E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > N55 Procede V4 Review
      12-14-2010, 10:23 PM   #1
N55
N55's Avatar
Drives: 🚀
I bought a Procede for my N55 from a fellow e90post member and got it today! So the install was a breeze until I got to the crank sensor part. It took 45 minutes just to get it undone. I followed all the instructions (Bending aluminum down and etc.) and my hand just wouldn't fit (My hand is not big) The hose that blocks the way didn't make it any better either. My hands are all scratched up from trying to force my hand down there. So I ended up using 2 hands to get it undone. I used one hand to pull and the other to hold the release down. If you try the two hand method you have to use your left hand to go in as instructed then use right hand to go in behind the strut bar and then down.
After everything was hooked up the CANbus didn't work . So I called shiv and he took care of everything and was a great help. They have great customer support!
I went for the autotune drive and a few miles later I could feel the power! The car pulled like crazy! It actually gave me the goosebumps . The power delivery was smooth. There was very very minimal turbo lag. The controls are very easy and simple.
I am extremely happy with the procede. My friend has the N55 fully stock like mine but with a JB3, after he rode in my car tonight his jaw dropped! (Yes I know the JB3 is stage 1) He was with the procede after I let him drive.
The only complaint is the serial adapter, that you have to buy from radio shack/best buy, can't you guys just make it a USB?
Overall: Procede
I hope this helps! I will try to post some videos of pulls.
      12-14-2010, 10:36 PM   #2
IcebergM4
IcebergM4's Avatar
361
Drives: '23 M4C
Congrats man the torque is like a kick in the pants!
      12-15-2010, 05:48 AM   #3
yitbos1
Drives: 2013 E92 M3 Le Mans Blue
Yeah that crank sensor is a real pain! I just installed mine - N55 as well - and that was the only thing that wasn't a breeze. Well... maybe the MAP sensor since it's underneath a cover. I dropped the small screwdriver I used to pry the tab and needed to remove some under carriage covers to get it back
Anyway, there is just no way to get that crank sensor undone the way Shiv has it in the instructions. You need to find your own way, apparently. I was able to use one hand, but in a way other than what is suggested.
      12-15-2010, 10:30 AM   #4
N55
N55's Avatar
Drives: 🚀
Thanks Iceberg!
@ yitbos1 LOL I was holding onto the screwdriver for dear life ha. The Map sensor took a little to find also.
Also does anyone know where I can find the procede reader software? Or do I just plug the Procede into my laptop and download that reader software from the procede?
Thanks in advance!
      12-15-2010, 10:41 AM   #5
AltecBX
AltecBX's Avatar
Drives: BMW 335xi Sedan; BMW M3 ZCP
2018 BMW M3 ZCP  [0.00]
2007 BMW 335Xi  [0.00]
PROcede User Software
http://www.procedetuning.com/BMW/n55...downloads.html
335xi Sedan 6AT | Weather(70-85°F) | N54 Tune Comparison Chart || N54 Turbo Upgrade Comparison Chart
-PROcede Rev. 2.5 ~ v5 (3/17 maps) / JB4 (8/21 maps) / COBB (Stg2+FMIC LT Aggressive maps)
†Procede Map2(UT 45 - IGN 40) Aggression Target 2.0 | 0-60 in 4.0sec || †Cobb E30 LT (35% Ethanol/65% 93 Octane) | 0-60 in 3.9sec
AR Design Catless DP | BMS DCI + OCC | ETS 5 FMIC | Alpina B3 Trans Flash |235/265 19" Michelin PSS
      12-15-2010, 02:59 PM   #6
N55
N55's Avatar
Drives: 🚀
Thanks Altec! I already have that installed on my laptop. So i'm guessing the procede software is in there.
      12-15-2010, 03:01 PM   #7
AltecBX
AltecBX's Avatar
Yes it is
      12-15-2010, 05:40 PM   #8
N55
N55's Avatar
Drives: 🚀
Thanks!
      12-16-2010, 04:40 PM   #9
shockin330i
shockin330i's Avatar
798
Drives: 2016 ZCP M3
hhmmm
ERnie
2016 BSM/f80/ZCP
      12-18-2010, 08:29 PM   #10
N55
N55's Avatar
Drives: 🚀
Originally Posted by shockin330i View Post
hhmmm
yes? ha?
      12-18-2010, 09:08 PM   #11
shockin330i
798
Drives: 2016 ZCP M3
I wonder how much it costs to have this baby over nighted....
ERnie
2016 BSM/f80/ZCP
      12-18-2010, 10:30 PM   #12
D.B.S
D.B.S's Avatar
Drives: '11 X5 35i / '13 S5
Wish I could use mine (procede)... Damn BMW for taking the ecu box out of the X5...
BMW X5 35i: Boopie Exhaust & Intercooler, K&N Drop in Filter, JB3 (3+ psi)
2013 Dodge Challenger R/T: CAI, Catch Can, Custom Exhaust, Headers, 87MM Throttle Body, Diablo Custom 93 OCT Tune
      12-19-2010, 11:26 AM   #13
N55
N55's Avatar
Drives: 🚀
Probably in the range of $30-$45 for overnight! Not too bad if you want it quick!
      12-19-2010, 12:06 PM   #14
shockin330i
798
Drives: 2016 ZCP M3
I guess ill cal them since it isn't an option on their website...
ERnie
2016 BSM/f80/ZCP
      12-19-2010, 08:33 PM   #15
N55
N55's Avatar
Drives: 🚀
Goodluck !
      12-19-2010, 08:46 PM   #16
adrianBMW99
adrianBMW99's Avatar
Haven't had a chance to put up a thorough review yet (I will sometime when I have video), but the car with the N55 Procede is crazy. Midrange power is explosive and launching the car spins the tires wildly while pushing your head back into the seats
      12-19-2010, 10:42 PM   #17
N55
N55's Avatar
Drives: 🚀
+1 I love getting my head whipped back to the seat!
      12-24-2010, 04:56 PM   #18
shockin330i
798
Drives: 2016 ZCP M3
just got mine in, any advice?
ERnie
2016 BSM/f80/ZCP
      12-24-2010, 05:31 PM   #19
adrianBMW99
Start from ecu canbus wires, work your way around, let the harness guide you, all connectors are a breeze until you get to the last one,the crank position sensor is tricky but doable. Last, connect power, ground it and fire her up. Let autotuning do its thing!
      12-24-2010, 05:38 PM   #20
daixloxbmw
Drives: Corvette Grand Sport
+1
Its actually very easy and there's no way you can screw it up since all the connections are in order starting with shortest wire to the longest on the harness. I had a bit of a problem with the Manifold Pressure Sensor and the Crank Position Sensor. Locating them wasn't difficult but even after you find it, its very difficult to release the tabs, pull it out and replace with the Proceed connectors due to the tight spaces, obstructions and awkward angles.
      12-24-2010, 06:16 PM   #21
shockin330i
798
Drives: 2016 ZCP M3
The connections are a breeze, same as the one's on the jb3. I couldn't for the life of me take that damn tape off for the canbus. So I just ripped it. I'll buy some stuff to re wrap it 2morrow.
Right now I'm on the crank sensor. I'll try the two handed method....
ERnie
2016 BSM/f80/ZCP
      12-24-2010, 06:22 PM   #22
black e
black e's Avatar
34
Drives: DCT N55 135I
The canbus wires are coverd by what looks like 2 rubber condoms....
e90post
