E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > 335d - VAC Motorsports Diesel Power Module for the US cars
      11-05-2009, 01:39 PM   #1
Jim E.
Jim E.'s Avatar
92
Drives: Individ: 99 M3, 11 X5d, 16 F31
Thumbs up 335d - VAC Motorsports Diesel Power Module for the US cars
So I finally broke down and had the VAC Motorsports Diesel Control Module installed and dyno'ed.
http://www.vacmotorsports.com/catalo...mw-diesels.htm
I was skeptical when I called VAC and told them that I would do it if they put my car on the dyno and did before and after runs. Aaron and Steve were nice guys and very accommodating. In fact, Aaron told me if I did not like the results I didn't have to buy it.
I also told him that I highly doubted their hp gain figure on their site but would be happy with a 15% increase across the board.
The results are attached.
Basically my peak wheel torque is around 450 ft-lbs @ ~1600 rpm's and fairly flat down to 425 wheel torque @ 2400 rpm's. 450 wheel torque is around 520 ft-lbs at the crank assuming around a 16% loss factor. I really don't know what the loss factor is for an automatic tranny but heard it can range from 15% to 25%. Anyone have any insight on this?
In terms of wheel hp the base peak was 225 hp @ 4K (~260 hp) and jumped to nearly 260 hp at the same rpm. (~300 hp crank)
Notice how the hp stayed up in the upper 4K rpm.
Overall when tooling around town the car feels the same. When you hit it then it jumped into another category from the stock setup. I'm still getting used to it so I think it might be a bit premature to give a full seat of the pants description. But it definitely put a smile on my face!
Note, according to Steve at VAC, they can reprogram this module for more gains but have it set to the most conservative setting until they get more feedback. He said it's as easy as unplugging the module, sending it to them and getting it back.
As a reference point, BMW's figures at the crank are: 265hp @ 4200 rpm and 425ft-lbs @ 1750-2250 rpm.
Dyno runs were on Dynapacks. Runs were made in fifth gear and the dynapacks were adjusted to about a 2.45 rear ratio (.87 x 2.81). Ambient temp was around 58-60 degrees F. Water temp was around 190 degrees F.
Cheers,
Jim
      11-05-2009, 01:46 PM   #2
faz
Drives: 2023 X5 x40i, 2018 330i F30
These are great numbers for the price.
      11-05-2009, 01:50 PM   #3
maswastage
Resident Diesel Junkie
maswastage's Avatar
56
Drives: 2010 AW 335d
Wait...they finally have a chip tune for US diesels? I think I just jizzed meself.
Just to confirm I'm reading your numbers correctly, you had 225whp stock and 260whp after the tune? I was expecting a little more, like 240 stock and 280 tuned. Or maybe were Dynapacks the ones that typically read slightly lower?
      11-05-2009, 01:59 PM   #4
Jim E.
Jim E.'s Avatar
92
I was told that dynapacks tend to read higher but keep in mind that VAC specifically told me they have programmed very conservative settings until they get more feedback. Their goal however is not to put out the highest output product regardless. they wanted to maintain a balance of reliability and power gains.
It's a good start for now.
      11-05-2009, 02:03 PM   #5
Jim E.
Jim E.'s Avatar
92
Not bad especially when I was able to get 40mpg on the hwy going back home!
      11-05-2009, 03:19 PM   #6
Twilight1
Drives: Tuned SHO
Alright, Jim! It's funny, today I e-mailed Imran at Evolve asking when his re map will be available. 520 ft-lbs is plenty considering the tranny has a limit at around 500, from what I've read.
Do you know how this differs from a re-map? Be sure to keep us informed on your driving impressions.
      11-05-2009, 05:01 PM   #7
Ron1n
Speed Demon
Ron1n's Avatar
Drives: 2021 M5C
2021 M5 Competition  [0.00]
2016 BMW 550i  [0.00]
2011 335is  [0.00]
2009 E93 M3  [10.00]
2010 335d  [9.50]
This is EXCELLENT to hear.
They'll have a future customer in me VERY soon.
