.. (650, 700, 700p, etc.)
Palm or Windows based (this is important)..
Model & Month of Build for your Car..
Let us know if;
a. Everything works, or
b. What doesn't work (ie. Phonebook, Signal Strength, etc.)
Did I forget anything??
E93 335i Cabrio - Jet Black - Saddle Dakota Leather - 6MT - ZCW - ZPP - ZSP - 322 - 4AS (Grey Poplar) - NAV - HD - SAT - IPOD/USB Ordered 3/29 - Delivered 6/15
      06-04-2007, 10:37 AM   #2
HellFish
Drives: 07 335i Coupe
Treo 650... kind of works. It will not upload your whole phone book, just the numbers you have on speed dial.. kind of annoying. Also, it drains my battery like a crazy.
2007 335i Coupe | Graphite | Black Dakota | Premium | Sport | Nav | Heated Seats | Comfort | Aero |
      06-04-2007, 12:48 PM   #3
bpbenda
Drives: 2006 BMW 325i
2006 BMW 325i  [0.00]
Have 2006 325i with navigation and Treo 700p. Only pulls numbers from Favorites list (speed dial). Numbers from Contacts do not transfer. Signal strength is no problem. No battery issues directly related to use with vehicle. Running the phone with bluetooth active does drain the battery more, but this is typical of similar phones. Bluetooth pairing is somewhat glitchy. First time the phone pairs with the car, the phone does not know to transfer the call to the car. So, if you are trying to pair for the first time, it may seem like it is not operating properly. Work around for this is to turn off the car all the way and then turn it back on. The reason I think it works this way is because the car needs to be looking for the phone when the car is started. It will not operate properly if you try to activate bluetooth after the car has already been turned on. This is not the case with many other bluetooth phones. My wife's LG VX8700 works perfectly with the vehicle. So, can be an aggravation at times. Once you get the hang of it, it's not that bad, but certainly much room for improvement.
Vehicle was built January 2006.
      06-04-2007, 03:35 PM   #4
rocketman99
Lurker
Drives: '19 M2C, '24 X1 M35
It's been posted before and I'll rehash. Treos don't work very well with idrive. However, they do work really well with idrive if you use a piece of software called jetware mobile.
I have a Mar 06 build 330i and a treo 700wx. Out of the box, all I got was the phone to pair with no signal strength and the only contacts were those saved in my treo "speed dial" buttons. About three months ago I downloaded jetware. Now I have the signal strength bar and my entire phonebook in idrive.
I've never had much trouble pairing my phone with the car's BT, but since I got the latest BMW software update it's really easy to reset the BT on the car.
      06-04-2007, 04:09 PM   #5
HellFish
Is there something like for non windows based palms?
      06-04-2007, 04:23 PM   #6
PI Guy
PI Guy's Avatar
I don't think "Jetware" is available for the 650.. am I wrong?
      06-04-2007, 04:25 PM   #7
PI Guy
PI Guy's Avatar
.. and ONLY for Windows Models!
      06-05-2007, 04:08 AM   #8
Jonmartin
Jonmartin's Avatar
Drives: E90 M3
Originally Posted by ksfrogman View Post
December '06 build 330i
Treo 700wx with Verizon
I hate this phone with a passion. I had a Treo 650 with Palm OS. It wasn't bad. I actually liked it. The Treo 700wx uses Windows, which tries first and foremost to be a PC, and secondarily a phone.
As others have mentioned, only speed dial numbers get loaded into the iDrive menu. The phone does not always pair with the Bluetooth of the car. In fact, most of the time I have to manually turn off the Bluetooth activation on the car, then turn it back on. Then I go into the Bluetooth of the Treo and do the same thing. This forces them to pair.
Verizon's version of this Treo does not display that I have text messages or voice mail. It simply will occasionally pop up a "notification" prompt on the lower left hand corner. When I select that it tells me I either have a text message, voicemail, or simply that my wireless sync has updated my inbox.
Also, when I try to use my phone to make a simple phone call, I sometimes get interrupted by pop-up windows like "Battery is now 75% full" or "active sync successfully updated." If my home phone were to do this, I'd throw it away and get another.
I feel you I hate my treo after having both a 650 and 700P both were official garbage and it wasnt till just today that Treo decided to release a major update so that my 700P works with iDrive finally AFTER A WHOLE YEAR!
      06-05-2007, 06:27 AM   #9
Grimace
Drives: 335iiiii
what update is that? where can i find it?
      06-05-2007, 07:14 AM   #10
e93
open air motoring at its best
Australia
18
Drives: BMW E93 335i Convertible
2007 e93 335i  [0.00]
My Treo 650 paired up no problems. Works OK everytime I get in the car. You have to load the numbers you want to call into the speed dial - but I don't have enough friends to fill that up anyway
[SIGPIC][/SIGPIC]
2007 335i Convertible || Black Sapphire | Cream Beige | Burr Walnut | 6 AT Paddles | Comfort Access | Aluminium Pedals | Aero Front Spoiler | Remus Quads | KW V3 Coilovers | Velocity V-715 wheels | M3 Rear Lip Spoiler || On Order || || Wishlist || ||
      06-05-2007, 08:35 PM   #11
alpine 335
Drives: 335i Coupe
Let us know if;
650 Sprint, Palm and everything works fine.
Phonebook does not transfer(know issue) call waiting must be controlled via the handset, signal strength works with picture of telephone.
