N55 Wastegate DC% logs
07-06-2010, 03:23 PM | #1 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Interesting stuff:
At the same stock boost pressure, it runs a lot higher wastegate DC% than the n54 which peaks out at around 35% in similar conditions. This suggests that the wastegate spring is softer, the wastegate solenoid bleed smaller, the turbocharger has less capacity or a combination of the three. For comparison, this Wastegate DC% curve in a n54 would yield around 12-13psi. Shiv |
07-06-2010, 03:38 PM | #2 |
Rep 2,663
Drives: BMW 335xi Sedan; BMW M3 ZCP
Most these findings on the new N55, seems to prove that the N54 is a much stronger engine.
335xi Sedan 6AT | Weather(70-85°F) | N54 Tune Comparison Chart || N54 Turbo Upgrade Comparison Chart
-PROcede Rev. 2.5 ~ v5 (3/17 maps) / JB4 (8/21 maps) / COBB (Stg2+FMIC LT Aggressive maps) †Procede Map2(UT 45 - IGN 40) Aggression Target 2.0 | 0-60 in 4.0sec || †Cobb E30 LT (35% Ethanol/65% 93 Octane) | 0-60 in 3.9sec AR Design Catless DP | BMS DCI + OCC | ETS 5 FMIC | Alpina B3 Trans Flash |235/265 19" Michelin PSS |
07-06-2010, 03:44 PM | #3 | |
1737
Rep 17,960
Drives: A Lot
Shiv |
07-06-2010, 03:49 PM | #4 |
Rep 4,764
Hopefully it isn't less capacity. Hopefully they just decided to throw in an extra hurdle or two via hardware limitations that would discourage a percentage of the casual owners. With the N54 is was so easy to throw on a piggy. If it requires adiditonal hardware swaps maybe they figure they can cut down on tuned n55's by a good amount?
07-06-2010, 04:22 PM | #7 |
Rep 738
shiv, so the outlook of stock vs stock tuned, the engine output seems to steer to less power than the n54 due to possible turbo output...question is, does it look like a turbo upgrade would be much easier to do on the n55? im not sure what the hardware is like on that engine and to me it would seem logical that upgrading the turbo should be a lot sooner and easier than the n54.
i guess i just can't wait to solidify the decision to keep my car or get a 135i with 7speeds :-) teri
http://videos.streetfire.net/video/s...rays_37268.htm
gotta do what i gotta do to get them donuts 04 spec-v: rip dec07 |
07-06-2010, 04:40 PM | #8 | |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
1. You have half the intake plumbing 2. You have half the exhaust plumbing 3. You have half the number of turbochargers and their supporting hardware such as coolant and oil lines For one, you *should* have more space in the engine bay to work with, less plumbing to deal with. The fuel pump is the same as the one used in N54 engines. So, *theoretically* it should be easier from hardware stand point to upgrade the turbo on the N55. Now, software wise, noone really knows but I have high confidence in the tuners. |
07-06-2010, 05:05 PM | #9 | |
Rep 3,262
07-06-2010, 07:17 PM | #11 | |
Rep 738
im just almost sold on the dct trans. teri
07-06-2010, 07:59 PM | #12 | |
Rep 3,004
07-06-2010, 08:01 PM | #13 |
Rep 10,587
any reason why you cant just replace it with a better twin scroll? I dont see why not.
07-06-2010, 08:05 PM | #14 |
Rep 1,748
Maybe this is a stupid question, but does anyone know what type of TwinScroll they are using in the N55? Couldn't it be upgraded to a Garrett GT35R Twin Scroll? Or something similiar?
BMW X5 35i: Boopie Exhaust & Intercooler, K&N Drop in Filter, JB3 (3+ psi) 2013 Dodge Challenger R/T: CAI, Catch Can, Custom Exhaust, Headers, 87MM Throttle Body, Diablo Custom 93 OCT Tune |
07-06-2010, 08:44 PM | #15 |
ElevenPointFive
326
Rep 2,450
Perhaps this is an indication that you will need to swap out turbo hardward to safely produce more boost on the N55 as it seems like that twin scroll is working pretty hard already with the duty cycles.
2008 E90 335xi - N54 Daily Driver
MHD Stage 2+ ~ CPE DPs ~ BMS Intake ~ AMS FMIC |
07-10-2010, 12:09 AM | #16 |
Rep 4,784
HHmm. I did the muffler delete yesterday and my 1/4 times suffered today. Seems like it needed to launch at higher rpms for the car to actually lower my 60' times. And my 1/4 trap speeds were lower by almost 2-3 mph.
Pre MD I would launch at 1500rpm and today I had to launch around 2krpm. Any thoughts?
ERnie
2016 BSM/f80/ZCP |
07-10-2010, 09:12 AM | #17 |
Rep 2,841
07-10-2010, 09:39 AM | #18 | |
Rep 374
07-10-2010, 12:23 PM | #19 |
Rep 4,784
I'll take some later, but it does sound legit. But I'm just not liking how much my 1/4 dropped...
ERnie
2016 BSM/f80/ZCP |
07-10-2010, 01:45 PM | #20 | |
Rep 183
http://www.turbos.bwauto.com/product...sGasoline.aspx |
07-11-2010, 02:09 PM | #21 |
1737
Rep 17,960
Drives: A Lot
07-11-2010, 02:13 PM | #22 |
1737
Rep 17,960
Drives: A Lot
Quick Update:
Very productive weekend so far. Just got logging/viewing access to all the CAN channels necessary for v4 tuning logic: -Actual dbw throttle -Oil temp -DME boost target -DME actual boost before throttle blade -Air intake temp The CAN logic is a bit different from that of the n54 so this job was harder than expected. The scaling is also different on many of the channels which came as a surprise. But so far, I'd say we are 80% of the way to have a fully functional v4 tune for the n55. With autotuning to follow a few weeks after (firmware update only). Shiv |
