E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > Procede n55 Dyno testing
      03-23-2011, 08:10 PM   #1
OpenFlash
Drives: A Lot
Smile Procede n55 Dyno testing
From testing today...
CF: 1.05
2011 135, 7DCT
Mods: Procede v5 3-21, Vishnu DP, Vishnu Charge pipe, muffler shop cat-back with dual 2.5" magnaflow mufflers, tightened wastegate actuator
91oct
CF: 1.05
Tested in 5th gear (6mt and 7at should dyno in 4th gear)
Graphs represent the following settings:
15psi, 50%IC
14psi, 50%IC
12psi, 50%IC
Stock Tune
Observations:
-Due to turbo capacity limitations, all tuned settings make about the same power/boost above 5500rpm. So different boost settings just effect midrange and low end power/boost. The turbo is so flow limited that it will not support more than 14psi at 5000rpm. And by 6000rpm, it's down to just under 12psi. Perhaps upgrading the FMIC will reduce some pressure loss and increase top end boost/power. We will be installing an upgraded FMIC next week and will re-test.
-We found that slightly tightening the wastegate actuator helped the turbo maintain slightly more top end boost. Not a lot. Just a little (0.5-1psi) This mod is easy to do when installing a downpipe. All you need is a 10mm wrench. Shortening the wastegate rod no more than 1/4 of an inch. If you shorten it too much, you will experience overboost in the 3700-4000rpm.
-The DME refuses to let the car run beyond 6500rpm when dyno testing in 5th gear. This is because it throws a 13001 code for "Poor Road Surface" due to the fact that the front wheels aren't spinning along with the rears. Funny.
-Here's a datalog of the 15psi run:
I'll post a "how to dyno your n55" once i finish writing it. There are a few unique issues with this platform. They are worth mentioning.
Cheers
shiv
      03-23-2011, 08:21 PM   #2
IancoleTX
Dillo boxers
IancoleTX's Avatar
Drives: 2019 M5C
Very interesting, thanks for posting Shiv. Looking forward to results with the FMIC.
2019 M5C Matte MBB / Tartufo
      03-23-2011, 08:26 PM   #3
TMR
TMR's Avatar
Drives: M3
SUPER nice!
2015 M3 BPM Tuned, Eibach, Magnaflow and more www.tmrmzine.com/m3/f80
SOLD E92 Slēk Carbon Fiber Widebody M3 www.tmrmzine.com/m3/slek/
SOLD E92 335i Stage 3+ with all the toys www.tmrmzine.com/335/
SOLD E39 M5 Modded, What a great car! www.tmrmzine.com/m5/
      03-23-2011, 08:28 PM   #4
Jimefam
Drives: 2011 550I Msport
Yeah I had quite the mission when getting my N63 dyno'd. So I guess a turbo upgrade for this motor will be out asap. Nice numbers though.
      03-23-2011, 08:37 PM   #5
Clap135
Clap135's Avatar
102
Drives: 2009 N54
sucks for the n55 guys, it will be a miracle to break 400 on that stock turbo running race gas and meth.
Uncorrected this car didn't even break 340 right?
      03-23-2011, 10:39 PM   #6
MS135I
Drives: M-sport 328i
So what kind of numbers are the n54's putting out with the same exact mods as Shiv's car on straight pump? I looked through the dyno thread and didn't see many n54 hp numbers that were significantly higher with the same bolt-ons using pump. Infact, the torque numbers on the above dyno looks to be the same or better than the n54 numbers with the same mods. Maybe I am missing something here? With that said, I do realize that with meth and/or race fuel the n54 is on an entirely different level.
      03-23-2011, 10:47 PM   #7
Sniz
Sniz's Avatar
654
Drives: e92 335 - gone // e36 M3 turbo
I saw that 5,400rpm choke before I read what Shiv wrote, sucks! The midrange bump still is attractive though.
funny how BMW is only concerned with 'Poor Road Surface' after you reach well over 100mph
      03-23-2011, 10:47 PM   #8
OpenFlash
Drives: A Lot
Similarly modded (full exhaust), an n54 would probably put down 365-370whp. The n55 does seem to make bigger peak torque numbers than the n54 all other things equal. But above 5000rpm, the n54 has a considerable advantage.
