Swirl Flaps
12-04-2011, 02:12 PM | #1 |
Rep 2,612
Drives: F30 328i Luxury - Sport Auto
Swirl Flaps
Its not a euphemism, don't worry, I was just wondering if the notorious swirl flap issue of older 30d's was still present in the current N57's - such as mine. I know the first gen X5 30d was prone to this issue and the symptom was unsteady idle at start up. Do the current 3.0L's suffer from this?
I'm wondering because it was brought to my attention after watching a (shite) Fifth Gear review of buying a used X5 30d and it was recommending you watch out for this as it can lead to dramatic engine problems. This brings me onto another question; is my car normal? On 8/10 (evening through to morning - 13hrs) cold starts, the rpm at idle is ever so slightly fluttery until it warms slightly. Is this normal? The current temperatures at cold start are about 2 - 6 Degrees C so rather cold but I don't remember it doing this before. Last edited by SomeRandomer123; 12-14-2014 at 02:57 PM.. Reason: Addition of image |
12-05-2011, 08:38 PM | #2 |
Rep 236
Drives: 335d
I don't think this affects the US 335d. I believe I remember someone asking this on another forum, but I don't remember which one. I'll try searching for it.
Enjoy what you drive.
12-07-2011, 06:20 PM | #4 |
Rep 1,110
U.S./Cdn-spec M57's have swirl flaps, but they are electrically actuated (vice the vacuum actuation from earlier M57's). (Ref: the ST810 Advanced Diesel presentation)
2016 GLE 350d - White on Black
12-15-2011, 06:00 PM | #5 |
Rep 2,612
I believe our engines are still prone to this fault but not as likely to happen as it used to do.
Gone: 2006 BMW E60 520d SE 6MT Gone: 2009 BMW E90-LCI 330d SE 6MT Current: 2012 F30 328i Luxury 8AT On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!) |
03-20-2012, 01:17 PM | #6 |
Rep 26
Had the same symptoms on my 330d E90 LCI.
Slight variations at idle on first morning startup. If you press the acelerator a couple of times and bring the RPMs above 1000, problem would not return until next morning startup. It was a problem with the swirl flaps and it cost me over £600 - BMW only sells the whole intake set. I wonder why they come up with one diesel engine after another and they all seem to have this problem... |
03-20-2012, 02:15 PM | #7 | |
Rep 2,612
03-20-2012, 11:01 PM | #8 | |
Rep 26
Anyway, I'm removing my swirl flaps in the next few days. Shouldn't cost me more than £50 for the job and it's the only guarantee that it won't happen again. Just for the record, it's a European 2009 E90 LCI 330d Steptronic. |
05-12-2012, 07:14 PM | #9 | ||
Rep 2,612
Mine is also a 2009 but a 6MT. 80k miles on it now.
05-14-2012, 08:29 PM | #10 |
Rep 104
Swirl flap failed 4/12 on 2011 335d
My dealer diagnosed a fault (service engine soon lite) as a swirl failure.
Had to order a new air intake from the motherland, fly it here and replace it. Car is a 2011 335d bone stock with 3,500 miles on it. It ran fine, the light went out a few times, kept coming back, so I took it to the dealer. 8,000 miles and a cross country high speed, high temp (west Texas ) round trip From Phoenix to Ft. Walton Beach, FL Had a loded pistol just in case |
06-26-2012, 03:30 PM | #11 |
uʍop ǝpısdn
Rep 63
Drives: '11 335d, SG/Saddle, ZSP, ZPP
I just brought mine to the dealer for a yellow SES light, same issue as ithatel mentioned above. Stock everything, exactly 7k on the odo. The SA said he has to order a new part to replace the swirl flap/manifold.
06-26-2012, 04:28 PM | #12 |
Rep 2,612
Wow! Good job any debris didn't fall into the cylinder! Lucky guy!!
07-05-2012, 12:06 PM | #13 |
uʍop ǝpısdn
Rep 63
They found fault code #4B67(I think?) and ended up installing a whole new intake manifold. I think they reset the ECU too, because my mileage has been crap since them (~33 before, down to 27 now)
07-05-2012, 12:45 PM | #14 |
Rep 2,612
Ahh. Glad to hear to issue has been resolved!
12-09-2012, 03:54 PM | #15 | |
Rep 48
i have also same trouble swirl flap in DTC stored in DDE, car is 330D LCI E90 2009 engine N57 can you confirm, is possible remove this swirl flap and car continue working fine ? maybe need coding after ? thanks friends |
12-10-2012, 05:23 AM | #16 |
Rep 3,489
Drives: Montego Blue 335d
@ ka rai good question I beleive it can be done unlike ours that its electronicanily induced to the ECU. Good luck
RENNtech Flash(Lenny Wu)/WAGNER IC
Enkei Rajin 18"/Execuhitch Hitch/Koni FSD Soft Ride Bike Rack/Brava Synthetic Motor Oil(Made in Puerto Rico)/Meth(in the works)/CBU done w Andrew EGR Race Pipe (whoa! what an animal it is now) |
12-10-2012, 12:40 PM | #17 |
Rep 1,502
Drives: F36 435xd
Hi Guys
I have resently had my intake manifold replaced before the swirl flaps would be a problem. And yes the swirl flaps is controlled by vacuum in europe and cannot be replaced seperatly, only by replacing the entire intake manifold. There are some solutions in the UK to remove the swirl flaps. The ppl I have read about cannot feel any difference before and after removal. As far as I know theres no coding involved in removing the swirl-flaps. The new intake manifold is a bit different than the old one. The axel where the flaps is mounted is stronger, the swirlflaps is mounted with small screws and the actual flap is covered with a rubber band at the edges. Proberbly to keep it sealed and to remove any debree building up inside the intake manifold.
Brgds
Allan ‘15 F36 435xd Gran Coupé Ex: E46 330d, E91 330dA |
04-07-2014, 03:36 AM | #18 |
Rep 713
Hi guys,
do you have any updates if swirl flaps can fail in N57 engines and destroy engine? it happens in M57 but what with newer engine? I've been told that intake manifold is designed to prevent the M57's issue. thanks. |
04-07-2014, 03:54 AM | #19 |
Rep 3,049
Drives: 2009 BMW 335d
I had a "swirl flap actuator" fault code due to carbon build up and they replaced my entire air intake manifold under warranty.
04-07-2014, 07:13 AM | #21 |
Rep 2,210
On the newer engines the actuator can still fail, but that is not the same as an older failure. On the older swirl flap design the flap could come loose and actually fly down the intake and possibly make it into the cylinder causing serious issues. This hasn't happened on the updated version that I know of. Also, at least for the US version most of the actuator failures are probably due to carbon buildup so you don't need a new intake, you just need to clean up the flaps and rod
Tags |
330d, 35d, flap, n57, swirl |
