12-22-2009, 04:24 PM | #1 |
Rep 6,845
Drives: 2018 Audi RS5 coupe
Brand new pair of SWS-8 for $198!
just saw this on ebay great price no affiliation by the way i live in virginia this guy/girl is in texas http://cgi.ebay.com/Earthquake-SWS-8...item27adeb43e9 |
12-23-2009, 12:35 PM | #2 |
Rep 6,845
depends on which sound system you have
but in all cases if you are not using an external amp it's hardly worth $200 as the difference will be marginal they start to sound good when you give them a lot more power |
12-26-2009, 02:02 PM | #3 |
Rep 2,279
You'll need an aftermarket amp. Also, keep in mind that these are the 4 ohm version. The 2 ohm version will work better for most applications.
'09 Interlagos Blue E92 M3 (sold to a good home)
12-26-2009, 07:01 PM | #4 | |
Rep 6,845
if you are using an aftermarket amp that has enough power it will run cooler at 4ohms and most amps are more efficient at 4ohms than 2 ohms also the daming factor is always higher in 4ohm than 2ohm so 2ohm is not always better. |
12-31-2009, 01:19 AM | #5 |
Rep 2,279
Agreed. That's why I said "most," not "all."
