      06-16-2011, 07:38 PM   #1
HP Autosport
Supreme Allied Commander
Drives: F80 M3
AST 4200 Monotube Double Adjustable Coilovers for 1M and M3
Here is our AST 4200 with Swift springs and Vorshlag camber plates for our project 1M.
Shown with optional adjustable front strut mount, rear quick change spring kit(with helpers and radial thrust bearing) and remote rear rebound adjusters.
The 4200 Series shocks use AST’s Twin Piston Dual Adjust (TPDA) technology. Similar non adjustable versions have been found in the highest forms of racing. TPDA builds on this technology to allow for 2 adjustment knobs to be mounted on the shock body (no tools required). Quick rebound and compression changes can be made in the pits in seconds. 4200s are fully customizable and rebuildable.
AST-USA offers full rebuilding and revalving services for AST shocks at competitive prices. This includes quick turn around when you need it the most.
Benefits include:
Monotube design - gives the biggest piston sizes available
Floating piston design with high pressure nitrogen means no cavitation around the piston
Compression and Rebound adjuster knobs permanently mounted on the dampers – no fumbling for knobs
Fully threaded strut bodies allow maximum tire width without fender rolling or larger spacers
Rebuildable by AST-USA – get the valving you want, when you want it.
» Rebound and Compression Adjustable, without reservoirs ("Internal Doubles")
» 22mm diameter shaft struts, non-inverted
» Adjustable flanges on struts for ride height without disturbing suspension travel
» Aluminum threaded cylinder shocks, non-inverted
» Spherical lower "eye" shock mounts
» Optional spherical upper shock mount assemblies
» Synthetic hydraulic fluid
» Designed for racing classes that require any adjustment be internal ("no reservoirs")
      06-17-2011, 10:49 AM   #2
hwelvaar
Belgium
112
Drives: BMW M135i MT
LOL at your picture !!
      06-28-2011, 11:05 PM   #3
HP Autosport
Drives: F80 M3
Those are thrust sheets.
      06-29-2011, 10:44 PM   #4
cpt97m3
AutoXer
34
Drives: 2009 135i
In the shape of a competitors logo...
2009 135i, Alpine White, 6MT, M-Sport, iDrive, iPod/USB, Heated Seats, Premium Sound, BMW Assist
      06-30-2011, 09:15 AM   #5
TUNEDM3
Stay Ripping
60
Drives: 1M
You mentiom this kit is also for the m3, has it been 100% confirmed that the suspensions are identical and kits are
Interchangeable? I am aware kw is releasing completely different part numbers.
THE GOBBLER- S.O.H
      07-01-2011, 12:36 PM   #6
TUNEDM3
Stay Ripping
60
Drives: 1M
Any word as if the 1m and m3 are
The same fitments?? Do you have the ast kits in stock?
THE GOBBLER- S.O.H
      07-02-2011, 09:39 PM   #7
Dan Parker
Drives: 2012 Golf R
They are the same.
HP, how does this ride vs. stock? I'm considering AST but I don't want to lose a lot of the ride quality on the street. I race so I don't intend on tracking this car much. Mind telling me/us what the spring rates are?
Dan Parker
      07-03-2011, 01:07 AM   #8
M3 Adjuster
Albania
7906
Drives: 1M, X1 M Sport, E46 325ic
Dan... AST has EXCELLENT ride quality... I have a set on my E30 M3. I could drive it on the street to work... yet with 700/850 spring rates, it's set up well for the track.
It doesn't hurt that their headquarters for USA are here in DFW and that I know the owner personally..
They aren't infallible.. but they make excellent products, and they back it up with great service... ask Eric Heinrich how they came thru for him at Ofest year.
      09-06-2011, 10:38 AM   #9
HP Autosport
Drives: F80 M3
4100s are in stock.
4200s are custum built and takes 6 weeks.
Originally Posted by Dan Parker View Post
They are the same.
With proper spring rates the AST ride is about the same as stock but with more control. Damping force is generated very quickly with the ASTs and you can get away with slightly lower spring rates for comfort.
Spring rates will be tailored to each individual. You can also see the rates stamped right on the springs in the photo.
Tags
ast 4200, bmw 1m, coilovers, swift springs, vorshlag
1addicts
