E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > what are the 335d tuning options?
      07-01-2009, 01:18 AM   #1
jayjay
Drives: BMW station wagons
Just came back from test driving the 335d. It was great....for a diesel, but performance wise I wasn't that impressed. What are the current offerings for performance sw and piggybacks? What kind of wheel hp/torgue numbers can these engines produce with a tune?
      07-01-2009, 04:39 AM   #2
Andras
Bodhisattva
Andras's Avatar
Italy
14
Drives: 335i E92 MY07
Wink
I would say
*ECU flash
*sprintbooster
*sporty air filter
Unfortunately US 335d are tuned down in comparison with European ones because of restrictions on emissions. Not to mention the fact that 335d's Steptronic never launches in first gear unless you use it in a manual mode.
That's why the 3 options above are not options, they are a "MUST HAVE"
Salut, Gilles!
335I E92 6AT - V3.2 - GRUPPE M - FMI - RR DOWNPIPES - AE EXHAUST HFC
      07-01-2009, 05:11 AM   #3
E92Fan
E92Fan's Avatar
Drives: .
You should have a browse of the UK forum - the UK leads the way for diesel tuning, especially with the 335d. Most members are running 285rwhp (350bhp flywheel) and 515lbft torque calculated at the flywheel (measurements off a Dyno Dynamics road)
There are one or two piggybacks available, but the best solution is by far the ECU flash.
Some threads for you to browse:
http://www.e90post.com/forums/showthread.php?t=174545
http://www.e90post.com/forums/showthread.php?t=113581
http://www.e90post.com/forums/showthread.php?t=263369
http://www.e90post.com/forums/showthread.php?t=254282
http://www.e90post.com/forums/showthread.php?t=253564
http://www.e90post.com/forums/showthread.php?t=155537
      07-01-2009, 08:40 AM   #4
racediesel
Drives: BMW 535xd 2012 F11
hey
now have been on dyno two times.
firts time try to get so much out as can with DPF.
results are: about 320-325hp and about 660nm.can get more but then DPF start get dirty very very fast.so i do not beliewe some countryes cars have so much power with DPF.maybe get little bit more=more shit to DPF and dyno shows more than here...
second time DPF away,3inch downpipe.
361hp and 780nm.now propblem is boost start increasing itself after 3000rpm=wastegate too small.
next:
have to increase downpipe size to 3,5inch and exhaust pipe to 2x2,5inch.
port westgate.
this way could get broken 400hp.torgue to higher rpms maybe also more.not down because gearbox.
Greetings
Pasi from Finland
      07-01-2009, 08:54 AM   #5
marconi118
Drives: 06/07 e93 335i
Originally Posted by racediesel View Post
hey
next:
port westgate.
Greetings
Pasi from Finland
What flash are you using?
changing parameters after every hardware change?
      07-01-2009, 11:09 PM   #6
racediesel
program is modded on dyno and flashed via OBD.
dynochart:
http://kuvablogi.com/nayta/2023868/
e90post
