E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Asia > Hong Kong > Run-flat indicator issue-where to best fix it in HK
      01-03-2010, 09:42 PM   #1
Wolfman
Drives: 2009 E90 335i
This morning on my drive to work, my run-flat tire indicator light again came on. It was only two weeks after I pumped the tires and I checked there was no leaks or punctures. I can simply reset the indicator, but it seems to turn on every two weeks regardless of how much I pumped into it. So this means something is wrong with the indicator. Anywhere reliable in HK I can fix it without going to BMW Concessionaries (since they are so expensive)?
      01-07-2010, 04:16 AM   #2
335 Freak
Bimmer Turbo Land
335 Freak's Avatar
Hong Kong
39
Drives: White E92 335I Coupe
Perhaps, your TPMS went bust!!! However, I doubt it any rims shop in HK can fix the TPMS whereby, better go to a garage or else, you can rotate the existing TPMS to find out which one is failed!!!
Lumma BDK, M3 CF Hood, I-Forged Triumph 19", AP-6pt-360FR, AP-4pt-345RR, M3 CF Lip, ACS CF RFS, CF Grill, JB3 3.0, Stett DV CHG Pipe + DCI + FMIC, NST Pulley, F+R Full M3 Susp Kits, M3 E92 Q-pipes Ex, UR Catless DP, Ohlins C/O, Eibach Sway, M3 Dash Cockpit, CF Wrap Interior, M3 CF Pedals, M5 Shft Knob, LED ATW, OSS Design BlackOut LED Angel Eyes!!!
      01-09-2010, 04:39 AM   #3
Wolfman
I'm going to take my bimmer to a garage in Tai Hang for check-up, thanks for the advice.
      01-16-2010, 04:36 AM   #4
docjay
docjay's Avatar
Philippines
Drives: 2010 E90
Hey i just had that yesterday,i had that too! Called my service manager he said you just have to reset the system.It worked with mine.Look at page 76 of the manual on initializing the runflat system.
e90post
