E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > DINAN is coming out with a tune for the d
      08-04-2011, 07:50 PM   #1
cssnms
cssnms's Avatar
Drives: 2011 BMW 335d
It appears all of those e-mails to DINAN paid off! See below e-mail from DINAN. No details on power gains, pricing, or when it will hit the market, but there is rumor it should be out in the next few months. Good news for those concerned about their warranty or that don't care to risk their engine, fuel pump, etc running a piggyback.
"Hi Chris,
It is true.
Performance Software for the diesels is in development now along with suspension for the 335d. No ETA yet from engineering.
I would suggest signing up for the DINAN Newsletter as it will have the latest news and product releases. The sign up form is located on the dinancars.com home page on the right hand side.
Thanks!
Brian"
      08-05-2011, 07:22 AM   #2
maswastage
Resident Diesel Junkie
maswastage's Avatar
56
Drives: 2010 AW 335d
This is good news indeed. A tune from Dinan is sure to be more expensive than something like the JBD, but should allow you to keep your warranty.
      08-05-2011, 11:22 AM   #3
EYE4SPEED
Ex-Diesel Driver
EYE4SPEED's Avatar
Drives: Audi SQ5
Who will service the warranty - your dealer or your authorized Dinan dealer?
      08-05-2011, 01:23 PM   #4
cssnms
cssnms's Avatar
Your BMW dealer and if the dealer doesn't cover it because they believe the problem is a result of the tune, then DINAN will cover the costs. More info on the DINAN warranty can be found on their website.
      08-14-2011, 09:36 AM   #5
BillyG335d
DIESEL POWER
BillyG335d's Avatar
JBD
Chris, how is your car running? I spoke with one of the DINAN reps at Bimmerfest and he couldn't give me a date for a Diesel ECU flash. He said they were aware of the demand but they are so busy with other projects. He had nothing good to say about the JBD. He said it was junk and that you could buy a resister at Radio shack that would do the same thing. He went on about how it was just tricking the motor into thinking it needed more fuel etc.??? He still didn't change my mind, I may just have to get a JBD?
http://www.e90post.com/forums/showthread.php?t=569884
      08-14-2011, 10:14 AM   #6
cssnms
cssnms's Avatar
Hey Bill, The car is running great/strong!
As for the JBD, most of us running the JBD know what it is and how it works. Yes it's a resistor which tricks the ECU into delivering more fuel, which is a method common for diesel piggybacks. Is it the best way do go about making more power, absolutely not. An ecu reflash would be the best way whereby the ECU would be preprogrammed to tell the fuel pump when to deliver more fuel as well as adjust for injection timing and boost. That said, it is a rather benign way to get more power IMO, esp if run at the default setting.
Unfortunately, there are not a lot of options out there for us US diesel guys, as I am sure you know. There are a couple of shops that offer a "resident" flash tune, but the warranty risks running a tune that cannot be reversed are to great. What is great about the JBD (aside from the increase in power) is that it is easy to install and uninstall leaving virtually no trace that it was installed, that coupled with the fact it is relatively cheap.
I am anxious to see what Dinan comes out with and what kind of power gains we could expect to see. I suspect the gains will be conservative and more in line with the JBD default setting and VAC module, but it will cost 4 or 5 times as much. Rumor has it, they will come out with the tune prior to the end of the year. I have also sent ESS tuning a couple of e-mails and they said they may also consider working on a flash tune via a handheld programmer if there is enough interest. The first company that comes out with a flash tune via a handheld programmer will get my business.
      08-14-2011, 10:32 AM   #7
naamanf
Drives: '14 550i '10 MDX '79 TA OH-58D
Is the JBD really just a resistor network? There is more in the box than just a resistor and pot. Unless the PIC is just for show then there is more going on in there. I guess a couple seconds of pocking around in there with a DMM should provide the answer.
335d M-Sport/Everything + Individual, 550i M-Sport ED APR 2014
      08-14-2011, 11:18 AM   #8
cssnms
cssnms's Avatar
Yes, it functions by tricking the ECU into thinking that not enough fuel is being delivered, as a result the ECU sends a signal to the fuel pump to pump more fuel, thus the fuel pump increases pressure to pump more diesel. Increasing fuel delivery is how diesels make extra power. There are a couple of ways to go about doing this; 1) by increasing injection timing (ECU flash) or 2) by increasing fuel pressure (piggybacks).
      08-14-2011, 01:51 PM   #9
Mike@N54Tuning.com
Joint Chiefs of Staff
Drives: 2007 335i, 2015 M3
The JBD uses a 18F23K22 (8-bit) processor. Good luck tuning the D with resistors as it requires many non-linear functions. Tuning the diesel
isn't rocket science though and the overall function is much simpler than say the JB4 piggyback used to tune the N54 turbo motors. But the results speak for themselves and it's hard to beat the value. Diesels running full (and much more expensive) DME flashes which are verypopular in Europe are not running substantially faster than the JBD and in some cases slower.
