The truth about the N55 engine begins to surface ?
01-24-2010, 11:37 AM | #1 |
Rep 3,262
I just saw this line in the new N55-based BMW 5-series review from Automobile Magazine:
"we sampled a 535i, powered by BMW’s new N55 single-turbo inline six-cylinder. The new engine is rated at the same 300 hp and 300 lb-ft of torque as the outgoing twin-turbo unit, but it doesn’t have quite the same punch at the low end." http://www.automobilemag.com/reviews...ew_engine.html Well, now we know why they still use the twin-turbo in the more sports-oriented model... Go N54 !
01-24-2010, 11:54 AM | #2 |
Rep 10,854
The differences between the N55 and N54 in the 535i are determined by software specs, not inherent differences in the performance potential of the bi-turbo (N54) versus twin-scroll+valvetronic (N55) designs.
Believe me, there are variants of the N55 in R&D that smoke the current N54 & N54B30.
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
01-24-2010, 12:18 PM | #3 | |
Rep 3,262
Of course, software can bring more additional "punch" but so is the software from GIAC, Evotech, etc. The question is, can it bring the additional punch while keeping the targeted BMW parameters ? If it did (with the current hardware), they would have released it at least in the heavier models like the 535i which would really benefit from more torque. When I will see an M3 with single turbo and Valveronic I will give the props to N55, but I really believe the next M3 will have a twin-turbo without valvetronic in order to provide low-end torque and a high-RPM redline (where the Valvetronic has problems).
01-24-2010, 12:48 PM | #4 |
Rep 6,093
Lag can be fun, though... like when all of a sudden 30 psi hits!
But, for everyday driving, not so much. Two twin scroll turbos as an upgrade option to the N54 might be something to look at. Two bigger turbos, but twin scroll to try and help alleviate low end lag.
When you say impact instead of affect/effect, you are communicating that you don't understand the difference between the two words, and are too lazy to learn.
01-24-2010, 12:55 PM | #5 |
Rep 10,587
I would expect the n55 to have a little less low end grunt, but be surperior up top where it really helps for performance reasons.
a n54 powered vehicle can certainly pull my M3 on low end rpm pulls, but once i'm spooled, good bye. same idea but the n55 wont be as laggy as a larger turbo for many reasons, twin scroll and valvetronic being 2 of the main ones.
01-24-2010, 01:05 PM | #6 | |
Rep 10,854
Edit: misuse of term "impeller", see comments below. |
01-24-2010, 01:35 PM | #8 |
Rep 3,262
Sorry but this is not true. Twin-scroll just means that exhaust gases (from the six cylinders in this case) are split in two separate streams of flow (one flow from each 3-cylinder bank) which enter the turbine separately and spin the same impeller which has two sets of fins, one for each flow. The advantage is the higher pressure in each flow and the alternating exhaust pulses in each flow path (after a cilinder fires the exhaused gas from that cylinder creates and exhaust "pulse") which create the high turbine RPM faster than a single flow.
01-24-2010, 01:57 PM | #9 | ||
Rep 601
Sorry but you are wrong. Read here from BMW: Twin Scroll Turbo System Explained Quote:
--2009 BSM 135i-- -Manual, Sport Package, BMW Assist |
01-24-2010, 02:07 PM | #10 |
Rep 1,629
[quot]But, for everyday driving, not so much. Two twin scroll turbos as an upgrade option to the N54 might be something to look at. Two bigger turbos, but twin scroll to try and help alleviate low end lag.[/quot]
two twin scrolls on any six cylinder engine makes zero sense. It would actually be significantly less efficient. The whole point of a twin scroll turbo is to seperate the pulses of exhaust gas.
Cars>Women
01-24-2010, 02:11 PM | #11 |
Rep 1,190
^ aren't they putting dual twin scrolls in the next M3 engine(I6)? Is that just forum banter at this point?
2011 VW GTI 4dr-6mt-Sunroof-Nav-Xenons
OLD: 08 335i AW/CR/Poplar 6mt-ZSP-ZPP-ZCW-iPod-iDrive-PDC-Style 230s w/FK 452-Dinan LSD |
01-24-2010, 02:46 PM | #12 | |
Rep 3,262
It will either be a twin-turbo I6 (my guess is 3.2-3.6 liters) or a twin-scroll, twin-turbo V8.
01-24-2010, 03:07 PM | #13 |
Rep 10,854
You guys are right of course -- the turbo in the N55 is not a sequential design, nor an active variable geometry design. I should always double check myself whenever I use the word "impeller" because I use it inappropriately to refer to the turbine fan. My point is simply that the turbine fans in the N55 are designed for low threshold, reduced lag, and high power. I don't understand the nuances of how the blades are designed differently to take advantage of the separated manifold.
Pretty good summary here: http://kilometermagazine.com/artman2...Turbo_Six.html But I want to see a better cutaway than what BMW provided in the Press package. Any advantages to a manifold/header divided 6 ways, with separate inputs from each cylinder to the turbo? Complicated mess.
01-24-2010, 04:38 PM | #16 |
Rep 10,854
What is so "wild" about BMW R&D having multiple engine versions? They always do. Most obviously never make it to market. Second point, if you have people that you know inside BMW you don't name them. Third point, I don't write about stuff here unless it's already out, in this case Michael (Mapezzul) discussed N55 variants on his blog.
01-24-2010, 05:27 PM | #17 | |
Rep 3,262
01-24-2010, 05:32 PM | #18 |
Rep 257
lag or no lag, I'd still go for the N55 just because it's a newer toy, then patiently wait for the tuners to do their tricks. On top of that, the possibility that the N55 may be a more dependable unit more than makes up for its shortcomings.
01-24-2010, 06:26 PM | #19 |
441
Rep 18,331
Well everything that comes out seems to be the best thing out, we will wait and see what the N55 platform brings, but I have a feeling the N54 will be a special engine that enthusiast will be looking for a long time after its no longer in production...If it wasn't anything special why would they even offer it in the 335is model, knowing that the enthusiast would pay top dollar for a N54 engine..
01-24-2010, 06:52 PM | #20 | |
Rep 1,467
how many people do you know that would drive a more laggy vs less laggy car, and say the more laggy car is more sporty... hardly anyone spends any time over 6000 rpm. And the car isn't marketed towards the serious performance crowd (more like the 'ooh, sporty sounds nice!' crowd). -scheherazade |
01-24-2010, 06:56 PM | #21 |
Rep 4,632
The newest isnt always the greatest. That goes for both tuning potential greatest and daily driving consumer greatness.
The N55 seems to be and have less tuning potential than the N54 because of the valvetronic, and of course it going to come with some tough anti-tuner hardware/software mix that will most likely keep tuning power levels at bay. For everyday driving, the N55 has the stuff to make it really good. If and how much better than the N54 we will have to see, tq coming in 500rpm early is going to be hard for alot of people to see a difference in there dail driving, so we will have to see, i expect to test drive one as soon as it comes out at my local dealer. Tuning wise, the N54 is going to be the better choice. since there is more R&D which is 3 years into it if not longer which is major. All we can do is speculate but tuning wise things are really leaning on the N54 side. Daily driver and out of the box wise, the N55 has the right stuff but if it will be better we will have to see. |
