      12-28-2011, 09:29 PM   #1
vito747
Drives: 1 coupe M
Engine oil temperature
Hello!!
When do you consider the engine to be warm enough to stat pulling hard after a cold start??
I always wait until the oil tmp is close to 120ºC (almost vertical) to go beyond 2000-2300 rpm... Is that "too conservative" or is the right spot... I have seen that in normal driving the oil stays between 95 (the dot) and 120 but closer to 120, (I assume 110+-) so I consider that optimum tmp but some say it is too conservative and there is no need to wait that much (some times it takes up to 15-20 KM) and then I gradually rev up the engine...
Happy new year!!
      12-28-2011, 09:33 PM   #2
Simsims
Drives: 119/220
too conservative
VO 1M - everything except sunroof
RIP BSM 135i 2009-2011
      12-28-2011, 10:38 PM   #3
Fundahl
Drives: VO 1M, 300zx TT
160+ degrees Fahrenheit is good enough to go WOT. Basically once the needle moves off the beginning of the gauge.
      12-28-2011, 11:24 PM   #4
vito747
Drives: 1 coupe M
Really??¿¿ cuz I feel the gearbox a little more rough at the beginning and then it starts to smoothen but way after the needle starts to move... maybe it´s my and my paranoia...
      12-29-2011, 12:51 AM   #5
Fundahl
Well, yeah the trans and diff are a bit clunkier for a while, but as far as your engine is concerned you'll be ok.
Personally, i feel the diff "clunk" back after letting off when it is still cold, but no gearbox issues, and I slam gears pretty hard!
      12-29-2011, 05:54 AM   #6
Romo
Romo's Avatar
Netherlands
1748
Drives: GR Yaris GT4RS
I must say the 1M engine rather warms up slowly compared to my previous E92 M3.
I spoke about it with Advevo, he does have the same experience...
Can`t explain why, but it does warm up slowly.......
      12-29-2011, 05:56 AM   #7
marcel b
marcel b's Avatar
132
Drives: F31 340i
I spoke about it with Advevo, he had the same experience...
a lot of cooling
      12-29-2011, 06:03 AM   #8
Romo
Romo's Avatar
Netherlands
1748
Originally Posted by marcel b View Post
a lot of cooling
Think so.........
I had the pleasure to drive along with Advevo behind the wheel on friday 23th of december........
He drove it hard, I mean realy hard, and a lot of drifting
Temperature never exceeded 120 degrees Celcius........
      12-29-2011, 06:23 AM   #9
Advevo
Drives: M2 Competition, E30 M3 DTM
Romo it s also good to mention i use the Castrol Edge 0W-40. Engine oil temp stays a little bit lower on extreme use.
On Track i get the temp a little over 120 degrees.
      12-29-2011, 09:49 AM   #10
Oaktree
Oaktree's Avatar
Drives: 2012 X5 - 2010 M3 - 1999 M3
In MN it takes me about 8-10 miles for the temp gauage to budge which is almost my entire commute.
      12-29-2011, 08:42 PM   #11
Fundahl
Yes, warm up takes a while, but is critical for those turbo bearings. (and main!)
I can actually hear mine whine more and it fades by the time it is warm. (cowling off)
1addicts