Mike
      08-29-2011, 04:30 AM   #10
BillyG335d
DIESEL POWER
BillyG335d's Avatar
I am reading that BMW is not sending over a F30 Diesel to the U.S. I hear they are keeping the X5d and possibly bringing over the X3d and 7 series d. Sounds like the 2011 335d may be the last of its kind for awhile. Not sure if that' good or bad news for us 335d owners. It also means that aftermarket tuners probably aren't to exited to spend a lot of time and money in R&D for this motor. I think these car may increase in value and due to their limited production. Lets hope so because I may have this car for along time. I see 10X more M3's on the road than 335d's and I like that!
      08-29-2011, 11:57 AM   #11
EYE4SPEED
Ex-Diesel Driver
EYE4SPEED's Avatar
Drives: Audi SQ5
What about the 5XdM or whatever they call it? If our cars are more collectible, hopefully I can get more when they bring over the 5 series D in 2012.
      08-29-2011, 12:10 PM   #12
hotrod2448
grand poobah
hotrod2448's Avatar
Drives: F80 M3, F10 535i
2011 335d  [0.00]
What is with the giant picture?
      08-29-2011, 12:23 PM   #13
Ron1n
Speed Demon
Ron1n's Avatar
Drives: 2021 M5C
2021 M5 Competition  [0.00]
2016 BMW 550i  [0.00]
2011 335is  [0.00]
2009 E93 M3  [10.00]
2010 335d  [9.50]
Tryin to show off his l337 matte black badge replacement? (just messin, man)
Current: '21 M5C, '15 X6 50i Previous: '18 M550i, '16 550i, '11 335is, '09 E93 M3 DCT, '10 E90 335d, '07 E90 328i
      08-29-2011, 12:27 PM   #14
taibanl
taibanl's Avatar
281
Love the black badging!
      08-29-2011, 12:58 PM   #15
Ron1n
Speed Demon
Ron1n's Avatar
Drives: 2021 M5C
2011 335is  [0.00]
2009 E93 M3  [10.00]
2010 335d  [9.50]
Yeah, I'm kinda partial myself.
      08-29-2011, 04:30 PM   #16
hotrod2448
grand poobah
hotrod2448's Avatar
2011 335d  [0.00]
Yeah, I need to order the gloss black badging and the painted reflectors.
      08-29-2011, 04:57 PM   #17
Ron1n
Speed Demon
Ron1n's Avatar
Drives: 2021 M5C
2011 335is  [0.00]
2009 E93 M3  [10.00]
2010 335d  [9.50]
I really disliked the look of the deflectors, so I passed...I also prefer the matte black over the glossy (my grilles are matte black, too). Obviously my preference, and wouldn't knock someone else for theirs, as long as it's tasteful.
      08-29-2011, 08:16 PM   #18
hotrod2448
grand poobah
hotrod2448's Avatar
2011 335d  [0.00]
My car has the gloss black trim so, I think the gloss black badging will go well.
      08-30-2011, 12:22 AM   #19
taibanl
taibanl's Avatar
281
Hmm...wondering what it would cost to retro an entire gloss black setup onto my D. Bet it would look sick on Vermillion Red!
      03-13-2013, 10:23 AM   #20
corbin
Drives: 335d 2010 & x5d 2012
Reviving an old thread. Was searching the forums and saw this, so I called dinan and talked To a rep, who was towing the line about "we can't release any info on things we are working on". What's the consensus? Thinking its just a pipe dream because iftheyhavent come up with anything yet, then why would they now?
      03-13-2013, 10:25 AM   #21
crazyinp
crazyinp's Avatar
2022 BMW X5e  [0.00]
2023 BMW X5M  [0.00]
They have been "working on" for over 2 years. At that point I don't believe we will see anything.
      03-13-2013, 10:32 AM   #22
Puerto Rican 335d
Puerto Rican 335d's Avatar
Puerto Rico
229
Drives: Montego Blue 335d
Billy you should of put the "D" in red like I did, it would really stand out MORE w the matte black numbers
Chris this is great news I once inquired about this to DINAN and they had told me that they were not in the making of it, good thing is warranty wont be void but EXPECT to pay prices a la RENNtech or more. I gather DINAN is getting ready for the INFLUX of new DIESELS in the BMW stables and hopefuly those who still have the 335d's can reap benefits for it.
RENNtech Flash(Lenny Wu)/WAGNER IC
Enkei Rajin 18"/Execuhitch Hitch/Koni FSD
Soft Ride Bike Rack/Brava Synthetic Motor Oil(Made in Puerto Rico)/Meth(in the works)/CBU done w Andrew EGR Race Pipe (whoa! what an animal it is now)
e90post
