04-07-2010, 07:45 PM | #1 |
Rep 6,094
PYSpeed.com | RS Technik Wheel Spacers Ultra Light Weight **You Deserve The Best**
PYSpeed - RS Technik Wheel Spacers (FREE SHIPPING WITHIN US PROMO)
RS Technik Wheel Spacers (You Deserve The Best) This is the lightest Wheel Spacer and Best Quality on the Market. - Available Now in 12mm and 15mm including 10 Matching Extended Wheel Bolts (More Coming Soon!) Give your BMW an aggressive stance and fine tune its handling characteristics with RS Technik Wheel Spacers. User wheel spacers to optimize your tire track width improving lateral stability and grip. Additionally, spacers give your vehicle a more aggressive look, by filling out the fender gap generally associated with conservative stock wheel offsets and suspension setups. Each spacer is optimized for the ultimate in strength while maintaining the lightest possible weight. Made from T6-6061 aircraft grade aluminum and machine finished to absolute perfect. Each spacer is proudly made in the USA. Features: - Made from 100% billet aircraft grade T6-6061 aluminum. - Finished to last. Anodized zinc coating ensures each spacer is resistant to corrosion, wear and provides a beautiful fit and finish. - Stuck spacers are a thing of the past. Each spacer features a chamfered inside edge that allows easy removal using a standard flat head screw driver. - Design and manufactured specific for your vehicle. Hub-centric design means you get a perfect and safe fitting spacer. - Includes matching corrosion resistant wheel fasteners. Each fastener is made specific to match your selected spacer size. - Made in the USA. Packages Includes: - (2) RS Technik Wheel Spacers - (10) Extended Wheel Bolts in Anodized Zinc Coating as well Models Supported: - All BMW 5x120 bolt patterns with 72.5mm hub flanges (not E39, E70) Last edited by PYSpeed.com; 04-07-2010 at 07:59 PM.. |