I suspect/hope the n55 will support up to 360-365whp when an upgraded intercooler is installed. Which is still 30-40whp shy of what a fully modded n54 will put down on a good day.
But there is something very different about the way the n55 puts down the power. I'm not sure if it's entirely due to the 7DCT or the Valvetronic system but the n55 seems to be more responsive and faster than its numbers would indicate.
Shiv
      03-23-2011, 10:59 PM   #9
Proper Motion LLC
Custom Powder Coater
Proper Motion LLC's Avatar
147
Drives: White 335i Sedan
By the looks of that Dyno, shouldn't n55 guys be shifting b4 6000 rpm?
      03-23-2011, 11:01 PM   #10
Sniz
Sniz's Avatar
654
probably 6200ish but I have no idea of the gearing of that tranny
      03-24-2011, 02:27 AM   #11
shockin330i
shockin330i's Avatar
798
Drives: 2016 ZCP M3
subscribing
ERnie
2016 BSM/f80/ZCP
      03-24-2011, 03:26 AM   #12
edo
edo's Avatar
Mexico
53
Drives: E92 335i
Why? The dyno operator once told me that one should dyno a car in a gear that is closest to "direct" one in order to get the most accurate results. 5th gear of 6MT has 1:1 ratio, if I remember correctly.
Mods: RB turbos, JB4, BMS DCI, Scoops, Forge DVs, ar design catless DPs, Milltek exhaust system, Helix FMIC, Quaife LSD, VK MotorWerks OC Kit, Bilstein B16 PSS10
      03-24-2011, 12:04 PM   #13
OpenFlash
Drives: A Lot
Originally Posted by FastGator View Post
why 5th gr dyno instead ofs 4th?
Because 5th gear on the 7dct is geared like 4th gear on the 6at/6mt. Goes up to ~140mph. 4th gear would be a bit too short of a run.
      03-24-2011, 12:09 PM   #14
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
Someone should clue the guy in that said N55 is faster then N54 now LOL.
Its amazing how these BMW fight you tooth and nail on everything. Now it needs special instructions to Dyno. Whats next?!
      03-24-2011, 12:14 PM   #15
jpsimon
Team Zissou
jpsimon's Avatar
Drives: 2022 AWD M3 Comp - SMB
JP your avatars are always amazing.
that is all.
      03-24-2011, 12:18 PM   #16
OpenFlash
Drives: A Lot
Nothing new with German cars. Some MBs require a whole song and dance before allowing it to be dynod. What's interesting is the "road speed quality" code that closes the throttle above 130mph when the front tires aren't spinning. Sounds like an anti-dyno code to me since I can't think of a scenario were that would happen on the street.
      03-24-2011, 12:28 PM   #17
that is all.
I do what I can for the community. LOL.
Oh I know about those.
Atleast MB makes it easier. Right in the hidden menu you can select dynometer test and shut off limiters, traction control ETC ETC FTW
      03-24-2011, 12:49 PM   #18
edo
edo's Avatar
Mexico
53
Drives: E92 335i
Shiv, why 6MT should be dynoed in 4th gear?
      03-24-2011, 12:51 PM   #19
OpenFlash
Drives: A Lot
Because 5th gear would result in 160+mph roller speed which is a bit sketchy. The run would also take a really long time which would heatsoak the engine a fair bit. The idea of dyno testing in a 1:1 gear ratio is meaningless these days. Far more important is picking a gear that doesn't result in excessive torque to the tire or excessive speed to the roller.
Shiv
      03-24-2011, 12:57 PM   #20
shockin330i
798
Drives: 2016 ZCP M3
So what you're saying shiv is that you are going to make some firmware adjustments so that the 1300 code isn't tripped, correct? Lol
ERnie
2016 BSM/f80/ZCP
      03-24-2011, 01:22 PM   #21
RyanMv4
Drives: 2020 440xi
425WTQ is just unreal
2024 X5 x40i
      03-24-2011, 01:25 PM   #22
Keik E92 M3
Drives: BMW M3 DCT
2009 BMW  [9.00]
2011 BMW 335i  [6.80]
Shiv
I am going back to the dyno soon, should i dyno my 6AT in 4th Gear correct?
Also about the boost settings how would i stop it from going into valet mode?
Thanks
e90post
