E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > 335d muffler delete
      05-09-2011, 10:19 AM   #1
nate82
nate82's Avatar
Drives: like John Force
2011 335d  [0.00]
335d muffler delete
I just picked up an '11 335d. A few of my friends have diesel trucks and have deleted the mufflers on them and have measurable hp and torque gains. Has anyone done this on a 335d or X5d and with any gains? What do you think?
      05-09-2011, 10:25 AM   #2
MisterSkiMask
Drives: I Can not say
ohferchrissakes
      05-09-2011, 11:05 AM   #3
Bakeme521
Some say...
Bakeme521's Avatar
Drives: Fresh
2007 BMW 335i  [8.24]
Try it and get back to us
I have exhaust and an intake...
      05-09-2011, 12:28 PM   #4
DieselDiner
DieselDiner's Avatar
486
Drives: 335d
Most of the back pressure on the d is further upstream around the DPF. You cannot remove the DPF. So - if you remove the mufflers, you might succeed in making your car noisier, but probably won't succeed in gaining much power.
      05-11-2011, 11:25 AM   #5
nate82
nate82's Avatar
2011 335d  [0.00]
Thank you. That's more the answer I was looking for.
      05-13-2011, 10:11 PM   #6
rizzo2008
Drives: BMW 330ci ZHP e46
Actually you could remove the DPF and Urea injection if someone figures out an engine coding or external tuner that could remove the error codes associated with removing those items (of course that will void your warranty but I imagine some people don't care). It is very common with new diesel trucks (albeit illegal but impossible to enforce) where owners will take out the DPF and/or eliminate urea injection with a new engine coding. So far I haven't heard of a similar coding for the 335d US spec car though. Perhaps I'm wrong have any tuners managed to do any of the following on US spec diesel cars or SUVs?
1. delete the DPF with a straight pipe
2. eliminate/disable urea injection
3. bypass/delete the egr system
4. replace the swirl flaps with fixed plates
5. do any of the above and code to eliminate errors/check engine lights?
      05-13-2011, 10:28 PM   #7
Forcefed3
Drives: 2008 335i
2008 335i  [1.00]
F-335i
      05-14-2011, 04:57 PM   #8
rizzo2008
Originally Posted by gbreeE90 View Post
F-335i
Is that a company?
      05-14-2011, 05:25 PM   #9
N55 Power
N55 Power's Avatar
Tajikstan
11
Drives: 2011 135i
F-335i
Is that a company?
JFK, f-350? see how that could be slighlty modified to sound like 335i?
I own a f-250 with a dpf/cat delete and i have a h
      05-29-2011, 11:01 PM   #10
rizzo2008
Well has anyone heard of this? Seeing as nobody's warranty on a 2009 car has run out maybe these mods will become more common as the first warranties expire in 2013.
      06-02-2011, 09:05 AM   #11
DieselDiner
486
Drives: 335d
It's been done now across the pond: http://www.e90post.com/forums/showthread.php?t=535271
      06-03-2011, 11:38 AM   #12
rizzo2008
So the programming is there for the DPF delete but they don't have the urea/adblue system in European cars do they?
      07-19-2011, 04:40 PM   #13
Quasimodem
Quasimodem's Avatar
Drives: 335d
2009 335d US  [0.00]
I dont lurk in the UK forum much, but I just saw a discussion where they were discussing a 335d with DPF failure and forcing a "regen". I may be mistaken, but that seems to imply a DEF system. Is there a regen for DPF systems without DEF? Maybe they have some other way of purging the DPF of soot besides using DEF.
Speakers: CDT Audio HD-42 comps--front doors (RAAMmat deadened), CDT ES-06 6.5" woofers--kickpanl Pods, Hertz EBX202R dual 8" ported trunk sub. Amps: Phoenix Gold RSd 500.4 (comps & pods). PG RSd 600.1 (sub). Power & Ground: 4AWG Streetwires w/RockFosgt RFDB1 distro blocks. Input: HU lineout--Kicker KISL RCA adapters--RockFosgt RFIT-6 cables--Audiocontrol Matrix--Monster cables--RSd 500.4--lineout Monstr Cabl to RSd 600.1.
      07-20-2011, 10:42 AM   #14
maswastage
Resident Diesel Junkie
maswastage's Avatar
56
Drives: 2010 AW 335d
Quasi, I think you may be a bit confused. The DPF regeneration is separate and independent from the DEF injection. The DPF physically catches particulate matter, which is periodically burned off. The DEF is injected into the exhaust to react with and neutralize nitrogen emissions.
The European cars must still undergo he DPF regeneration process even though they don't have DEF systems.
      07-20-2011, 01:50 PM   #15
Quasimodem
Quasimodem's Avatar
Drives: 335d
2009 335d US  [0.00]
Not confused, just ignorant. So then the regen is something accomplished by the engine system without any DEF injection. Interesting. The thread I was reading had all kinds of advice about driving certain speeds and whatnot to allow the vehicle to do a proper "regen". I wonder if US 335ds could be reprogrammed as European 335ds so that they can do the non-DEF regen. But from the problems being discussed on the UK forum, it appeared that tne non-DEF regens were not that reliable since some apparently had their DPF plugged up. Possibly caused by driving the car short distances or in a type of driving which did not allow it to accomplish the required regens. So maybe the DEF system is best as well as being cleaner.
      07-23-2011, 08:01 AM   #16
Hotcoupe
Hotcoupe's Avatar
Drives: Don't know yet!
I've been running a straight through exhaust on my 335D's since 2008, all three mufflers (centre & two rear boxes) have been removed.
In terms of performance gains you can expect approx 18-20bhp increase with little to no gain in the torque figure.
My car is currently running at 363bhp and 500lbs torque measured on a Dyno Dynamics rolling road.
My previous 335D running the same map and the stock exhaust system ran at 345bhp with the same 500lbs torque.
Note: UK 335D's stock figures are 286BHP and 425lbs torque.
Never argue with an idiot on the internet. He will drag you down to his level and beat you with experience.
      07-24-2011, 06:13 PM   #17
itsbrokeagain
itsbrokeagain's Avatar
Drives: 1999 528iT, E53 X5, E46 325xi
Holy crap thats a lot of torque...
      12-07-2014, 09:38 PM   #18
Bimmerx53
Drives: Bmw e70 x5
I'm wanting to do the same thing you did except to my e70d, how good does it sound with just the three (In my case 2) mufflers deleted?
I've read that as long as the DPF is still on, removing the mufflers won't make much of a difference
      12-08-2014, 02:26 AM   #19
Yozh
Yozh's Avatar
Drives: 2011 335d M-Sport
If you dig though a DPF Delete thread you shall find a video of an E90 with mufflers and DPF deleted. Should be similar.
      12-08-2014, 03:31 AM   #20
Si-M240i
Drives: M240i LCI
I have all 3 boxes deleted and Wagner FMIC and remap and just North of 380bhp and around 620 torque.....its a beast. When I had the remap tweaked after fitting the fmic and exhaust I gained a further 20bhp over the original remap on the car when stock
      12-08-2014, 03:33 AM   #21
Si-M240i
Drives: M240i LCI
The sound is slightly louder and sounds more sporty in the cabin. The DPF and cats cut the volume so the 3 mufflers do very little
      01-20-2016, 12:49 AM   #22
1edyson
1edyson's Avatar
Philippines
68
Drives: 2010 335d
Bringing back a thread from the dead here...but does anyone have any sound clips of the muffler delete on the 335d? I'm thinking of doing this while I wait for additional exhaust options
e90post
