      11-07-2011, 03:09 PM   #1
MusclezMarinara
Drives: VALNCYA
Anyone install spacers?
Wondering if anyone has installed spacers on their 1Ms?
Thinking about
12MM REAR
15MM FRONT
Thoughts?
      11-07-2011, 03:19 PM   #2
hopofthese
Drives: E46 M3 & 11 1M
Had 12mm all around. It will be tight to put a 15mm in the rear.
      11-07-2011, 03:19 PM   #3
bmwmck
Drives: Beater
http://www.1addicts.com/forums/showthread.php?t=575069
he's got 12front, 15rear. and he's lowered on H&R springs
i've seen a ton of others on the forum run different specs, do a quick search
      11-07-2011, 03:55 PM   #4
MusclezMarinara
Drives: VALNCYA
Ill re search
      11-07-2011, 06:37 PM   #5
M3 Adjuster
Albania
7905
Drives: 1M, X1 M Sport, E46 325ic
Thinking about
12MM REAR
15MM FRONT
Thoughts?
Just to have a wider track? or for looks?
      11-07-2011, 07:09 PM   #6
MusclezMarinara
Drives: VALNCYA
Thinking about
12MM REAR
15MM FRONT
Thoughts?
Wider track but i do not want to have issues I know sometimes spacers have influence on driving, whether it's vibrations or balance problems.
      11-07-2011, 07:11 PM   #7
Pete_vB
Pete_vB's Avatar
Drives: '69 GT3, GT4, 1M, 912
Wider track but i do not want to have issues I know sometimes spacers have influence on driving, whether it's vibrations or balance problems...
....steering feedback and weight, high speed instability...
1M, GT4, 1969 Porsche 911 w/ 997 GT3 Cup Motor (435hp & 2,100 lbs)
      11-07-2011, 10:27 PM   #8
bmwmck
Drives: Beater
... will not be concerns
      11-07-2011, 10:31 PM   #9
nicoz
Drives: 1M
Some are having rubbing issues with 12mm Front.
      11-07-2011, 10:35 PM   #10
bmwmck
Drives: Beater
i've heard at full lock + lowered suspension
      11-07-2011, 10:56 PM   #11
Pete_vB
Pete_vB's Avatar
Sorry, but have you ever hear of scrub radius?
      11-08-2011, 03:56 AM   #12
Advevo
Drives: M2 Competition, E30 M3 DTM
yeah you need to scrub you're balls in a bigger radius when you have spacers.
      11-08-2011, 07:35 AM   #13
James T. Kirk
Captain of the Enterprise
James T. Kirk's Avatar
Drives: 2011 1 Series M Coupe
I pursued getting spacers with my tuner and they were emphatic that it would cause issues such as vibration and imbalance. I was really pushing the agenda and they were absolutely certain that it would not be good down the line.
2011 1 Series M Coupe VO M3 vs 1M Comparo Review
2011 M3 E90 DCT ZCP (sold) * 2010 335i Sedan (sold)
2005 M3 Convertible (sold) * 2003 325i Sedan (sold)
      11-08-2011, 07:38 AM   #14
MusclezMarinara
Drives: VALNCYA
Ill take this into consideration . Thanks Guys.
      11-08-2011, 07:41 AM   #15
James T. Kirk
^ I was sad about it, too. I would have loved to push out the rear track a bit more than the front.
      11-08-2011, 08:41 AM   #16
MusclezMarinara
Drives: VALNCYA
Maybe well just add 305s
      11-08-2011, 08:55 AM   #17
James T. Kirk
That'll work!
      11-08-2011, 08:58 AM   #18
v1k0d3n
v1k0d3n's Avatar
Drives: M2C /// (and x3 for the wife)
i'm not really a huge fan of spacers unless you change your wheel out (smaller/etc). i've had some bad experiences (balance and vibration problems) with spacers on stock wheels...not sure about the 1M though, but I'm not in a rush to change things unless others have said it's a tried and true solution. i think most of the guys that have tracked with spacers also have been on different wheels setups. is this correct?
      11-09-2011, 08:14 AM   #19
MusclezMarinara
Drives: VALNCYA
Here are mine installed no issuse shown at this time...will know more once on the highway at highway speeds.
But up to 60mph no issues
12MM REARS ONLY NO FRONT SPACERS
      11-09-2011, 08:25 AM   #20
Laguna01///M3
IG @WBucco
Laguna01///M3's Avatar
Drives: '22 PB G80 6SPD
Justin (JJSchmooze) has 12mm all around. Lowered on KW Sleeve kit it slightly rubs the wheel well liner on the passenger side during full lock turns. I've been in his car at speed, and there is no vibration.
-Walter
      11-09-2011, 08:33 AM   #21
JJSchmooze
I'm on that Orange Crush
JJSchmooze's Avatar
Drives: 1M Coupe VOP ZCV ZPP
Ohhhhhhhh the scrub man is back. This reminds me of a long winded conversation we had......
http://www.1addicts.com/forums/showt...Dropped+Spaced
“Speed has never killed anyone, suddenly becoming stationary... that’s what gets you.” Jeremy Clarkson
      11-09-2011, 08:53 AM   #22
v1k0d3n
v1k0d3n's Avatar
I think the issues were a little different though. There was more concern with the spacers and dropped setup vs just one or the other though, right? not sure...my memory is hazy, but god...I remember that long drawn out feud.
1addicts
