      01-12-2012, 05:58 PM   #1
Cal@Sonic MS
Cal@Sonic MS's Avatar
Drives: bmw
♦ Sonic MS | Ground Control Camber Plates for the BMW E82 1M Coupe
Sonic Motorsports
1045 West El Camino Real
Mountain View, CA 94040
tel: 650-733-6506
fax: 650-691-9009
email: info@sonicms.net
We at Sonic MS are proud to present Ground Control's new camber/caster plates for the BMW E82 1M Coupe.
Ground Control Camber/Caster Plates for the BMW E82 1M Coupe
STREET SERIES
MFG PN #cp1mstreet
MSRP - $499.00
These plates feature over 26mm of total camber adjustment with the ability to make corrective caster changes to equalize side-to-side caster in the stock position.
Other features include replaceable waterproof German axial load bearings, and urethane bushings for long life, less deflection, and a smooth silent ride on stock or stock sized aftermarket springs.
These camber plates are also engraved with the Ground Control logo and markings which can be used to locate the plate in the stock position for easy, repeatable, adjustment from street to track and back.
All components are anodized or zinc plated for corrosion resistance.
GC also offers their lifetime guarantee on this part!
• A clean sheet design for street cars, not an adapted spherical race plate.
• Waterproof, German-made, axial load steering bearings.
• Allows for up to 26mm total camber adjustment.
• Unique slot design allows for caster correction.
• Urethane center mounts reduce NVH, yet do not flex.
• All components plated or anodized for corrosion resistance.
• Zinc plated mounting bracket for ease of install and adjustment.
• Reuses stock rubber spring pad for noise isolation.
Please note: this is the only version that works with stock springs.
RACE SERIES
MFG PN #ccp1mrace
MSRP - $409.00
Legal for SCCA Production, Street Prepared, and also legal for BMWCCA Prepared classes.
More camber adjustment than stock, caster adjustment, aircraft bearings, engraved with calibrated degrees, with stainless steel reinforcement.
Every component is anodized or plated, including fasteners. The Ground Control design adds extra travel to avoid excessive bottoming out, this is a very well engineered product.
The GC exclusive stainless steel reinforcement prevents electrolysis between the steel fender and the aluminum camber plate.
Camber and caster are separately adjustable by sliding the mounts, without removing any components from the car. The priority of this design is to allow fast, repeatable alignment changes at the track.
The Ground Control camber plates feature two sets of bearings, a proprietary bearing, made to our specs by Aurora in the USA, which allows for articulation of the shock shaft. This spherical bearing is very understressed, as the Ground Control design does NOT support the weight of the car on the spherical bearing. Instead, the weight of the car is supported by a completely separate articulating needle bearing, which is also manufactured for Ground Control in the USA
TECHNICAL SPECIFICATIONS:
Camber range: 6mm positive, 24mm negative, 30mm total.
Caster range: 22mm positive.
All Ground Control products carry a lifetime guarantee against defects when installed and maintained correctly. We strongly recommend that all of GC's products be installed by a competent, qualified mechanic.
For best pricing and ordering information, please call me at 650-733-6506, email at cal@sonicms.net or send me a PM.
Or you can simply visit the link to our website to order!
Store Hours:
Mon-Fri : 10AM-7PM PST
Sat: 12PM-5PM PST
Payments:
We accept all major Credit Cards, in addition to PayPal and Certified Cashiers Checks / Money Orders.
We also offer professional on-site installation services for customers local to the SF Bay Area. Please contact us directly for more information.
      05-21-2012, 04:27 PM   #2
Cal@Sonic MS
Drives: bmw
Thank you for your continued support, we appreciate it!
      04-12-2013, 02:59 PM   #3
Cal@Sonic MS
Drives: bmw
ttt
      04-18-2013, 03:04 PM   #4
Cal@Sonic MS
Drives: bmw
ttt
      05-16-2013, 01:22 PM   #5
Cal@Sonic MS
Drives: bmw
ttt
      05-31-2013, 03:24 PM   #6
Cal@Sonic MS
Drives: bmw
ttt
1addicts
