335d Performance Tuner Remap - JBD?
03-14-2011, 12:35 AM | #2 |
Rep 234
I've had my JBD for 4 days and my car is noticeably faster. I had it on the stock setting for 10 minutes before I dialed it all the way up to 100%. I have not thrown a code yet.
03-14-2011, 08:21 AM | #3 |
766
Rep 3,961
Mine is running great on 100%. No problem pulling away from a stock 335i. 0-60 in 4.5 seconds, and 12.9 ETs.
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) |
03-14-2011, 08:50 AM | #4 |
Joint Chiefs of Staff
4901
Rep 115,955
Here is some info on the JBD. Its a great inexpensive way to add some serious pep to the D.
http://www.e90post.com/forums/showthread.php?t=422987 and a dyno... |
03-16-2011, 09:48 AM | #7 |
Rep 865
Drives: 2018 F15 X5 xDrive35d
You can't go wrong with Burgertuning
03-16-2011, 10:00 AM | #8 |
Rep 490
Drives: 335i
Somebody correct me if Im wrong, but I think the jbd works like the jb+(for the i) it trick your car into thinking your in higher altitudes so you run more boost.
03-16-2011, 02:32 PM | #10 |
Rep 2,760
Does it eliminate that lag at tip-in I felt in the X5 35d?
E92 335 | Space Gray | Saddle Brown Dakota | Dark Burl Trim | ZPP | ZSP | AT | Idrive | 6FL | FBO | Dinan CAI | Quaife LSD | STG3 PROCede.
03-16-2011, 02:33 PM | #11 |
4901
Rep 115,955
03-16-2011, 02:58 PM | #12 |
Rep 2,760
Looks like I will be getting this when I get my diesel X5. I wonder if only downside is more fuel consumed, but going easy should alleviate that! I like to have the GO-ability when I want it and sip the fuel when just tooling around.
03-16-2011, 03:10 PM | #13 | |
Rep 3,175
As I understand it, that's NOT a remap in the traditional sense. Diesel tune boxes do nothing more then by-pass the rail sensor and deliver a signal to the ECU that tells it to raise fuel pressure vs the ECU giving a comand based on it being reprogrammed. |
03-16-2011, 03:27 PM | #14 |
Rep 234
With slightly more aggressive acceleration because of all the additional power and according to the OBC, I get better gas mileage. I'm not sure if it's completely accurate. I have read that it will take time for the OBC to adjust and recalibrate itself.
03-17-2011, 12:20 PM | #15 |
Rep 21
I think cssnms is correct. I found a pretty good writeup on the differance between remaps and tune boxes. Enjoy the read.
http://www.endtuning.com/dieseltuningboxes.html |
03-19-2011, 07:06 AM | #16 |
Santa Fe Concorso
103
Rep 2,984
If you plan on running it 100% be sure to include the scan tool option to clear codes.
03-19-2011, 09:01 AM | #17 | |
Rep 3,175
03-19-2011, 09:24 AM | #18 |
Resident Diesel Junkie
56
Rep 1,070
That was a very interesting read. The jist of it seems to be that remaps are preferable to tuning boxes because they work directly with the ECU as opposed to tricking the ECU, and therefore put less strain on the engine, injectors, and other supporting engine components. Perhaps somebody more knowledgeable can chime in and make sure I'm getting it right.
In any case, there are only 2 things holding me back from getting a JBD. One is I don't want to risk anything with my warranty. And the other is concern about long term reliability. Many people are running the JBD and are very satisfied, but what worries me is what will happen after 50,000 or more miles of running the car at a greater-than-factory power levels. Perhaps that's not as much of an issue for someone who's on a lease and planning on changing out of the car in a few years, but I plan (and hope) to keep mine for a very long time. |
03-19-2011, 10:02 AM | #19 | |
Rep 3,175
I believe the repracutions/risks of using the JBD are lower then the gas juice box variant. Diesel tune boxes place extra load on the high pressure fuel pump and your concerns about long term reliability as it relates to these added stresses are valid. That said, there are tolerances built into the various mechanical components, now whether or not the JBD exceeds those tolerances I don't know. I would venture to guess that one would be well within those tolerances at the base setting. |
03-27-2011, 10:17 AM | #20 | |
Rep 743
Same
03-27-2011, 12:36 PM | #21 | |
Rep 387
Alex.
Current: 2023 G20 LCI M340i xDrive
History: 2005 E90 325i > 2008 E90 328xi > 2011 E90 LCI 335i xDrive > 2013 F30 328i xDrive > 2016 F30 LCI 340i xDrive > 2020 G20 M340i xDrive WE ARE! |
03-28-2011, 08:02 PM | #22 |
Ex-Diesel Driver
61
Rep 2,000
Subscribed and can anyone here verify if the BT scanner can only be linked to one VIN or up to 3?
FS: HRE Center Caps http://www.e90post.com/forums/showth...post13972317l] |
