E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > N55 down pipe removal
      03-16-2011, 03:04 PM   #1
Keik E92 M3
Drives: BMW M3 DCT
2009 BMW  [9.00]
2011 BMW 335i  [6.80]
This thing is a pain in the ass... I cannot seem to be able to reach the 02 sensors let alone the mounts holding it up... Is there a easier way to do this?
      03-16-2011, 03:06 PM   #2
jjurroz
Drives: 2018 F80 M3 ZCP
u don't have extensions?
      03-16-2011, 03:18 PM   #3
FrankiE90
FrankiE90's Avatar
Drives: Krooked Sk8board
go from up top - unhook the mount/clip - give u some slack for the O2 sensors.
FrankiE90 AKA:.[The TANK] *CLICK THE SIG
E90s (been gone but not forgotten) • KW clubsports • • • • • • • • • • 18" BBS GT4 // Build E30 (pending) + E46 M3 Wagon ESTORIL Blue
      03-16-2011, 04:02 PM   #4
Keik E92 M3
Drives: BMW M3 DCT
2009 BMW  [9.00]
So go from the top of the engine bay ... That will include disconnecting the stock intake pipe correct? I am going to take that.
Yes i do.
      03-16-2011, 04:24 PM   #5
FrankiE90
FrankiE90's Avatar
Yes i do.
no no.
u go from the bottom for sure.
there is no easier way, unless u have a lift.
if u're laying down u got go all the way up on that
bitch to get to the clamp. just reach up and muscle it
i thought u were having problems with the O2 sensor
have u removed the clamp yet?
      03-16-2011, 04:28 PM   #6
FrankiE90
FrankiE90's Avatar
here's a pict.
where u having problems?
edit--
also look at black e thread for downpipes.
http://www.1addicts.com/forums/showt...t=n55+downpipe
remove the bracket nut, then remove the dual exhaust bolts.
then go for the clamp.
once u get the clamp off, something it comes off easy - but
u got to muscle it to open.
then pull off the DP - you'll notice the mid bracket will hold it up til u
slide it off.
at that point remove the O2 sensors.
remember those steps.
      03-16-2011, 04:28 PM   #7
Keik E92 M3
Drives: BMW M3 DCT
2009 BMW  [9.00]
Yes I removed the 4 bolts connecting to the exhaust and removed 2 other bolts connecting to the dp to the brace and loosened the clamp to the turbo and this thing still isn't moving
      03-16-2011, 04:52 PM   #8
FrankiE90
FrankiE90's Avatar
u need to remove the clamp.
it wont come off til u do that.
the clamp, use flat head, something to lift the clamp
from where it's bolted on.
that clamp is wrap'd around the edges of that DP.
get that and it'll be off.
when u put on the new DP make sure it's
a tight fit and the clamp is on properly.
just have the clamp hanging half ways off the
fitting when u slide in the new DP. the dp should lock on.
and then close the clamp and bolt on. it'll help if u have
2nd pair of hands to hold the other end. well maybe not.
      03-16-2011, 04:52 PM   #9
Slops
Slops's Avatar
South Africa
188
Drives: 2005 C55 AMG
Jesus... Did the instructions from Robert not help you either?
      03-16-2011, 05:02 PM   #10
Keik E92 M3
Drives: BMW M3 DCT
2009 BMW  [9.00]
The clamp is half off the other side is acting like it has super glue on it it's pissing me off the bolt is completely off and half of the clamp is off the turbo and down pipe but the other half is stuck grrrr
      03-16-2011, 05:04 PM   #11
Keik E92 M3
Drives: BMW M3 DCT
2009 BMW  [9.00]
Afriad not lol... I have everything off except the sensors and half of the clamp it's a tight fit, I have huge hands.
      03-16-2011, 05:18 PM   #12
Keik E92 M3
Drives: BMW M3 DCT
2009 BMW  [9.00]
Okay got the clamp off, now just the 02sensors.
      03-16-2011, 05:18 PM   #13
Slops
Slops's Avatar
South Africa
188
That sux dude... Hope you have somebody to help. At least I'll have my brother and a lift
      03-16-2011, 05:29 PM   #14
Keik E92 M3
Drives: BMW M3 DCT
2009 BMW  [9.00]
I am all by myself wih jack stands I can't get this o2 sensor off.
Worst car i have ever worked underneath EVER! lol...
I installed turbo kits etc and this is killing me... 02 sensor removal is giving me a pain in the ass now.
      03-16-2011, 06:14 PM   #15
FrankiE90
FrankiE90's Avatar
is the clamp off?
ur almost there. just sucks with jack stands in this case
if the O2 sensor is lose and u need to twist it off.
follow that line up and unhook off the holder -
should give u some slack to twist off the senor.
edit - twist the wire with the sensor too.
      03-16-2011, 06:20 PM   #16
shockin330i
shockin330i's Avatar
798
Drives: 2016 ZCP M3
Lol be happy you aren't working on the n54. Then you'd have double he trouble...
ERnie
2016 BSM/f80/ZCP
      03-16-2011, 06:22 PM   #17
Slops
Slops's Avatar
South Africa
188
Careful with the O2 sensor as they are a lil sensitive
      03-16-2011, 06:25 PM   #18
Keik E92 M3
Drives: BMW M3 DCT
2009 BMW  [9.00]
I haven't even loosened them yet... The DP is just hanging i took a 20 min break to regain some strength.
      03-16-2011, 06:48 PM   #19
Keik E92 M3
Drives: BMW M3 DCT
2009 BMW  [9.00]
I do not see how people who removed there DP got these damn sensors off in such a small area.. This thing is not budging no matter how more force i apply..
      03-16-2011, 06:49 PM   #20
FrankiE90
FrankiE90's Avatar
open end wrench (forgot size 14 / 17?) for the sensors.
You'll be able to hand turn them off once u break them loose with the wrench.
It'll get easier.
      03-16-2011, 06:52 PM   #21
adrock
adrock's Avatar
Drives: 2014 435i
2011 E92 335i  [9.58]
2007 E92 335i  [0.00]
Oh man, I'm going to be attempting this on Sat. Any pointers you can give me before I get started? All the other threads are for N54 DP, and I just assumed N55 was going to be a little easier due to the "extra" space.
      03-16-2011, 07:11 PM   #22
FrankiE90
FrankiE90's Avatar
it's like the N54 - minus
1 clamp.
i recommend a lift.
keikdasneak
try to take off the upper sensor first
so the mid one u can twist the DP will make
it easier.
and just wait till u have to get it back on.
e90post
