Common CV boot problems
07-16-2009, 07:50 AM | #4 |
Rep 28,154
yes the cv boot is supposed to be filled with a special grease. over time the boot dryrots and the grease begins to come out, the biggest cause of the joint going bad is not lack of grease, but the dirt getting into the boot.
07-16-2009, 07:52 AM | #5 |
Rep 28,154
is that collar oily? it looks to me like condensation from the a/c system, if its not oily its just the water dripping from the ac system sweating and is rusting that collar
07-16-2009, 11:44 AM | #6 |
Rep 53
Whats the best way to prevent the boot from dryroting?
07-16-2009, 11:47 AM | #7 |
Rep 28,154
nothing really, i guess if you wanted to be real anal about it you could try like armor all or something on it. the problem is the rubber is subjected to the engine heat, anything that leaks from the car (oil, antifreeze, gas) and also exposed to those from the road, and salt. they normally last a long time without any treatment
07-16-2009, 01:24 PM | #8 | |
Rep 708
Yep, collar is oily. The opposite side is not. Watched an oil line grow on the collar over a two week period. Now it's covered. Not sure of source. Going to get it checked out in a couple weeks. Long wait for loaner |
07-22-2013, 05:42 PM | #9 |
Rep 4,732
Drives: Alpine White '13 550i
My CV boot just went out.. I guess it's common with 330xi's. Anybody have more info on this? Bumped because don't think I should start a new thread for this.
08-10-2013, 12:17 PM | #10 |
Rep 2
My CV boot just started making some funny noises when i turn slowly. At least i think thats what it is. I havent had a chance to take a look at it yet.
09-11-2015, 02:50 PM | #13 | |
Rep 55
Also, this as a DIY does look pretty difficult if you aren't experienced (I'm not).
09-11-2015, 05:15 PM | #14 |
Rep 2,109
That OP picture looks like oil leak from axle-differential seal. The CV joint has grease, and so thicker than oil and I don't think it will "leak" unless the boot is torn somewhere in its folds.
09-14-2015, 08:37 AM | #15 |
Rep 947
Use a rubber moisturizer/treatment. You can try 303 aerospace.
120k on my 330xi cv joints. All boots are fine and have no signs or cracking/dry rot. I'm lowered as far as I can go on H&R coilovers as well since 82k miles. Typically when the boot tears, grease is slug all over the wheel well. It's not oil, it's grease packed. |
