E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90/E92/E93 Marketplace (For Sale / Trade / Wanted) > SPONSORS Classifieds/Groupbuys/Specials Area > Lighting / Electronics / Audio / Security > RENN Spec | Macht Schnell Gauge Panel, TPMS Emulator, Light Battery Kit, Floor Mount
      09-03-2009, 04:56 PM   #1
RENN Spec
Drives: 488 Pista, M2CS, Tundra
Hello,
As an authorized dealer, we're glad to be carrying all the Macht Schnell product for the e9x 3 series. These products have been rigorously tested by the guys over at Macht Schnell to insure the best quality in terms of durability and material.
Macht Schnell Light Weight Battery Kit
Stock BMW batteries can weigh in at approximately 60-65lbs. A lightweight battery is a great way to shed unwanted pounds for vehicles that see extended track use. However a smaller battery footprint means it will not fit in the same location without fabricating your own mounting solution.
Macht Schnell Battery Enclosures are CNC-machined from the same aerospace 6061-T6 lightweight billet aluminum as our Competition Wheel Spacer kits and feature a black anodized finish which is strong and non-corrosive to withstand grueling conditions while keeping your battery worry-free. Simply put - these are the finest-engineered battery enclosures available for your BMW. Your stock BMW battery can be easily swapped at any time during off-season.
Macht Schnell recommends Braille batteries. Always refining and creating Braille saw the need to develop a lighter alternative to providing even longer lifer for their line of batteries. The solution towards longer life came in addressing what causes batteries to fail, heat and vibration.
  • Machined from 6061-T6 aerospace aluminum
  • Overall footprint are exact dimensions of stock BMW battery, engineered for a perfect fit
  • Shaves approximately 50lbs from stock battery setup
  • Holds battery securely in place
  • Top-mounted terminal indicator can be reversed for left/right positive terminals
  • Black anodized finish for additional strength and corrosion/wear resistance
  • Macht Schnell logo engraved in holder
  • Easily swapped for stock battery at any time
  • Weighs only 2.5lbs without battery
  • Includes corrosion-resistant hardware
  • Available for Braille 11.5lb, 15lb, 17.5, 21lb Batteries
Macht Schnell Floor Mount
Race seats can offer a an immediate improvement in driver feedback keeping you planted to the seat and concentrated on driving, while offering a significant weight savings. However, most race seat companies leave it up to the driver for a mounting solution.
Macht Schnell Floor Mounts are designed for the serous track enthusiast in mind. CAD designed and machined from 6061-T6 aerospace aluminum, these mounts are as strong as they are light. Multiple mounting positions allow driver to dial in an exact seat position that is most comfortable and perfectly centered to the steering wheel.
Macht Schenll TPMS/RDC Emulation Module
Tire Pressure Monitoring System (TPMS) is an electronic system designed to monitor the air pressure inside all the pneumatic tires on all BMWs manufactured since 2006. Within a predetermined pressure level, a RF signal (433mHz) is sent to each of the receivers located in the wheelwells. These systems report an error message to the driver when pressure is low.
Battery-powered Radio Frequency based TPMS have several disadvantages. Batteries eventually become exhausted and represent a maintenance cost to the consumer. Batteries are chemical systems with lifetimes that unfortunately perform very poorly in extreme temperature environments typical of North America and European climates and in aerospace applications. In order to conserve battery life and to conform to various countries communication authority standards for short range radio communications, the power levels of battery powered TPMS are kept very low . As a consequence of these very low power levels, the construction of certain steel belted radial replacement tires and vehicle metallic geometries can block the low power signal transmission paths.
The so-called total cost of ownership for direct systems is much higher than for indirect systems due to battery and wheel changes and broken/damaged parts. Replacement TPMS sensors from your local dealer can be in excess of $300USD/set with the lithium batteries mounted in the sensors with a 5-6 year shelf life. Aftermarket sensors are not generally reliable.
For those that have multiple tire sets for the track, this is simply not practical. Our TPMS/RDC Emulation Module installs in less than 15 minutes and will fully emulate a full-pressure TPMS signal when activated. Module can be activated/deactivated by lifting up on the driver’s side window switch for +5 seconds with the key off.
Macht Schnell Macht Schnell TPMS/RDC Emulation Module features:[List][*]The ability to run racing tires/wheels or other environments in which TPMS sensors are not compatible[*]Easy 15-minute installation process with no wire cutting[*]Proper emulation of the TPMS/RDC monitoring system[*]No dealer visits or coding required after installation[*]Completely removable at any time
Note: The Macht Schnell TPMS/RDC Emulation Module will disable the TPMS/RDC monitoring system which complies with the Transportation Recall Enhancement, Accountability and Documentation (TREAD) Act. For this reason, this module is not intended for street vehicles and can result in possible injury or death if proper conditions are not followed. Not compatible with euro models
Macht Schnell Astray Gauge Panel
We will be offering the new Macht Schnell astray gauge panel for customers who are looking to add aftermarket gauge inside their cabin. The Macht Schnell ashtray gauge panel are perfectly position in where the OEM ashtray used to be to give you a cleaner, more factory look yet allowing the driver great visibility on the crucial data. The openings are 52mm allowing you to put your favorite gauge where it be Defi to SRTi.
  • Painted a dull oem finish to compliment the interior
  • Made with ABS plastic for a durable construction.
  • No modification, drilling or cutting to your oem panels
  • Combo Package available with your choice of gauge.
Gauge options:
We can get numbers of aftermarket gauges to pair with the Macht Schnell Gauge.
What we recommend:
Defi Racer Gauge:
More infomation here: http://www.defi-shop.com/product/rg/rg_top.html
These are available and ready to ship. Please PM me for price for any of these products.
-Jason
      09-22-2009, 02:16 PM   #2
RENN Spec
All inquiries replied.
e90post