Current: '21 M5C, '15 X6 50i Previous: '18 M550i, '16 550i, '11 335is, '09 E93 M3 DCT, '10 E90 335d, '07 E90 328i
      11-05-2009, 05:19 PM   #8
coolchu001
coolchu001's Avatar
47
Drives: 09 BMW 335d
Can this be self installed?? as in easily plug in play, similar to the JB3?
450 wheel hp is around 520 ft-lbs at the crank assuming around a 16% loss factor.
I really hope you meant HP ;-)
      11-05-2009, 05:22 PM   #9
Jim E.
Jim E.'s Avatar
92
Originally Posted by Twilight1 View Post
Alright,Jim! It's funny, today I e-mailed Imran at Evolve asking when his re map will be available. 520 ft-lbs is plenty considering the tranny has a limit at around 500, from what I've read.
I've been on Imran's list since June or so. :-)
I was under the impression that the tranny limit in the 335 is 700NM. It's still a mystery to me.
I'm not sure about the difference between a tuning module and a re-map. I'd love to know what the parameters are. I was told that the tuning module adjusts boost and fuel pressure at the rail but I cannot be sure.
      11-05-2009, 05:25 PM   #10
Jim E.
Jim E.'s Avatar
92
Sorry I had a brain spasm! LOL!
      11-05-2009, 05:29 PM   #11
Twilight1
Drives: Tuned SHO
700NM is 516 ft-lbs. And I think you're correct with the 700 limit. I'm sure it's a very stout transmission. I can't wait to hear your impressions. Now, when is the LSD coming ?
      11-05-2009, 05:48 PM   #12
Jim E.
Jim E.'s Avatar
92
Dude, are you reading my mind or what???
I already have the diff but just need to send it out to Wavetrack. Can't wait!
      11-05-2009, 06:20 PM   #13
Insider
Insider's Avatar
14
Drives: 2007 335i
What's the boost pressure on the diesel with this chip?
http://www.insiderpicks.com - The world's best stock picks.
      11-05-2009, 06:32 PM   #14
Jim E.
Jim E.'s Avatar
92
I really don't know. You'd have to call Steve at VAC Motorsports.
      11-08-2009, 09:36 AM   #15
Twilight1
Drives: Tuned SHO
Jim,
Any other thoughts now that you have a few miles on the Module?
      11-08-2009, 09:46 AM   #16
bavarian19
bavarian19's Avatar
Drives: Car
      11-09-2009, 02:04 PM   #17
Ron1n
Speed Demon
Ron1n's Avatar
Drives: 2021 M5C
2011 335is  [0.00]
2009 E93 M3  [10.00]
2010 335d  [9.50]
I'm interested in hearing more feedback now as well. I've already set the money aside..just want to hear some more.
      11-10-2009, 07:21 AM   #18
MartinS
MartinS's Avatar
Drives: G82 M4 x-drive
Here is mine (euro):
http://www.niiice.dk/signatur_2010.jpg
435d xDrive & M5 F90 Frozen dark silver metallic
      11-10-2009, 09:23 AM   #19
Ron1n
Speed Demon
Ron1n's Avatar
Drives: 2021 M5C
2011 335is  [0.00]
2009 E93 M3  [10.00]
2010 335d  [9.50]
I hate you for being able to get that car in a coupe. >.<
      11-12-2009, 05:40 PM   #20
Twilight1
Drives: Tuned SHO
OK, Jim ,it's been a week. We need some more info.
It's also time for the LSD!
Funny story... My wife accused me of re mapping the car because of the added response from the cold air. All cars benefit from the denser air but it seems these diesels really react to the lower air temps.
      11-12-2009, 06:14 PM   #21
Ron1n
Speed Demon
Ron1n's Avatar
Drives: 2021 M5C
2011 335is  [0.00]
2009 E93 M3  [10.00]
2010 335d  [9.50]
Do share, Twilight.
What you got goin on?
      11-12-2009, 06:18 PM   #22
Twilight1
Drives: Tuned SHO
Originally Posted by Ron1n View Post
Do share, Twilight.
Just commenting on how the car responds to colder weather. Feels like a 20 hp boost.
e90post
