N55 DP Sensor Clearance Issues
04-09-2011, 01:58 AM | #1 |
Rep 1,217
Drives: 2014 435i
I'm having trouble getting my downpipe out, everything is unbolted including the clamp, but every time I pull the dp down the lower o2 sensor hits the transmission mounting bracket before it is able to clear the bolt. Are people unbolting the sensor before removing the downpipe? Or do you pretty much have to remove the transmission mounting plate. I'm afraid I'm going to damage the sensor if I keep trying to pull the dp out with it plugged in, but I can't see how you would unbolt it while the dp is installed.
04-09-2011, 02:59 AM | #2 |
Rep 8,801
Pull the clamp off completely.
The DP should pop off and u should be able to drop it. Just muscle it a bit, u're almost there.
FrankiE90 AKA:.[The TANK] *CLICK THE SIG
E90s (been gone but not forgotten) • KW clubsports • • • • • • • • • • 18" BBS GT4 // Build E30 (pending) + E46 M3 Wagon ESTORIL Blue |
04-09-2011, 09:35 AM | #4 |
Rep 1,035
The plate that bolts to the DP and trans I completely remove. I also just unscrewed the o2 sensor while it was in the car and took it out. Then removed the pipe
04-09-2011, 09:45 AM | #5 |
Rep 1,217
Drives: 2014 435i
Awesome, thanks for the help! I'll take that off.
04-09-2011, 01:32 PM | #6 |
Rep 1,343
Drives: BMW M3 DCT
I had that same problem i was going crazy!! lol ... the bracket has to come off.
04-09-2011, 03:28 PM | #7 |
Rep 1,217
Drives: 2014 435i
Any idea what size the Torx Bolts are on those brackets? Can't get my E18 to fit on there, maybe it's to thick?
