07-11-2011, 12:35 PM | #1 |
Rep 21,240
F30 3-series Won’t Get Turbo 3-Cylinder N37 Engine. Bound for FWD 1-series Instead
BIMMERPOST NEWS F30 3-series Won’t Get Turbo 3-Cylinder N37 Engine. Bound for FWD 1-series Instead BMW's research and development head, Klaus Draeger, has confirmed that future BMWs will indeed utilize new turbocharged 3-cylinder gas and diesel engines. This begs the question which future models will receive these 3 cylinder motors. According to Draeger (via Autocar), the upcoming FWD 1-series models will receive the 1.5L turbo 3-cylinder and not the F30 3-series (at least not initially?) “They are not a priority for the 3-series,” Draeger told Autocar last week. “We’ll start with the front-wheel drive architecture and more price-sensitive models.” Instead, the smallest engine we expect to see for the F30 3-series in the US is the 245hp 2.0L turbo 4-cylinder N20 engine. Draeger revealed that the petrol version of the engine, known internally as N37, has the potential to match the maximum 54bhp-per-cylinder rating of the firm’s recently introduced turbocharged 2.0-litre, four-cylinder N20. This suggests range-topping versions of the new triple will develop up to 160bhp. The key to the new engine’s efficiency, says Draeger, is its capacity-to-surface-area ratio, which he describes as being better than any existing BMW engine for thermal performance. In a bid to dispel the idea that three-pot engines are used for cost-saving, Draeger said, “The three-cylinder engines are not cheap. They are every bit as hi-tech as our four and six-cylinder engines.” We previously reported that this 3-cylinder engine range (gasoline and diesel) will receive the TwinPower Turbo treatment. The TwinPower Turbo package combines a single twin-scroll turbocharger, direct injection and full variable valvetronic. It first debuted on the N55 motor in the 5-series GT in 2009 and most recently on the first 4-cylinder motor, with the 2.0L N20 gasoline engine in the X1 xDrive28i. The use of this technology allows for increased horsepower while decreasing CO2 emissions. As an example, the N20 outputs 245hp compared to just 156hp from the naturally aspirated version. |
07-11-2011, 01:08 PM | #2 |
Rep 1,855
Don't know much about engine dynamics, but isn't a 3 cylinder inherently imbalanced?
///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust |
07-11-2011, 01:16 PM | #3 |
Rep 9,134
07-11-2011, 01:31 PM | #4 |
Rep 409
it'll likely have a balance shaft similar to what benz uses in their v6's (272 motor). although, benz runs theirs down the valley, which isn't really possible on an I3... who knows what BMW might do?
| v3.0si | | '08 Z4Coupe 3.0si | BMW Aero | BMW Performance |
07-11-2011, 01:42 PM | #6 | ||
Rep 19,368
Globally, I would be very surprised if we don't see a 320i with the lower output 184hp N20B20 recently confirmed for the Z4 20i and 520i. Additionally, I suspect some markets will get the two versions of the new smaller I4 that are slated for use in the F20 116i and 118i respectively. In fact, with the 1.6L I4 in the mix, it is no surprise that the three cylinder is not a priority yet since the 1.6L can cover that market for now. Quote:
I think the new I3 will introduce the new shared engine architecture which is said to yield almost 70hp per cylinder (0.5L standard cylinder displacement across the lineup). |
07-11-2011, 02:18 PM | #7 | |
Rep 876
I don't know but I think if you use all the balance shafts in the world, the engine will still vibrate.
07-11-2011, 03:44 PM | #8 |
Rep 2,612
Drives: F30 328i Luxury - Sport Auto
1 "Life is too short for front wheel drive" - Sabine Schmitz whilst driving the E60 M5 around the Nurburgring.
Gone: 2006 BMW E60 520d SE 6MT Gone: 2009 BMW E90-LCI 330d SE 6MT Current: 2012 F30 328i Luxury 8AT On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!) |
07-11-2011, 04:06 PM | #9 |
winter mode
62
Rep 2,057
Drives: 08 135i, 88 M3
this
88 M3: BMWCCA J Sport
08 135: because streetcar |
07-11-2011, 09:10 PM | #11 |
Rep 420
07-12-2011, 03:55 AM | #14 |
Rep 985
I thought this tread was about the new 3 sylinder engine.
Not FWD? Oh well, i suppose BMW should rather give up, than follow EU regulations and other (stupid) CO commisions. There is a need for such actions people, it doesn't mean you have to buy them though, but i can assure you, some will, and coming from BMW, these engines will sure be good, and most of all, others will follow. It's not like BMW will be alone making 3 sylinder engines, and small FWD cars, look at A and B class from MB. Rant over?
3 series: E30: 89 325i, E36: 92 325iC, 94 320iC, 96 320i Convertible, 94 320iaC, E46: 99 320ia, E90: 06 318i Le mans, E91: 07 318dt
5 series: E39: 97 520ia, 01 530Dat, E61: 09 520Dat X series: E83 05 X3 2.0d, E84 10' X1 2.0 X-drive DA, F25 13' 2.0da X-drive. |
07-12-2011, 11:05 AM | #15 |
Rep 1,712
FWD made by a company such as BMW... its the principle of it that saddens me.
FWD cars isnt bad or anything but it will always underperform compared to RWD. law of physics is firm on that. for a purist car company such as BMW to do that... saddens me. ah the tragedy. |
07-12-2011, 07:56 PM | #16 | |
Rep 602
BMW Performance Exhaust, Michelin Pilot Supersports F-225/40, R-255/35, BMW Performance Suspension, BMW Performance black kidneys, Quaife LSD, M3 rear sub-f bushings, M3 front control arm, rear guide rod and rear upper link kits, BMW Performance cross-drilled/slotted rotors, AFE Cold Air Intake. |
07-13-2011, 03:24 PM | #17 |
Rep 104
07-14-2011, 04:04 AM | #18 |
Rep 169
^ Indeed
This doesn't make any sense, with the 3 series getting ever bigger, the 1 series was beginning to replace it in terms of being small compact sporty - but making it FWD immediately cuts off that progression, perhaps that is the thinking behind it - by giving the 1 series a step backwards in handling/driving, it keeps the 3 series on top... Having said that, we must try to keep a little faith in BMW, we are after all, good fans - perhaps their decisions are for the best, only time will tell |
07-14-2011, 07:32 AM | #19 |
Rep 805
Drives: BMW 335i
I don't like the idea of FWD with BMW, but looking to all what's going on to automarket they have a point maybe!
I can't resist the BMW drive, even the smallest 1 Series is something special...don't know what will look like with FWD! 160 bhp from 3 cylinder is very nice actually!
The Best Is Yet To Come!
E36 - E39 - E53 - E60 - E87 - E90 Last edited by Pentium; 07-14-2011 at 07:44 AM.. |
