Airsoft: One of a Kind Custom Tokyo Marui M4A1 **(NOW $680)**
02-03-2007, 12:55 PM | #1 |
Rep 8,338
Airsoft: One of a Kind Custom Tokyo Marui M4A1 **(NOW $650)**
*****MORE PHOTOS AND DETAILS BELOW***** $350 and cost of shipping to your doorstep, or best offer. Optics not included (additional $200) I will include the rifle with it's matching silencer, two batteries, 1 standard cap magazine and carry bag. That's on top of everything you see there. Now that my 335i has arrived it's time to do some modding, but I need to free up some money first. My greatest hobby before cars was airsoft, the peak of which gave birth to this: The gun itself is a Tokyo Marui M4A1 I originally bought as their DevGru custom M4 ($900). It then began its transformation, losing and gaining accessories, these are its current stats: Tokyo Marui M4A1 tuned to 400fps (385 in actuality) Guarder Metal Body Guarder 2 piece cqb barel Systema metal hop-up chamber Star ruber ergonomic grip Prime battery retractable stock G&P Aimpoint G&P Rear Flip Up Sight Phantom Flashhider superbright 13 LED flashlight high connectivity connectors (wired to the stock) Norrell MolyResin (metalbody, outterbarel, front sight, ras, stock tube, flashhider, flashlight and mount, etc.) I will also throw in a G&G silencer that is also refinished in Norrells and matchs the gun perfectly as well as a Classic Army bipod (both pictured here, before the silencer or gun was refinished however http://ironicdesigns.no-ip.com/Pictu...s/IMG_1028.jpg. Now besides the ordinary, here's the real custom part about this gun. The WHOLE rifle has been refinished with Norrell's (http://www.molyresin.com/). MolyResin is the same finish applied to countless highend arms by their manufacturers. By refinished, I mean the parts have been stripped of previous paint and been recoated in a milspec finish. The whole process took me three days to finish and atleast 10 hrs between stripping the paint and refinishing and curing. Some facts about MolyResin below. Specifications: Appearance: The bonded coating will appear uniform in color, smooth and free from cracks, runs, sags, scratches, pin holes, blisters, bubbles, and foreign matter. Thickness: The optimal thickness of the coating will be between .0003" and .0009" unless a thicker coating is desired. The thin coating characteristics of less than one thousands of an inch allows easy re-assembly of precision fitted parts Lubricity: Moly Resin***8482; contains molybdenum disulfide, which provides excellent anti-friction characteristics. Wear life is comparable to blued, parkerized and other common firearm finishes. Moly Resin***8482; is a phenolic Resin that when thermally cured, produces the most durable thermally cured painted surface of any products on the market. Wear life when tested on Tabor Abrasurf with #CS10 wheel installed @ 500 grams weight minimum 235 RPM's. Thermal Stability: The cured coating will withstand exposure at 500 f for 1000 hours minimum and 1000 hour minimum soak at -125 f. Minimum initial oxidation temperature is 880 f. Thermal breakaway is 1000 f minimum. Fluid Resistance: Moly Resin***8482; will meet 24 hour emersion requirements in the following fluids: aviation gasoline, hydraulic fluid, jet fuel, lubricating oils, paint removers, trichlorethylene, nitric, sulphuric and hydrochloric acids, hydrogen peroxide, gun powder solvents, strong bases such as ammonium and sodium hydroxide, and numerous other strong chemicals. Corrosion Resistance: Moly Resin***8482;, when applied to bare sandblasted cold rolled steel will pass the test procedures for salt water spray at 1000 hours, salt water immersion at a minimum of 1000 hours, accelerated salt spray test equivalent to 30 years marine atmosphere exposure, and 60 days sea water immersion. Hardness: Hardness meets and/or exceeds the hardness of any Epoxy,Teflon or most other thermally cured firearm coating or paints on the market. Here are some photos (note: the optics pictured have since been removed, but I will throw in an aimpoint w/ cantilever mount and a NEW G&P Aimpoint). Notice the finish - this is THE MOST REALISTIC airsoft replica rifle on the market. The blemishes in the finish you're seeing, where the paint looks blotchy, is from silicone oil; the residue rubs off as well as most any other scratch thanks to Norrell's. For reference (look out how uniform and high quality the finish looks on the flat slide of the glock):
02-03-2007, 01:17 PM | #2 |
United States Marine
316
Rep 2,748
man, I wish I could justify this purchase. I miss airsoft, and just started getting back into it with my friends... I used to have $2300 worth of various electric and gas powered weaponry. Sold it all off a few years ago. But now all my $$ goes to the car.
