BMW M3 Forum (E90 E92)
EXXEL Distributions
      11-10-2010, 04:54 PM   #1
Kartelli
Drives: 15 AW M3 DCT
E-Brake Cable (Tighten)
Can anybody post a quick "how to" tighten the ebrake cable?
Mine is abit loose, car rolls back unless the ebrake is pulled up very high.
      11-10-2010, 05:33 PM   #2
elm3
///M Fan
elm3's Avatar
Drives: '09 E92 M3 IB/'17 f85 X5M LBB
2017 BMW / X5M  [9.00]
2009 E92 M3  [10.00]
2004 Yamaha R1  [10.00]
I think that if you pull the boot off, the adjusting nut will be right there.
'09 E92 ///M3 Interlagos Blue,6MT,Silver Novillo Leather,CF Trim,Premium Package,Technology Package,Cold Weather Package,Premium Sound,19"Wheels,Moonroof-Toy/'17 X5M, Long Beach Blue, Executive Package,Technology Package, Lighting Package, Driver Assist, Full Mughello Red Interior, 21" wheels-Toy/'14 535i with M Sport and 19" wheels-Daily
      11-20-2010, 07:36 AM   #3
ph_gbg
Sweden
Drives: M3 E92
Had a weak and unbalanced handbrake, and this is what i did:
Pry off the handbrake boot with a trim removal tool
Under the lever, there's a spring loaded cable tensioner. Push this backwards with a large screwdriver or a steel rod until you hear a click and the tensioner is held back.
Loosen one wheel bolt on each rear wheel. Put gearbox in neutral and raise both rear wheels. (You cannot do one wheel at a time because of the LSD.)
Rotate road wheel until you see a small toothed adjusting wheel through the bolt hole. It's partly hidden by a spring. Use a flash light. It is located at one o'clock or eleven o'clock, can't remember which.
Now you should flick the little wheel with a large flatbladed screwdriver to tension the brake. On the left side, you flick backwards and upwards. On the right hand side, you flick forwards and downwards. Tension until you cannot move wheel, then back off about 8 tooths. Make sure road wheel is free to spin.
Lower car, tighten wheel bolts. Use the flat screwdriver to push the arresting hook on the tensioner to the right. It will then spring out.
Did a vehicle inspection the other day where the hand brake was tested, and it looked great!
      12-06-2010, 12:46 PM   #4
Kartelli
^ Awesome, ill try this!!!
      12-07-2010, 01:46 AM   #5
JCtx
Drives: No BMW yet
I'm mechanically inclined and can't make any sense of that. Next time I have the wheels out for a brake bleeding will investigate. If we have a drum-in-disc parking brake system, we should be able to adjust it from the 'Y' or by the lever.
      12-12-2010, 11:34 AM   #6
kenwelch
Drives: 2008 E92 M3 M-DCT & 2017 440GC
It’s like a step back in time.
I have attached the diagram from realoem.com
The rear parking brake shoes have an “adjustment screw” (#3) at each rear wheel. You’re setting the parking brake shoe clearance at each wheel first then if needed adjust the brake cable.
shimmy232350.00
      12-12-2010, 06:13 PM   #7
kmarei
kmarei's Avatar
Egypt
686
Drives: 2018 Audi RS5 coupe
2018 Audi RS5  [0.00]
but all this is assuming both sides are not in sync, and i am trying to adjust them
assuming both sides are in sync and you just want to tighten the hand brake
must i still do the whole pull off a wheel and adjust the hidden screw etc?
      12-13-2010, 02:15 PM   #8
Kartelli
We have drum brakes in the rear??? News to me...
      12-13-2010, 06:03 PM   #9
kenwelch
Many modern cars use drum type parking brakes with disc type service brakes. The disc calipers then are much simpler (less expensive) and it's easier to change the disc brake pads during service.
      12-13-2010, 06:20 PM   #10
kenwelch
The shoes should last a very long time since they are only being used with vehicle stopped unless someone is dong fancy car tricks. I teach auto repair to teenagers you would be amazed at the things they can ruin.
I have not done this adjustment on my M3 with only 15K miles. I only use the park brake lever when the vehicle is stopped (parked).
If you go back and read the post by ph_gbg he said you can just remove one wheel bolt. Then you will see the adjustment screw through the lug hole. This will be the only way that you will know that "both sides are in sync".
You are confirming that the shoe clearance is equal on both sides.
It's important that when adjusting the parking brake it does not make either wheel drag when the parking brake is released......or it just kills the fuel mileage. and destroys the parking brake shoes.
      12-14-2010, 01:47 AM   #11
JCtx
Drives: No BMW yet
Thanks man. Drum-in-disc is the best parking brake system IMO, and that's what we have .