If I'm on the phone and want to leave the car I have to into the bluetooth menu and disconnect bluetooth otherwise I get this horrible beeping.
Joseph
07 335i Alpine White/Coral
04 M3 Imola Red/Imola Red - Sold
04 CTS Blue/Gray - Rain and Snow Car
02-07 Cadillac Hearses and Limos Black/Black
      06-05-2007, 08:50 PM   #12
Carnage
Carnage's Avatar
Drives: people insane
I have a 700W and it works pretty well...I posted a thread about a year ago with a list of things to look for....
http://www.e90post.com/forums/showthread.php?t=15990
      06-06-2007, 04:58 PM   #13
AndrewAZ
AndrewAZ's Avatar
137
Drives: 335i
The 700p has inherently flawed bluetooth. A patch was released on monday to fix the issue, but has been withdrawn since it has bricked so many treos.
http://treocentral.com/content/Stories/1226-1.htm
      06-06-2007, 09:58 PM   #14
DocHarvick
Happy Fan...Happy Man!
DocHarvick's Avatar
Drives: 2007 335i Coupe, BS/Sad Brown
Here's what I got.
Just got my 07 335i coupe, and have Treo 750. I've had multpile problems, and my car was built at the first of May. It pairs up ok, but after when I get back into my car after some short length of time, the bluetooth recognizes my phone, but I can't place a call out. It states the phone is connecting, and then boots the phone and takes me to settings. I have to reset my Treo for it to work. Also, it will come up for me to accept a call, but will disconnect when I hit accept. It's really pissing me off!! Any suggestions from anyone?
I'm gonna try the jetWare now....
Whose Cuisine Will Reign Supreme?
1987 325is Coupe, White with Blue Interior
2007 335i Coupe, 6MT, Black Sapphire, Saddle Brown, Sport, Luxury, Nav, Comfort Access, Dark Tint:rocks:
      06-06-2007, 10:09 PM   #15
noktekniq
noktekniq's Avatar
54
Drives: e90
sucks still no release for verizon. also no fixes for anything. maybe time for a new phone?
      06-06-2007, 10:27 PM   #16
sflgator
sflgator's Avatar
148
Drives: '09 MB C63 AMG & '08 MB GL450
I believe the Jetware s/w fixes your BT problems with the Treo 750; if my new Blackberry Curve 8300 didn't work out for me, I was planning on switching to the Treo 750 w/ the Jetware s/w. I had the Treo 650 and although it paired perfectly with my 335i, I hated the phone (screen freezes, restarts, other problems, etc.). Fortunately, my BB Curve is working great so far and the BT pairs well with my 335i!
|2009 RENNtech MB C63 AMG | Black/Black Leather/Black Maple | Premium II | MultiMedia | iPod |
| TeleAid | Charcoal Filter Delete | BMC High-Flow Air Filters | High-Flow Secondary Cats | Clear Side Markers |
      06-06-2007, 10:27 PM   #17
HellFish
Any word as to when the Blackberry curve will be available for Sprint?
      06-06-2007, 10:49 PM   #18
AndrewAZ
AndrewAZ's Avatar
137
Drives: 335i
If you have sprint call them up and complain about your 700p. I got a 755p over nighted to me and it fixes all the 700p issues. I got my 755p the day the 700p MR came out and did the MR on the 700p and used it for a while side by side to the 755p and it was still a POS and I quickly put it in the UPS box and sent it back. I was given the option when the BB 8830 comes out to trade up but have to pay the difference. The rep that I spoke with told me he didnt know a date when the 8830 would be out but he assumed it will be out in 3-4 months or less since I guess in 3 months they have a bunch of new phones that come out and they usually release a bunch of phones in a 1 month period together.
      06-06-2007, 10:59 PM   #19
Jonmartin
Jonmartin's Avatar
Drives: E90 M3
I'm waiting for the 8830 also.
      06-07-2007, 12:01 AM   #20
noktekniq
noktekniq's Avatar
54
Drives: e90
so the sprint 755p doesn't have problems? does it also have the problem of phonebook import
      06-07-2007, 08:50 AM   #21
sflgator
sflgator's Avatar
148
btw -- the 8830 is a variant of the 8800; the Curve 8300 is a completely different phone...more like the BB Pearl with a full QWERTY keyboard (like the old spaced out keyboard rather than the tighter, soft button 8800 keyboard), larger screen, a 2.0MP camera, and some other improved features. The BB Curve 8300 is in the 1st pic and the 8830 is in the 2nd pic below...
      06-07-2007, 10:30 PM   #22
AndrewAZ
AndrewAZ's Avatar
137
Drives: 335i
I dont have BT in my BMW, but I use it with a headset and a GPS receiver and I dont have any of the pairing issues the 700p had. If someone in Arizona wants to meet up I will provide my 755p to test out. But then again you can go buy one from sprint and return it in 30 days if you dont like it or if it doesnt work.
e90post