What a gun, you've got there though! wow. |
02-03-2007, 02:36 PM | #4 | |
Rep 8,338
neighbors might think twice about not picking up after their dogs tho
02-04-2007, 08:31 PM | #5 |
Rep 8,338
bump
02-04-2007, 10:52 PM | #7 |
Rep 3,200
Oh I'm very, very tempted. Going to need to think about it though. My friend has been trying to get me to play with his young marines buddies for weeks but I didn't want to go up against hardcore airsoft players with a CO2 pistol. This may be the answer. Hmmmm. Nice mods, very nice mods.
328xi Coupe, Montego Blue on Black with Alum, Step, Sport, Premium, CA, PDC, Cold Weather (Damn Pennsylvania winters)
Current Mods: Heavy right foot - Planned Mods: Lightweight right foot |
02-04-2007, 11:11 PM | #8 | |
Rep 8,338
Tokyo Marui M4A1 RIS $350 Guarder Metal Body $200 Body Pins $30 Prime Crane Stock $130 Guarder 1 Piece CQB Barrel $110 Phantom Flash Hider $45 G&P Aimpoint and Cantilever Mount $65 Star Pistol Grip $35 Rear Flip up sight $30 400fps upgrade $100 wired to the back $10 flashlight $45 flashlight mount $30 $1,180 This doesn't include the cost or time spent refinishing the whole rifle. I also have a refinished silencer that matches the rifle and a bipod as well that aren't pictured above. I'll take pictures and post it in a few minutes. It'll cost a little more money for the silencer. (seeing these figures really makes me second think selling all of this at that price )
02-04-2007, 11:21 PM | #9 |
Rep 8,338
temporary photo till i can take a picture of the refinished silencer (which looks much better if you can imagine that). this is the bipod that can be included potentially as well.
02-04-2007, 11:45 PM | #10 |
Rep 8,338
Fully functioning quick-detach, serial numbered silencer:
(photos shot w/ and w/o flash, color not edited)
02-05-2007, 12:05 AM | #12 |
Rep 8,338
^ haha alright, i'm down
02-05-2007, 10:25 PM | #13 |
Rep 1,928
Drives: had e90, 330i mystic blue
WOW that is one bad ass gun excellent to take it to the airport j/k !!
E90 Mytic Blue 330i 07-20-2006. 05-17-2011
Doesn't the idea of making nature against the law seem to you a bit . . . unnatural? Support NORML |
02-05-2007, 10:46 PM | #15 |
Rep 8,338
lol alright alright i know it's sick, now someone buy it!
it shoots whtever u point it at =) haha j/k, it fires 6mm bbs, plastic or metal. 400 feet per second is w/ the standard 6mm 2gram bb fyi that's enough to shatter cds, dent cars, break some windows, shoot through both sides of a soda can, pierce someone's skin eye protection should be worn at all times, and i'm not responsible for the buyer's actions - i will go through a list of things on purchase
02-05-2007, 10:56 PM | #16 |
Rep 4,163
hmm wouldnt u run into trouble shipping these things
'06 bsm e90 330xi : 18" VMR CSL : KW V3 : GruppeM Rep Intake : UUC/Corsa Catback : Hartge Lip : ACS Roof Spoiler
OEM CF Trunk Spoiler : CF Emblems. Pillars. Mirror. Grille : LUXER12 led plate : V1 Hardwired : OG.longtran e90post sticker! circa 2005 |
02-06-2007, 01:48 AM | #17 |
316
Rep 2,748
No. You ship them in a slightly dismantled state, and they have orange tips. I've shipped a few, post 9/11, no problems.
02-06-2007, 10:37 AM | #18 |
Rep 8,338
^ yup yup
02-07-2007, 05:50 PM | #19 |
Rep 8,338
bump
02-08-2007, 08:49 PM | #20 |
Rep 8,338
bump
02-08-2007, 09:10 PM | #22 |
Rep 8,338
sorry the glock isn't for sale, it's been sold for a while now