Hey Ken, I wonder if the parking brake can be adjusted by pulling the lever in reverse, like on some other cars. Looks like a ratchet-type adjuster to me, although it can also be turned with a screwdriver. Mine is perfect too with only 6K miles, but somebody might give it a try and report back .
      12-14-2010, 11:10 AM   #12
kenwelch
The self-adjuster looks correct now that you mention it. I found this video clip of a 2008 328i parking cable removal. At 1:45 in the video you can see the adjuster screw is next to what looks like a self-adjuster mechanism. Not like the way it appears in the realoem illustration that I included earlier. Usually the self-adjuster on most vehicles works as you described when you pull the parking brake lever the correct parking brake shoe clearance is set. Now you have me wanting to take my car apart during Christmas break.
      12-15-2010, 10:56 AM   #13
kmarei
kmarei's Avatar
Egypt
686
so is there any way to tighten the handbrake WITHOUT doing the whole screw in the hub step?
can i just adjust it somehow from the hand brake lever?
      09-16-2011, 02:38 PM   #14
MNm3
MNm3's Avatar
Drives: 2009 Le Mans Blue e90 M3
Bump. My girlfriend's 328 xi needs tightening on the hand brake.
Gone but not forgotten...2009 E90 Le Mans Blue M3 6MT De-Chromed, Rogue SSK, Brembo BBK, Eibach Pro Kit, Eisenmann Race Black, MS Filter. 1998.5 Titanium Silver E36 M3 Coupe NASA GTS2 Race Car.
      09-25-2011, 01:28 AM   #15
montreal red
chris
montreal red's Avatar
Drives: White Boat
wished there was an easier way to tighten the ebrake... someone should make a DIY with pictures for the steps above.
Current: 2013 F10 M5 & 2016 Mini JCW
2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone)
      10-23-2011, 09:04 AM   #16
tinnsoldaten
tinnsoldaten's Avatar
Norway
34
Drives: e92 335i coupe
I just adjusted the handbrake by turning adjustment screws thru hole for wheel bolt , but I didnt do the whatever thing with handbrake lever. I saw the spring with special washer on it , but it didnt budge , and I didnt want to use more force or time and energy on it. The handbrake is now working again.
But I have to go all the way up with the lever to make it hold properly.
Is there any way of getting it to hold earlier? That got to do with loosening the spring?
      05-26-2012, 08:50 AM   #17
tinnsoldaten
Norway
34
Bump
Vargas S2 turbos|VAC S3 Cylinder head|RR DPs|RR MPs|Supersprint X pipe|Remus Quad Sport mufflers|aFe Stage 2 Si with scoops|Forge DVs|ER CP|BMS meth elbow|Aquamist HFS-4|Walbro 450 E85 LPFP|AA FMIC|BMS OCC|MHD|P3 Boost Gauge|Ohlins Road & Track + camberplates|M3 sways F/R+ Ground control endlinks|Vorsteiner v303 19"|Michelin PS2 sport|Quaife LSD|Vorsteiner V35 CF hood|CF CLS trunk|Duke Dynamics quad diffusor
      06-23-2012, 12:20 AM   #18
atruelunatic
Drives: n/a
Does anyone know if it's safe to reuse Macht Schnell's stud conversion kit with this? (I'll reapply loctite of course)
2011 e92 JzB 6MT
Akrapovic Evolution, ESS Tune, KW V3
      03-01-2019, 03:35 PM   #19
M3MPH1S
M3MPH1S's Avatar
Drives: 2010 E92 M3
I'm having the opposite issue where I disconnected my ebrake to take my rear subframe out and then after reinstalling, the ebrake won't fully disengage and is lightly scraping while driving. Would this potentially be caused by the same imbalance between the top side of the cable and the wheel side? When I disconnected the cable, I did *not* touch anything related to the handle inside the cabin - was I supposed to? Also I have studs installed, so I guess I'll have to just remove the rotor. Any help is appreciated.
      03-07-2019, 10:29 AM   #20
M43S7RO
Drives: Jerez Black E92 M3
You could try loosening the cables a bit at the handle. I have my subframe out now and will have to keep an eye on this.
      03-07-2019, 10:42 AM   #21
M3MPH1S
M3MPH1S's Avatar
Drives: 2010 E92 M3
Sorry forgot to update. My issue ended up being that part of the "inner radius" of the dust shields had slightly bent in and was scraping on the rotor hat. My ebrake cable ended up having no issues, so you can safely not worry about that when re-attaching yours. The cause of the bending was due to leaving all my control arms attached to the knuckle and leaving the whole knuckle and arm cluster lying on the ground. I was very gentle with it, but it seems due to the weight it pushed part of the dust shield in.
      03-07-2019, 12:54 PM   #22
M43S7RO
My knuckles are are also laying with arms attached. I've been gentle on the dust shield by supporting the knuckle with a piece of 2x4.
m3post
