05-18-2011, 03:20 PM | #1 |
429
Rep 4,650
♦ Sonic MS | MORR SpunForged VS8.2 Competition Wheels
Sonic Motorsports 1045 West El Camino Real Mountain View, CA 94040 tel: 650-733-6506 fax: 650-691-9009 email: info@sonicms.net We at Sonic MS are proud to present MORR's SpunForged VS8.2 wheels. MORR Competition Alloys MORR Competition Wheels was established in 2005 and has since managed to position itself as an industry leader and innovator in Craftsmanship, Performance, Aesthetics and distinctive innovations. MORR Competition Wheels designs and engineers its own line of ultra-light weight performance wheels for high-end automobiles. Our main product lines, MonoForged™ and SpunForged™ are not only designed to improve your vehicle's performance but to equally enhance your vehicle's appearance. Since its introduction in the market MORR has developed wheels that are tailor-made for every application and designed one-hundred-percent based on direct customer feedback. Every wheel is handcrafted exclusively to each vehicle allowing us to engineer a wheel based on specific diameters, width, offset, back pad thickness, brake clearance, and most important load rating. This company culture helps us to provide key breakthroughs in design and engineering that result in unique ultra-light performance wheels that have since their inception become industry icons. Spunforged Technology - Technical Information The new SpunForged product line is lighter, wider, and stronger than its predecessors. The new VS8.2 weighs approximately 8.87-kg (19.52-lbs) making it about 1.03-kg (2.26-lbs) lighter than the MonoForged VS8. This weight reduction was achieved by implementing several advanced manufacturing processes including flow-forming, which reduces barrel thickness by up to ten-percent, Vehicle Specific Profiles (VSP) and Finite Element Analysis (FEA) by using Vehicle Specific Load Ratings (VSLR) and Vehicle Specific Weight Optimization (VSWO). Vehicle Specific Profiles (VSP) & Vehicle Specific Weight Optimization (VSWO): By y using VSLR and VSWO, weight can be reduced by eliminating the need of using excessive load ratings due to the wheel blanks being shared with higher rated platforms. MORR manufactures wheel blanks exclusively for every design it produces, allowing us to engineer the blanks according to the specific load ratings of the vehicle brand & model we are making the wheel for. This in turn increases our production costs, but allows us to make a far superior wheel. Vehicle Specific Profiles (VSP): Through VSP, we can minimize excessive back spacing in our wheel blanks. Adding material to the back pad is required when sharing blanks among different platforms, increasing the weight and required excessive machining of the back pad which could compromise the integrity of the final product. Our SpunForged blanks are vehicle specific, thus requiring minimum machining of the back pad, resulting in a lighter wheel without compromising its integrity. Finite Element Analysis: During the design stage, our engineers run FEA simulations to ensure the weight optimization process does not sacrifice wheel strength. To ensure our wheels are ultra-lightweight and equally as strong, our SpunForged product line is manufactured using only the highest grade 6061-T6 Aluminum. All of our wheels conform to the strict international standards of wheel quality and manufacturing, which include VIA/JWL and TuV-Rheinland. Our SpunForged VS8.2 is rated at the new safety standard of 690-kg (1520-lbs) per corner; an increase of 30-kg over the previous standard, making the wheel significantly more resistant to load. Our MonoForged and SpunForged are also subject to extensive Rotary Bending Fatigue, 13-degree Impact @ 0-degrees, 13-degree impact @ spoke, Radial Load Endurance and Radial Load Fatigue physical testing. MORR SpunForged VS8.2 - 7-Spoke Monoblock T6061-T6 Aluminum Alloy - Spunforged Technology results in a lighter and stronger wheel - Front Weight - 19.52 lbs (19x8.5) - Rear Weight - 23.88 lbs (19x10) Standard Finishes - Sparking Silver - Smoked Titanium - Signature Silver - Signature Black - Midnight Black Custom Finishes - Gloss Black - Satin Black - ...and more, please contact us directly for more information. Recommended Fitment for the E89 Zer 19x8.5 ET35 19x10 ET36 225/35/19 255/30/19 We also offer full rim and tire packages including OEM TPM sensors. We utilize the Hunter Road Force GSP9700 Balancer and “Touch-less” Auto 34 Mounting Machine to mount and balance your rims and tires safely and effectively, without risking any damage to your new investment. Recommended Tires: *Please click on link for more information on the tire, including pricing. Kumho Ecsta SPT 19 inch Setup Yokohama S DRIVE 19 inch setup Yokohama ADVAN Neova AD08 19 inch setup MSRP Pricing 19 inch - $3550.00 / set Custom Powdercoat Finishes - Add $400.00 per set *Prices listed do not include shipping and/or tax if applicable. For best pricing and ordering information, please call me at 650.733.6506, email at cal@sonicms.net or shoot me a PM. |
